Old 11-19-2024, 10:18 AM #1
alia176 alia176 is offline
alia176 has a spectacular aura about alia176 has a spectacular aura about
Snow chains for front wheels
I'm curious if anyone has any luck finding a set of snow chains for their front tires. As y'all know the clearance is tight between the sidewall and the UBJ. I have SPC UCAs but even then clearance is tight with this set that I used to run in the rear, see the attached pics. You can see my red snowshoes leaning against the front tire. I tried fitting the Laclede chains shown below up front and the clearance is just too tight for comfort. It won't take much to destroy/damage the UBJ in short order.
Before anyone pipes up with useless commentary, let me say this:
- these aren't used on the hwys.
- No, i don't want silly cable chains. Those are for the hwy.
-I'm running Wildpeak AT/4s and they're awesome winter tires. But I'm going in deep stuff, and even those tires are no match for certain conditions.
- No, tall mud tires aren't good for these conditions either. While they're great for our egos, they're useless in deep snow/ice.
- i'm going into the woods to go snowshoeing or backcountry skiing, usually in the middle of a snow storm.
- I'm running aggressive ladder style chains in the rear, but wanted additional traction up front. i realize this may not be possible.
Thanks for your valuable insights.
Snow chains for front wheels-capture-laclede-tire-chains-jpg  Snow chains for front wheels-capture_2-jpg
2003 Sport V8 Icon 2" rear, Bilstein 6112 front with 700# king springs, Gibson cat back, Magnaflow cross pipe. OBA, DIY sliders, etc
1996 FZJ80 landcruiser with whole bunch of stuff, including a Turbo.
1997 4Runner SR5 - daughter's ride, slowly getting built up
alia176 is offline   Reply With QuoteReply With Quote
Old 11-19-2024, 11:00 AM #2
Inv4drZm's Avatar
Inv4drZm Inv4drZm is offline
Inv4drZm's Avatar
Add a set of wheel spacers to the front for winter conditions?
2005 4R "The last of the V8s!" - TC +2 LT. - Lockers Front & Rear - 37's - Dana 60 - Build Thread
2005 Tundra 2WD Regular Cab 4.7L - Chopped Frame - Short Bed Swap - Lowered
2019 Tundra 4WD Double Cab 5.7L
Inv4drZm is offline   Reply With QuoteReply With Quote
Old 11-19-2024, 11:53 AM #3
MrTom's Avatar
MrTom MrTom is offline
MrTom is an unknown quantity at this point
MrTom's Avatar
What brand ladder style chains in the rear are you using?
Thanks..
03 4Runner Sport V-8 4WD
MrTom is offline   Reply With QuoteReply With Quote
Old 11-19-2024, 01:20 PM #4
Hmm I hadn't thought of THAT angle. Quite ingenious actually. I wonder if my daughter would notice if I stole a pair of spacers from her 3rd gen while we're doing her HG?
Great idea. Any cons to this, other than the scrub radius? Would I hate it? i wouldn't need much, technically, but spacers come at a min of 1.25" I think?
Old 11-19-2024, 01:37 PM #5
Thanks..
This is one example of the ladder chains that I'm using but any will work in the rear since there's so much room. Tire chains come up a lot in my FB Marketplace feed, just a FYI.
Peerless | Quik Grip 2200 LT
My 80 has ladder chains front and rear with quality bungee tensioners.
Snow chains for front wheels-20240105_111725-jpg
Old 11-19-2024, 05:14 PM #6
Inv4drZm's Avatar
Inv4drZm's Avatar
Shortest I see are 1" but maybe they make thinner hubcentric spacers that use existing studs like they use on cars.
KAX 6x5.5 1" Thick Center Bore M12x1.5 Wheel Spacers 2PCS
Old 11-19-2024, 06:10 PM #7
Thank you, this is good info to think about.
Old 11-23-2024, 08:51 AM #8
I was just thinking of changing out the rims for the correct offset vs using spacers, which I'm not a big fan of. I wonder if any of the fancy TRD rims would have the correct backspacing to push out the tire just a tad, we're talking 1/2" more than what I have now. I need to find out what the backspacing is on the factory rims and start with that. I'm not needing a massive spaced out stance; that's a Jeep thing, I wouldn't understand
Old 11-23-2024, 09:22 AM #9
thennen's Avatar
thennen thennen is offline
thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold
thennen's Avatar
Useless Commentary Alert - Aren't chains only to be installed on the rear tires? Not sure if that's just a clearance thing or a safety thing. I do know the owner's manual says not to do it.
thennen is offline   Reply With QuoteReply With Quote
Old 11-23-2024, 08:12 PM #10
Not useless at all, good question. The clearance is the main reason why I don't think oem wants you do it as that puts a huge liability on everyone.
What we're doing with our rigs is outside of the norm, in some cases we're being stupid so might as well go all the way!
For most conditions, rear chains will suffice. But I go play in deep snow where I'm plowing and I need to dig down to the native surface or the frozen ground under the snow, hence the need for chains up front.
Old 11-23-2024, 10:11 PM #11
thennen's Avatar
thennen's Avatar
What we're doing with our rigs is outside of the norm, in come cases we're being stupid so might as well go all the way!
Ah, I get you now. Well, enjoy the snow!
chains , front , set , snow , tires
Snow chains on front tires? kaitlyn2004 5th gen T4Rs 59 03-10-2023 02:13 PM
No snow chains on all four wheels? Joshua8200 Off-Roading 23 11-09-2021 07:18 PM
Snow chains on front wheels w/ LR UCAs 1blink 3rd gen T4Rs 14 01-07-2015 12:50 AM
snow chains on front: Thule XG-12 Pro ... Ridgehiker 5th gen T4Rs 13 02-11-2014 01:57 PM
Snow Chains/Cables for 18" Wheels Atomic 4Runner Engines / Suspension / Wheels / Tires / Audio / Accessories 2 11-25-2006 05:43 AM
