Old 12-08-2024, 03:15 PM #1
gh25_'s Avatar
gh25_ gh25_ is offline
Real Name: Garrett H.
gh25_ will become famous soon enough
gh25_'s Avatar
5th gen 4runner OEM cv axles fitment
Hi all,
I am new to this 4th gen fourms but I am not new to the 3rd gen fourms on here. I bought a 98' SR5 2wd Jan of 2023 but just recently upgraded to a 05 v8 4x4. Been loving it so far. Been doing tons of maintenance, alternator, timing belt, tranny fluid changes, etc.. One of the things that needs replacing though are my cv axles. The pervious owners had replaced the OEM cv axles with some cheapies (GSP) from rock auto, and both of the outer boots are torn leaking and have been for a while and are slinging bits of grease everywhere. I am in a 4th gen group on Facebook and I saw on there someone said you can use 5th gen cv's and they will bolt right up on our 4th gens. I also have seen people have issues with the front differential leaking after they replace their seals / cv axles. So, 4th gen axles are obviously discontinued and now the original 5th gen axle part# is now discontinued as well (4343060082). Now you can only get the new 43430-60083 part #. Does anyone know the difference between the two? I have heard the difference now is that it uses a different lock nut and you bang the nut with a chisel to lock it in instead of a cotter pin. But other than that there is no difference? I would hate to buy a set and install them just to have an issue like the infamous front diff leak lol. Or if anyone has a good suggestion for a non OEM brand they have had good experience with. And no I will not be using CVJ... they would be a rip off for me. After tax, shipping and core charges I would be in way more than OEM would cost, especially since I don't have OEM axles so I wouldn't get my core charge back. Screw them. But anyways. Any help is appreciated, I would like to get them replaced soon. Thanks!
gh25_ is offline   Reply With QuoteReply With Quote
Old 12-10-2024, 02:20 AM #2
Az4runnin's Avatar
Az4runnin Az4runnin is offline
Az4runnin will become famous soon enough Az4runnin will become famous soon enough
Az4runnin's Avatar
My son just ordered 5th gen axles and received them so we are in the same boat. I wasn't even sure if these were even gonna work but he said he did a lot of research and heard that they do work so I have some similar questions as well. Hopefully you can get some good feedback on these questions as I am very interested to find this out myself.
2003 V8 Limited 4x4 Black. JBA UCA's, TRD Pro Wheels. OEM LED Tails, 2012 FJ Springs F/R 5100's F/R 1.75 Cooper AT3 4S 265-70-17. Bye X Reas, Wet Okole Seat Covers Weathertech liners.
Az4runnin is offline   Reply With QuoteReply With Quote
Old 12-13-2024, 09:22 PM #3
084RUNNAH's Avatar
084RUNNAH 084RUNNAH is offline
084RUNNAH is on a distinguished road
084RUNNAH's Avatar
I recently installed some 5th gen cv axles on my 08. They were used from a 2023 4Runner. No issues
2008 Toyota 4Runner Limited V6
| Spidertrax | OME 886 and Icon Overland Coils | Kenwood DNX9980HD | JL 8W3| HID | Full LED |
| S2000 headlight retrofit | URD Spec U Long Tube Headers | Borla Cat-Back Dual Exhaust | 5th Gen Brakes |
084RUNNAH is offline   Reply With QuoteReply With Quote
Old 12-17-2024, 03:18 AM #4
gh25_'s Avatar
gh25_'s Avatar
Thanks for the info. Will prolly pull the trigger on some soon here now, need to replace them haha
Old 12-17-2024, 02:26 PM #5
alia176 alia176 is offline
alia176 has a spectacular aura about alia176 has a spectacular aura about
I thought I heard that the GX460 front CV axles are also a direct fitment into a 4th gen 4runner. Perhaps the GX and a 5th gen share the same front axles? in either case, they're both an upgrade for a 4th gen.
2003 Sport V8 Icon 2" rear, Bilstein 6112 front with 700# king springs, Gibson cat back, Magnaflow cross pipe. OBA, DIY sliders, etc
1996 FZJ80 landcruiser with whole bunch of stuff, including a Turbo.
1997 4Runner SR5 - daughter's ride, slowly getting built up
alia176 is offline   Reply With QuoteReply With Quote
Old 01-04-2025, 01:03 AM #6
Az4runnin's Avatar
Az4runnin's Avatar
Just put 5th gen Axles on my Son's 4th gen. Only difference is Axle nut. No more click. JBA Uppers and OEM LCA's
Old 01-11-2025, 06:58 PM #7
warrig warrig is offline
warrig is on a distinguished road
Confirmed that 5th gen axles do work in 4th gen. I just used doubled axle nuts on the ends. Been ~5k / 8 months without issues. Will inspect check torque this spring / summer. Hope the CV boots and axles last 100k +. I also got 5th gen OEM CV boots that I need to put on old 4th OEM axles for spares, TBD.
warrig is offline   Reply With QuoteReply With Quote
Old 01-12-2025, 11:45 PM #8
gh25_'s Avatar
gh25_'s Avatar
Really good to here. I'm saving my money to buy some right now. Eventually I will haha
Old 01-13-2025, 08:42 AM #9
Buckaroo's Avatar
Buckaroo Buckaroo is offline
Buckaroo will become famous soon enough Buckaroo will become famous soon enough
Buckaroo's Avatar
A bit off topic but are people upgrading to the 5th gen CV axles because there is a problem with the 4th gen? Or is it that used OEM 5th gen CV axles with low mileage are more readily available and they fit? I recently replaced a CV axle on my '05 with an aftermarket rebuilt unit - both had been replaced before I bought it. I installed a Cardone unit from Rockauto which I know gets a lot of side eye but I have used them in the past with good results. The stated fitment on that part includes 4th and 5th gen. Did have leakage so had to do the job over again and replace the seal which fixed the problem. I attributed that to sloppy technique on my part installing the original replacement seal, not the CV axle.
2000 T4R SR5 V6 (Retired) & 2005 T4R Limited V6
2002 & 2017 XLE Camry
2004 Honda Accord
2017 Tundra Limited DC 5.7L TRD 4WD
2024 Honda Pioneer 700-2 Deluxe
Buckaroo is offline   Reply With QuoteReply With Quote
Old 01-14-2025, 12:51 AM #10
88Center 88Center is offline
88Center is on a distinguished road
yes, but only because they upgraded the boots on the 5th gen. I think the CV part is the same. But nobody wants to do the messy job of replacing boots because it's such a messy job, so they just order new.
88Center is offline   Reply With QuoteReply With Quote
Old 01-14-2025, 01:53 AM #11
I'll be doing the same this summer. Just need to order some tools.
Old 01-16-2025, 09:23 PM #12
gh25_'s Avatar
gh25_'s Avatar
If your like me and are in the same boat of needing to replace your CV's you are way out of luck to try and buy new "4th gen" cv axles. The part # for them has been discontinued a long time ago. Discontinued = you can't get them anymore. The newer 5th gen units are better design with the boots and they use a different type of bearing inside the joints themselves from the 4th gen. Due to the OG part being discontinued and the 5th gen being a direct fit w/ upgraded design that's why its the choice for many including myself. I wouldn't mind a non oem axle but I dont trust the chinese bearings they come with and my aftermarket cv axles on my truck put on by the PO already have torn boots. You get what you pay for with the cv axles. The boots on your cardones will probably leak sometime within 4 years at least if not sooner. The materials just aren't the same as OEM.
4th , 5th , axles , gen , oem
4runner on 80-Series Axles? danthemanx07 3rd gen T4Rs 29 03-31-2021 11:00 AM
FJ axles are interchangeable with the 4th Gen 4Runner lj4r 4th Gen T4Rs 3 08-10-2019 06:04 PM
4Runner vs. Tacoma CV Axles JZiggy 3rd gen T4Rs 7 01-12-2018 08:40 PM
Tundra CV axles on 3rd gen 4Runner 4wd4runner 3rd gen T4Rs 10 05-20-2016 06:37 PM
solid axles 94 4runner jamie67 Classic T4Rs 1 03-23-2011 10:15 PM
