Old 12-14-2024, 12:06 PM #1
GoBucks! GoBucks! is offline
GoBucks! is on a distinguished road
Transmission Line Leak
Hi, I got stranded yesterday with no shift with the transmission. Quickly realized I had a fluid leak and think I've located it, but can't ID the part. Looks like an easy fix (famous last words), although I fear this may be a power steering line.
Anyone know the part number of the line to the right? Looking down from the front of the vehicle in front of the radiator/trans cooler. You can see the rupture toward the bottom.
Transmission Line Leak-screenshot-2024-12-14-110710-jpg
2008 4Runner Limited V8
GoBucks! is offline   Reply With QuoteReply With Quote
Old 12-15-2024, 04:20 PM #2
4R005 4R005 is offline
4R005 is on a distinguished road
Believe this is the part you'll need. p/n 3290760071
It a combo of the feed and return lines w/two brackets that'll attached to front frame just under radiator.
4R005 is offline   Reply With QuoteReply With Quote
Old 12-15-2024, 08:38 PM #3
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
I bought the lines from Autozone and it was a Dorman, their PN: 624-279 for $99.35 including tax. High quality, fit perfect been installed since July, 2023.
It is both steel tubes and they tie together just like the original.
2003 Limited, V8, AWD. K&N, Dobinson IMS/FJ springs,, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around, spare tire relocated to inside cargo area.
Old 12-16-2024, 12:59 PM #4
@GoBucks!
Apologies. Was working on my '05 T4R this morning and noticed that the leaking line you indicated in your pic is actually the return line from the power steering rack back to reservoir. The two lines mentioned in my previous reply and rdruss are the feed and return lines from the transmission. Size of steel line is 3/8" and you can easily DIY. Online OEM Toyota parts supplier, p/n 4442035201 shows an insane price of CDN$245.00
I'm forgetting you mentioned no shift from your tranny. Like rdruss, I too had to replace the two ( feed & return ) lines from tranny when rust ate thro' one of them. Perhaps its coinsidence but do check the two lines also under the radiator AND the two long steel lines coming directly from the tranny to join up with short lengths of flex lines to the two under the radiator. I lost my tranny 3 years ago( cost me $4200.00 for a complete rebuild) when it ran dry from these rusty line breaks and subsequent leaks.
Old 12-16-2024, 05:40 PM #5
Thanks, all! After I posted, I actually crawled under the car and saw those two transmission lines. Thanks for the part number. I just ordered the Dorman part from Amazon and it was only $59.
The two longer lines to the tranny were replaced a couple of years ago and they still look brand new.
Now I just need to figure out the procedure for refilling everything. Just keep topping off , then running until it reaches the appropriate level?
Old 12-17-2024, 02:38 PM #6
alia176 alia176 is offline
alia176 has a spectacular aura about alia176 has a spectacular aura about
You have a dipstick-less tranny so "checking it" isn't as easy. I'm sure others will chime in but just a FYI.
2003 Sport V8 Icon 2" rear, Bilstein 6112 front with 700# king springs, Gibson cat back, Magnaflow cross pipe. OBA, DIY sliders, etc
1996 FZJ80 landcruiser with whole bunch of stuff, including a Turbo.
1997 4Runner SR5 - daughter's ride, slowly getting built up
alia176 is offline   Reply With QuoteReply With Quote
Old 12-17-2024, 09:38 PM #7
revox92's Avatar
revox92 revox92 is offline
revox92 is on a distinguished road
revox92's Avatar
I'm curious too on how to check level of dipstick less tranny. Hope someone would shed a light here.
2004 Toyota 4Runner SR5 4WD Auto
revox92 is offline   Reply With QuoteReply With Quote
Old 12-17-2024, 09:40 PM #8
There is a vid from The Car Care Nut that showed a step by step of filling procedure for a dipstickless tranny. Believe vid was of a Camry but procedure is the same for your T4R as well.
Old 12-18-2024, 12:20 PM #9
Hungryhawk Hungryhawk is offline
Hungryhawk will become famous soon enough
Final fluid level in tranny is a procedure. Best done if you have a readout of tranny temp.
Basically you overfill a small amount-then at the correct temperature you open the special drain plug that is connected to a pipe inside tranny. When fluid dribbles you put this special plug back in.
My Scanguage 2 provides tranny temp and dozens of other readings thru OBD2.
Verify your year and model 4runner outputs the tranny temp thru the OBD2. It is a handy tool- I have mine attached all the time for reading my tire pressure.
Hungryhawk is offline   Reply With QuoteReply With Quote
Old 12-18-2024, 01:10 PM #10
I bet Tim the Toolman has a video on this process. Just check YT as he has tons of awesome vids.
front , leak , line , part , transmission
HELP! AC Hose/Line Leak steanson 5th gen T4Rs 7 07-05-2024 01:18 AM
Brake line leak? Daddycreswell 3rd gen T4Rs 4 07-03-2019 12:14 AM
Break Line Leak? rpontbriand 5th gen T4Rs 8 01-02-2019 10:30 PM
Brake line leak BigWoody 3rd gen T4Rs 2 03-29-2015 08:03 PM
EVAP Line Leak & VSC LIGHTS ehampt 4th Gen T4Rs 0 09-21-2012 01:52 PM
