Old 01-12-2025, 09:00 PM #1
Millmoss Millmoss is offline
Millmoss is on a distinguished road
Friend selling 4Runner. There are some issues though.
It's a 2009 SR5, 4WD.
From the ad: "Check engine light is on and says o2 sensor is bad, but replaced o2 sensor and CEL came back on."
In talking to them, they also cleaned the MFA and then replaced it.
Here are the codes:
P0171
System Too Lean (Bank 1)
P0174
System Too Lean (Bank 2)
P0138
O2 Sensor - Circuit High Voltage (Bank 1 Sensor 2)
I would take it to our mechanic, who is great, but that's who THEY took it to. So I'm at a loss. I would love to be able to buy it for my son whose car just died, but I don't want to buy into a problem vehicle.
Anyone experienced this and is there something that could be done? It can't pass inspection with the check engine light. Owners say it drives fine - just drove it three hours away and back with no issues.
Any help would be appreciated. Thanks!
Millmoss is offline   Reply With QuoteReply With Quote
Old 01-13-2025, 10:26 AM #2
Ralph Blake Ralph Blake is offline
Ralph Blake is on a distinguished road
Smile
If it will start and you can drive it without a problem and gas milage is within reason, i would start trucking.
Toyotas throw many codes some are important others just make a lot of money for part sellers and the people doing a lot of not needed work to fix a code item that really does not exist.
Ralph Blake is offline   Reply With QuoteReply With Quote
Old 01-13-2025, 01:55 PM #3
Thanks Ralph. Its more the issue of getting it registered.
Old 01-13-2025, 01:56 PM #4
And also, buying a car with an unsolvable check engine light doesn't feel great to me. I was hoping someone here might have had or seen or heard of a similar issue and could provide some insight.
Old 01-13-2025, 02:25 PM #5
Runnin on E Runnin on E is offline
Runnin on E will become famous soon enough
How many miles? If you can't do the work yourself I would find a better mechanic. The factory service manuals are on this forum. If you follow the test procedures carefully you can find this issue. I recently found a broken wire for a wheel speed sensor after getting a few lights on the dash. I have tools though....and time to go through the process...and a lift....in a garage...BUT the manual was the key. One warning is that Toyota has a lot of "special" tools listed in their manuals. That's where this forum (and others) really helps because others have already figured out how to get around those usually expensive tools. Sometimes there are no alternatives...
Runnin on E is offline   Reply With QuoteReply With Quote
Old 01-20-2025, 03:16 PM #6
Ventil8 Ventil8 is offline
Real Name: Armando
Ventil8 will become famous soon enough Ventil8 will become famous soon enough
Real Name: Armando
O2 sensor codes? I’m still on the original O2 sensors on my 2005. I’ve owned it for 20 years(bought it new Feb 2005). From what I’ve read is that sensors should always be Toyota sensors, not some off brand or aftermarket. You can try and cheap out but lots of people have issues. I would make sure they are replacing them with OEM Toyota parts. The only parts that I didn’t go OEM are the front wheel bearings. Bought them from a forum member here that made them bolt on using Timken wheel bearings. Good Luck.
Original Owner- 2005 Silver Metallic Sport Edition 4WD V6
Ventil8 is offline   Reply With QuoteReply With Quote
Old 01-20-2025, 03:35 PM #7
Hungryhawk Hungryhawk is offline
Hungryhawk will become famous soon enough
Usually title cannot transfer without a smog pass. A recurring CE will fail a smog test.
If you value the friendship I would walk away from this problem vehicle.
There are lots of well maintained vehicles for sale. Reasons for existing owners to sell are vast.
Keep looking, perhaps a Camry would be a safer and less maintenance demanding vehicle.
Hungryhawk is offline   Reply With QuoteReply With Quote
back , bank , lean , replaced , sensor
Asked a cop friend how to steal a 4Runner Seymore Butts 4th Gen T4Rs 15 10-14-2021 09:11 AM
RIP My Old Friend - 2008 4Runner SR5 aluker85 4th Gen T4Rs 19 06-21-2018 09:59 PM
Help! Differential went out in my friend's 05 4runner FL054runner Problems & Warranty Issues 5 09-01-2015 09:19 AM
HELP! Selling 4runner but have Climate control LCD Backlight Issues! dannycwu 4th Gen T4Rs 5 01-12-2011 09:19 PM
Advice for friend looking to buy '95 4Runner live4swell 4th Gen T4Rs 7 05-13-2005 06:05 PM
