Old 01-25-2025, 12:34 PM #1
grumpy02 grumpy02 is offline
Real Name: Stan
grumpy02 is on a distinguished road
Real Name: Stan
How Long Should it Take for 4WD HI to Engage?
07 Sr5 4WD 4.0L A/T. I came to this vehicle from a 95 Tacoma V6, M/T, manual T/C & I know the electronic version is slower but really........Whenever I select 4Hi, it seems to take a very long time for the actuator to actually engage. Like minutes as opposed to seconds. (I haven't actually timed it but I can if it will help with the question) To the extent that I frequently no longer need 4WD by the time it engages. As in I have already slipped & slid my way through the snowy stretch. Any thoughts on what if anything can be done to make it work more quickly?
grumpy02 is offline   Reply With QuoteReply With Quote
Old 01-25-2025, 01:55 PM #2
88Center 88Center is offline
88Center is on a distinguished road
Should not take that long. Mine usually shifts in 3-7 seconds. Occasionally I've had it not switch, and the indicator light on the dash keeps blinking. When it does, I'll stop, go in reverse, then stop, shift into Neutral, then flip the switch knob again.
Pages 167 - 175 for 4WD operation
4Runner Owners Manual - 2008
https://assets.sia.toyota.com/public...f/OM35897U.pdf
If the 4LO" (low speed four−wheel drive) indicator light continues to blink and the buzzer sounds when you operate the four−wheel drive control switch knob to the H4" or L4" position, drive forward or backward in a short distance, then stop the vehicle completely, shift the automatic transmission selector lever securely into N" and operate the switch knob again.
If the indicator continues to blink even if doing so, contact your Toyota dealer as soon as possible. There may be a trouble in the four−wheel drive system
88Center is offline   Reply With QuoteReply With Quote
Old 01-27-2025, 03:51 PM #3
Cezar Cezar is offline
Cezar is on a distinguished road
In my experience after basically never using 4WD for ten years it took a long time to engage. Last year or two I've been using it somewhat often and the engagement has gotten much faster and consistent. I am using it daily the past few weeks and it works as expected, 3-4 seconds usually.
It seems like the way it works is it checks parameters are nominal and then makes an attempt, and then if that doesn't work, backs off and tries again, maybe with some sort of "cooldown" multiplier. You can hear the relays clicking when it kicks off an attempt so there is some audible indicator of this.
Cezar is offline   Reply With QuoteReply With Quote
Old 02-10-2025, 11:50 PM #4
jrb.eleven jrb.eleven is offline
Real Name: Jake B
jrb.eleven is on a distinguished road
Real Name: Jake B
I have the same problem (07 4runner) but it sometimes takes up to 5 minutes to engage 4WD even while driving.
jrb.eleven is offline   Reply With QuoteReply With Quote
Old 02-16-2025, 03:12 PM #5
Hi-desertT4R's Avatar
Hi-desertT4R Hi-desertT4R is offline
Real Name: Matt
Hi-desertT4R is a glorious beacon of light Hi-desertT4R is a glorious beacon of light Hi-desertT4R is a glorious beacon of light Hi-desertT4R is a glorious beacon of light Hi-desertT4R is a glorious beacon of light
Real Name: Matt
My 07 takes a while and sometimes I have to “double tap” or switch it back to 2hi then to 4hi and it’ll engage quickly. I’m just used to it being slow and quirky
2007 Titanium SR5 4WD
Build thread: https://www.toyota-4runner.org/4th-g...ld-thread.html
Hi-desertT4R is offline   Reply With QuoteReply With Quote
4wd , engage , long , question , time
Cheapest Long IFS long travel Kits? Cap. Morgan General Discussions 19 05-05-2020 02:28 AM
Long, long Drive - OVERLAND EXPO WEST Khjphoto Off-Roading 7 05-14-2018 03:50 PM
Center Diff Lock takes a long time to engage, sometimes won't... cmpcmp123 4th Gen T4Rs 3 06-12-2014 09:05 AM
How long does it take for 4x4 to engage? me4run 4th Gen T4Rs 6 02-25-2011 12:15 PM
6cyl 4WD owners, how long for 4wd to engage?? davemac 4th Gen T4Rs 3 10-05-2007 10:03 AM
