Old 02-06-2025, 04:13 PM #1
SoCalRunner's Avatar
SoCalRunner SoCalRunner is offline
SoCalRunner is on a distinguished road
Does 5th gen suspension fit on 4th gen?
I have a 2004 4R with 170k miles. Original shocks are leaking and i was wondering if i could replace with some old 5th gen front and rear shocks.
TIA
2016 T4R TEP | Maxliner floor mat | KO2 285/70/17/C | Precision Interior LEDs | Ceramic window tint | AVS Aeroskin deflector | Rhino Rack Pioneer Platform | SunSeeker Awning | Fox 2.0 front/rear no res | Icon 52700 | VTX Wheels | Side exhaust | Xenon Depot HID Low Beams & LED fogs
Round Rock, Texas
SoCalRunner is offline   Reply With QuoteReply With Quote
Old 02-08-2025, 09:52 AM #2
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
TIA
From What I've read on here, yes, but not without some minor mod to the front shock. As I understand it, the 5th gen lower shock mounting bushing is just a little wider than the 4th gen, so you would have file, sand, machine, or otherwise narrow up the front lower shock bushing, and I don't think it's by much.
2003 Limited, V8, AWD. K&N, Dobinson IMS/FJ springs,, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around, spare tire relocated to inside cargo area.
Old 02-10-2025, 07:48 PM #3
Hi-desertT4R's Avatar
Hi-desertT4R Hi-desertT4R is offline
Real Name: Matt
Hi-desertT4R is a glorious beacon of light Hi-desertT4R is a glorious beacon of light Hi-desertT4R is a glorious beacon of light Hi-desertT4R is a glorious beacon of light Hi-desertT4R is a glorious beacon of light
Real Name: Matt
Lower front shock eyelet is a little wider. Nothing about 15 seconds on each face with an angle grinder and a flap wheel can’t fix.
2007 Titanium SR5 4WD
Build thread: https://www.toyota-4runner.org/4th-g...ld-thread.html
Hi-desertT4R is offline   Reply With QuoteReply With Quote
Old 02-19-2025, 07:58 PM #4
DMV4runner DMV4runner is offline
Real Name: William
DMV4runner is on a distinguished road
Real Name: William
I put 5th gen springs and shocks on my 2008 SR5. It only required a small amount of grinding to make it fit.
Failure is written in pencil. "This sucks" builds character.
Embrace the suck
DMV4runner is offline   Reply With QuoteReply With Quote
Old 02-20-2025, 12:41 PM #5
Berty_K's Avatar
Berty_K Berty_K is offline
Berty_K has a spectacular aura about Berty_K has a spectacular aura about Berty_K has a spectacular aura about
Berty_K's Avatar
Super detailed DIY here: 4th Gen TRD Pro Suspension Retrofit
Kudos to @randomtask16
'08 Silver SR5 V6 4x4: OEM+
Berty_K is offline   Reply With QuoteReply With Quote
Old 02-22-2025, 01:05 PM #6
TLar25's Avatar
TLar25 TLar25 is offline
Real Name: Taylor
TLar25 will become famous soon enough TLar25 will become famous soon enough
TLar25's Avatar
Real Name: Taylor
Yes it does. I have front and rear from a 5th Gen TRD pro on mine. Front required basically no modification, think I had to maybe grind a small amount on the front shock eyelets as it was a tight fit. The upper mounts for the rear shocks were too small though and I had to take a step bit to them.
1985, 22re, 5spd, 4x4, Marlin crawler dual transfer case, locked fr&rr, 35's
1996, 5vz-fe, Auto, 4x4, Bilstein/ome lift, tundra 17's, 33's
Sold(regret it)- 1999 Highlander edition, Auto 4x4, 3"lift, factory rear locker
TLar25 is offline   Reply With QuoteReply With Quote
Old 02-22-2025, 04:05 PM #7
LOSTR4's Avatar
LOSTR4 LOSTR4 is offline
LOSTR4 will become famous soon enough LOSTR4 will become famous soon enough
LOSTR4's Avatar
I put on a 5th gen Gibson exhaust on mine, too...just to add to the 5th Gen what-if conversation...
2005 T4R Limited V8 Dorado Gold Pearl|'06 Headlight/Taillight Update|5000k HIDs|VSC-Off|Husky-Lined|HCF Delete||IAP By-Pass|TPS By-Pass|AFE Pro Dry S|Gibson Cat-Back Side-Exit|Pioneer AVH3800BT|Sprint Booster|BD SSPro IFLs|LEDs|ICON 2.5+|SPC UCAs|TE/FJ Wheels|255/80 Cooper ST MAX|Spidertrax 1.25|Custom-ish End Links|Custom Perkins Roof Rack|40" LED Light Bar|SW Color-Matched Front Bumper
LOSTR4 is offline   Reply With QuoteReply With Quote
Old 02-22-2025, 11:07 PM #8
TLar25's Avatar
Real Name: Taylor
TLar25's Avatar
Real Name: Taylor
How does it sound?
5th , gen , leaking , shocks , wondering
WTB: TRD Pro Rear Suspension Take-Offs (Shocks & Suspension) - Houston, TX steveh_2007 For Sale: Suspension/Wheels/Tires 0 03-06-2020 12:02 PM
Box of new 4th gen suspension parts(Energy Suspension, OME, MOOG) and headunit $35 nytosc For Sale: T4R Items 0 08-06-2019 01:01 PM
FJ TRD suspension vs FJ TT suspension vs 5100 & FJ coils andreylights 4th Gen T4Rs 4 11-16-2018 12:48 PM
Swappin my OEM suspension to FJ Cruiser suspension James_T 4th Gen T4Rs 15 08-17-2010 09:04 PM
