Old 02-08-2025, 02:31 PM #1
parsky1 parsky1 is offline
parsky1 is on a distinguished road
V8 oil leak at timing belt tensioner and crank position sensor
I’ve got a 2005 v8 and I’m noticing oil seepage in the front. The timing belt tensioner is wet along with the crank position sensor and the very front of the oil pan. Only 200,000 miles and timing belt was done by Toyota 10k miles ago.
What could this be?
parsky1 is offline   Reply With QuoteReply With Quote
Old 02-11-2025, 11:49 AM #2
LOSTR4's Avatar
LOSTR4 LOSTR4 is offline
LOSTR4 will become famous soon enough LOSTR4 will become famous soon enough
LOSTR4's Avatar
I'd take it back and see what they say it is...it could be almost anything...like a poor performing tech service at dealerships...I wish there was an easy answer, but I'd have them check it out! 200k miles, if maintained well enough, is nothing for this engine!
2005 T4R Limited V8 Dorado Gold Pearl|'06 Headlight/Taillight Update|5000k HIDs|VSC-Off|Husky-Lined|HCF Delete||IAP By-Pass|TPS By-Pass|AFE Pro Dry S|Gibson Cat-Back Side-Exit|Pioneer AVH3800BT|Sprint Booster|BD SSPro IFLs|LEDs|ICON 2.5+|SPC UCAs|TE/FJ Wheels|255/80 Cooper ST MAX|Spidertrax 1.25|Custom-ish End Links|Custom Perkins Roof Rack|40" LED Light Bar|SW Color-Matched Front Bumper
LOSTR4 is offline   Reply With QuoteReply With Quote
Old 02-11-2025, 06:02 PM #3
alia176 alia176 is offline
alia176 has a spectacular aura about alia176 has a spectacular aura about
What could this be?
It's been a while since I did the timing belt project but how did you determine the belt tensioner is moist? It lives behind the timing cover and not easily visible. The crank position sensor isn't too far away from the main seal so that could mean that the main seal is seeping, but that's a WAG at this point. The other clue is that the front of the oil pan is moist which could point the finger to the front seal. See if you can shine some light behind the front crankshaft pulley and look for oil seepage.
2003 Sport V8 Icon 2" rear, Bilstein 6112 front with 700# king springs, Gibson cat back, Magnaflow cross pipe. OBA, DIY sliders, etc
1996 FZJ80 landcruiser with whole bunch of stuff, including a Turbo.
1997 4Runner SR5 - daughter's ride, slowly getting built up
alia176 is offline   Reply With QuoteReply With Quote
belt , miles , oil , sensor , timing
CEL Crank position sensor! AF808fighter 3rd gen T4Rs 5 08-11-2020 10:56 AM
Crank timing wheel position (1GR-FE) andrewdn 4th Gen T4Rs 16 01-19-2017 10:17 PM
Timing Belt change- Tensioner and idler bearings? Hydraulic tensioner? DiskDoctr Maintenance/Detailing 10 09-13-2015 09:01 PM
3.4L crank position sensor symthoms goldshield1 3rd gen T4Rs 1 11-26-2011 02:16 PM
Timing Belt Tensioner: Should I replace it when doing the timing belt change? Lugnutz 3rd gen T4Rs 14 05-12-2011 12:58 PM
