Old 02-13-2025, 04:05 PM #1
t-rex grrr 2 t-rex grrr 2 is offline
t-rex grrr 2 is on a distinguished road
4th Gen V8 Regearing - 4.56 and 4.88
Hello,
For those that have regeared their 4th gen v8's, did you regret going with a 4.56 instead of a 4.88, and/or vice versa?
My situation is the following:
2006 V8
Currently running 295/70/17s
Considering 315/70/17s at some point
4runner is equipped with a front bumper, rear bumper swing out, and roof rack
I live at least 80 miles from the nearest dirt trail
I mainly drive trails with very little rock crawling
My main concern is picking the wrong ratio only to regret the other.
Thank you!
t-rex grrr 2 is offline   Reply With QuoteReply With Quote
Old 02-13-2025, 04:28 PM #2
LOSTR4's Avatar
LOSTR4 LOSTR4 is offline
LOSTR4 will become famous soon enough LOSTR4 will become famous soon enough
LOSTR4's Avatar
Go 4.88! it's like 200 RPM higher at 70mph...the extra torque and driveability is far greater with 4.88s...I don't have these gears but what EVERY single person in other forums and even different platforms state is they wished they just went with the higher gears...200 RPM is nothing
2005 T4R Limited V8 Dorado Gold Pearl|'06 Headlight/Taillight Update|5000k HIDs|VSC-Off|Husky-Lined|HCF Delete||IAP By-Pass|TPS By-Pass|AFE Pro Dry S|Gibson Cat-Back Side-Exit|Pioneer AVH3800BT|Sprint Booster|BD SSPro IFLs|LEDs|ICON 2.5+|SPC UCAs|TE/FJ Wheels|255/80 Cooper ST MAX|Spidertrax 1.25|Custom-ish End Links|Custom Perkins Roof Rack|40" LED Light Bar|SW Color-Matched Front Bumper
LOSTR4 is offline   Reply With QuoteReply With Quote
Old 02-13-2025, 09:56 PM #3
4RunnerAquasport's Avatar
4RunnerAquasport 4RunnerAquasport is offline
Real Name: Brett
4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of
Real Name: Brett
I have 4.56s with the 315s. I also have headers and Y pipe so my torque numbers are a little better than most. Pretty happy for the most part except the trans gearing is a little lacking in thick sand. So for that type of wheeling, 4.88s would make a difference.
Hwy cruise is 2300 to 2400 at 70 mph. Cruise control very rarely kicks down over bridges and mild inclines.
But, it sounds like you should go w 4.88s considering the GVW you'll be at on the scales. Because of a LT suspension, I'm at 5640 lbs with a light steel bumper only. Rolling mass makes a difference also, so try to find a light weight tire and wheel combo to go with.
Good Luck! Let us know how you make out.
1988 DLX 22RE AUTO BLACK-"Granny" - SOLD
2003 SR5 SPORT V8- Build- "Pearl" You Tube 2UZ 120
2012 LIMITED V6 "LE Mae" 5TH GEN BUILD THREAD
4RunnerAquasport is offline   Reply With QuoteReply With Quote
Old 02-14-2025, 10:58 AM #4
Bpzimm's Avatar
Bpzimm Bpzimm is offline
Bpzimm is on a distinguished road
Bpzimm's Avatar
I'm running 4.56s with 35's (11.5 skinnies) on my '06 v8 with a rear air locker, full steel front bumper (Shrockworks), full steel skids (Shrockworks), steel tube roof rack (similar to Gobi), dual battery system and a drawer system in the back and it's great! I've wheeled it in all types of terrain (rocks, sand, mud) and it's a tank. Cruises between 70-80 comfortably on the highway, although the 35s require a little more attentiveness. I also have a stainless snorkel, DT headers, DT y-pipe and Gibson cat back exhaust system so it flows pretty freely. Tows my 21' center console boat great around town too. No clue what it weighs, but I like the way it drives.
Bpzimm is offline   Reply With QuoteReply With Quote
Old 02-16-2025, 02:09 AM #5
I appreciate all of the feedback!
Old 02-16-2025, 07:56 AM #6
Real Name: Brett
Real Name: Brett
I bet it is a tank. Except for the secondary air system, I wish I had started w a newer model year. Your power numbers are much better than mine to start with. SS snorkel is cool idea as well.
The wider tires I run also take away from hwy performance and mileage. Skinnies are much better for all round performance, and easier to handle tight trail situations.
I'd be curious to know what your truck weighs. The truck stop CAT scales cost around $20. So I went ahead took it up there. I made sure to split the axles to know how my weight is distributed for spring and shock tuning.
Old 02-16-2025, 10:06 AM #7
Bpzimm's Avatar
Bpzimm's Avatar
Yeah I've had the the Slyfox SAIS bypass installed for a while, so no issues there. I may try and get it on a scale at some point. The stainless snorkel is a piece of art! Got it from Australia through Sloop imports, but I don't think they exist anymore. Didn't care for any of the plastic snorkels out that are available for our rigs.
Old 02-18-2025, 04:02 PM #8
alia176 alia176 is offline
alia176 has a spectacular aura about alia176 has a spectacular aura about
Also, do keep in mind the elevation where you play vs live! Normally aspirated engines struggle at times while playing at high elevations found in CO/UT/AZ/NM/etc. Our heavy rigs can benefit from staying in the power band while playing in the higher elevations, but if you live closer to sea level, then your RPMs are a tad higher, which of course impact your MPG. My V8 is a gas hog so probably doesn't matter to most of us what the MPG is but thought I'd throw the elevation thing out there!
From Google
On average, a normally aspirated (non-boosted) engine looses 3% of it's power for every 1,000' increase in density altitude.
2003 Sport V8 Icon 2" rear, Bilstein 6112 front with 700# king springs, Gibson cat back, Magnaflow cross pipe. OBA, DIY sliders, etc
1996 FZJ80 landcruiser with whole bunch of stuff, including a Turbo.
1997 4Runner SR5 - daughter's ride, slowly getting built up
alia176 is offline   Reply With QuoteReply With Quote
Old 02-19-2025, 04:17 PM #9
awhitney1 awhitney1 is offline
awhitney1 has a spectacular aura about awhitney1 has a spectacular aura about awhitney1 has a spectacular aura about
With all of that, I need to see some pics of this beast!
awhitney1 is offline   Reply With QuoteReply With Quote
Old 02-20-2025, 02:34 PM #10
From Google
Thanks for the input!
I live at sea level and the altitude where I play ranges from 1000-5000.
Old 02-21-2025, 12:50 PM #11
Inv4drZm's Avatar
Inv4drZm Inv4drZm is online now
Inv4drZm's Avatar
My rig has bigger tires than mentioned in this thread, 37" mud terrains, but I regeared to 4.88s with all the steel armor. vvti V8 and long tube headers.
Altitude and grade is a valid concern, when driving through Colorado, I have to floor it up the mountain and I can hardly keep up with traffic. In flat Kansas it's fine though lol.
2005 4R "The last of the V8s!" - TC +2 LT. - Lockers Front & Rear - 37's - Dana 60 - Build Thread
2005 Tundra 2WD Regular Cab 4.7L - Chopped Frame - Short Bed Swap - Lowered
2019 Tundra 4WD Double Cab 5.7L
Inv4drZm is online now   Reply With QuoteReply With Quote
Old 02-22-2025, 08:58 AM #12
Bpzimm's Avatar
Bpzimm's Avatar
Here you go! Kings on all 4 corners and bunch of other goodies!
Old 02-22-2025, 07:02 PM #13
Bpzimm's Avatar
Bpzimm's Avatar
Some more action shots:
4th , bumper , gen , live , regret
Regearing for 285/70/17s? TCT4Rillz 3rd gen T4Rs 27 05-25-2024 04:33 PM
Regearing With 35s Gavinstuckey 3rd gen T4Rs 3 09-26-2018 12:06 PM
Regearing With 35s Gavinstuckey 3rd gen T4Rs 9 08-30-2018 11:30 AM
Need help with regearing coltonbaxter31 3rd gen T4Rs 1 05-08-2016 01:54 PM
regearing... yotaman04 3rd gen T4Rs 2 03-24-2008 09:04 AM
