Old 02-14-2025, 10:41 AM #1
silverbullet07 silverbullet07 is offline
silverbullet07 is on a distinguished road
CV axles
I purchased CV axles from Napa April 2020 to replace my OEM ones due to the Boots splitting. The vehicle only saw maybe 20K miles from 2020-2024. I noticed the inside boot split at the band on both shafts.
I told them about it and they are replacing them under warranty. I was sit to do a bunch of maintenance to include new brake calibers and struts anyway, so not to much more to replace the CV shafts again.
silverbullet07 is offline   Reply With QuoteReply With Quote
Old 02-14-2025, 10:48 AM #2
88Center 88Center is offline
88Center is on a distinguished road
4Runner Archives - CVJ Axles
https://www.youtube.com/watch?v=YH5Cf7uJV5Y
88Center is offline   Reply With QuoteReply With Quote
Old 02-14-2025, 12:59 PM #3
Beachbums Beachbums is offline
Beachbums is on a distinguished road
I was a true believer and sprung for rebuild kits from Toyota that included grease, two types, clamps, and a boot. Check wheel bearing and transmission seals, and wheel bearings while there. On our 07 did one five years ago, and one last summer. I had the tools for the clamps so why not.
Beachbums is offline   Reply With QuoteReply With Quote
Old 02-14-2025, 03:35 PM #4
Thanks. I did install new hubs when I put in the new CV axles in 2020. I'll take a look at them to make sure everything still looks ok. I have quite a large list to do. Hope we can have some warmer weather soon to get the garage warm.
Old 02-18-2025, 10:13 PM #5
spearminthat spearminthat is offline
spearminthat is on a distinguished road
Originally Posted by silverbullet07 View Post
I purchased CV axles from Napa April 2020 to replace my Sprunki Game OEM ones due to the Boots splitting. The vehicle only saw maybe 20K miles from 2020-2024. I noticed the inside boot split at the band on both shafts.
Really need to check and service the car to determine where to replace. Your sharing is really great.
spearminthat is offline   Reply With QuoteReply With Quote
Old 02-19-2025, 02:24 PM #6
SF03runner SF03runner is offline
SF03runner is on a distinguished road
I rebuilt mine with the toyota kit and used metal worm drive clamps vs. the toyota zip tie things.
SF03runner is offline   Reply With QuoteReply With Quote
Old 03-31-2025, 09:45 AM #7
waypoint's Avatar
waypoint waypoint is offline
waypoint has a spectacular aura about waypoint has a spectacular aura about waypoint has a spectacular aura about
waypoint's Avatar
Aftermarket CV axles (not including CVJ) typically use rubber boots on both joints, unlike Toyota which uses a plastic/nylon boot on the hub end which rarely fails.
If your inboard boot is failing at low mileage, check your ride height and the angle of the axle shaft as it leaves the inboard tulip joint. In my case, the front springs had sagged quite a bit and the axle shaft was angled upward enough to cause the inboard boot ribs to rub against each other. Replacing the springs (and strut cartridges) brought the axle shaft back to near straight between the tulip joint and hub...no more failed inner boots.
waypoint is offline   Reply With QuoteReply With Quote
axles , replace , replacing , shafts , warranty
CV Axles Jackkill1 4th Gen T4Rs 5 02-27-2018 08:40 PM
CV Axles Tooltime19 4th Gen T4Rs 20 09-07-2016 12:41 PM
Cv axles 4runninxit4 3rd gen T4Rs 10 09-17-2015 11:15 PM
CV axles buccaneerbandit 3rd gen T4Rs 13 01-12-2015 12:42 PM
cv axles dudes4runner Southwest 1 08-15-2014 08:52 AM
