Old 03-12-2025, 05:23 PM #1
GoodieKev GoodieKev is offline
GoodieKev is on a distinguished road
Brake Light Mystery
Hello all,
I have a condition with my brake lights that's got me puzzled.
For starters, 2003 SR5 V8. They are LED in non OEM housings. Have worked flawlessly until about a month ago.
The first thing I noticed was the dash lights coming on when the brake pedal is pressed. Then, I found that even though the brake lights work when the pedal is pressed, when the headlights are on, there is no change in illumination on the tail lights.
Next, I found that my CHMSL was burned out. So, I replaced it.
Same thing going on with dash lights and tail lights not changing with headlights on. I'm headed back to auto parts store to buy standard bulbs and replacement fuses.
Fuses look fine visually. Going to start checking and replacing.
TIA for any thoughts and insights while I go down the list of possible solutions.
KG
GoodieKev is offline   Reply With QuoteReply With Quote
Old 03-12-2025, 08:25 PM #2
Solved.
P21/5W LED bulbs are interchangable with standard 7528.
Swapped out. Problem solved.
brake , fuses , lights , pedal , thing
2021 4Runner Brake mystery Corky 5th gen T4Rs 5 12-14-2023 10:15 AM
Having the long brake pedal travel/low brake pedal mystery problem Dragon_EX 3rd gen T4Rs 16 05-19-2021 10:58 AM
Is the rear Brake light above the lift gate the same as the brake light on the spoile bassmacka 4th Gen T4Rs 2 10-13-2017 10:20 PM
Mystery Light gaterose 4th Gen T4Rs 4 05-17-2013 08:10 AM
