03-26-2013, 04:36 PM
#151
Real Name: Jesse
Real Name: Jesse
Originally Posted by SnoboardingDave
Is there any way to tell if you're front sway bar bushings are worn? Mine is making a clunking noise when I go over hard bumps. Doesn't sound like metal on metal either & the truck steal feels relatively tight. I'll probably switch them anyway as mine is an 05 V8 w/ 86,000 miles.
Mine make a clunking noise when I don't grease them regularly. When I took my old ones out they were cracked and obviously very dry.
The glass isn't half empty. It's just twice as big as it needs to be. SILVER 2004 LIMITED V8 4X4, GIBSON CAT BACK, AFE PRO DRY, FJ COILS, BILSTEIN 5100's, REAR DAYSTAR 1.5, 265/70/17 TOYO A/T II, CENTER CONSOLE ORGANIZER MOD, INTERIOR/EXTERIOR LED MOD--*NEW* 1987 SR5 PROJECT
04-08-2013, 10:52 AM
#152
Replaced the sway bar bushings over the weekend & now all is well (& quiet).
05 V8 SR5 4WD - Galactic Gray
04-16-2013, 02:44 AM
#153
I just ordered front and rear sets from Energy and fronts 29mm fit perfect, but the rears 17mm are way too small! Everything I've seen online says the rear sway bar for an '05 sport 4wd is 17mm but mine is quite a bit bigger. Any help?
2005 4.7L V8 Sport--2013 FJ TT springs & Bilstein 5100's; 2" Supreme Suspensions front spacer; Toytec diff drop kit; 255/75R17 BFG Mud-Terrains; FJ 17" wheels p/c black; Rocky Road supersliders; Man-a-fre/4-Plus skid; Full LED int; Full set WeatherTech mats; DDM Tuning 35w 6000k low HIDs & 55w 6000k high HIDs; Nokya 2500k yellow fogs/signals-DRLs/markers; Hella 700ff driving (500ff fogs soon); IPCW LED taillights; Volant intake; Taylor TB spacer; Unichip ECU upgrade; Fitch fuel catalyst; Flowmaster cats; Flowmaster super 44 off-road muffler; 4-wheel Powerstop kit; De-badged; Intake scoop mod; Angle cut front bumper mod; TRD decals & valve caps; etc.
04-16-2013, 07:29 AM
#154
I can't find my notes, but I recall that the rear sway bar is about the same as the front (2004 V8 4x4 Sport).
04-16-2013, 09:23 AM
#155
Real Name: Matt
Real Name: Matt
I did the same thing and ordered a 17mm with the same results. Try the 21MM. I got the prothane kit #19-1164-BL. Comes with zerk fittings.
I also have a 2005 Sport V8
04-16-2013, 11:23 AM
#156
Yes sir ran into same problem on mine , got 1 on but the 1 on drivers side , lotta MF-ing , so no go , went on to summit & ordered 19mm should be here next cpl days will report !
2011 SR5 Mgm 4x4 alpharex pro headlights & depo black tail lights level 8 trackers wheels & p285/70/17 cooper at3s, 6112s all around set 2.5 rear rancho spacer 11/4, FJ coils TRD intake.w/afe-dry filter Urd y-pipe flowmaster super70ii TE roofrails! 2014 Sr5 Superwhite Bils 6112s/eibach 2.5 /1 "rear springs 285s Cooper at3 ms on fj pc-d satin black, Urd y-pipe/Flow delta 50 muffler/all interior led lights & low beams sealights h7 led with laminx yellow fogs & oldreds puddle harness w/2010-13 mirrors
10-24-2013, 01:06 PM
#157
07 Limited (V6) 30 mm front and 19 mm rear
05 Sport (V6) 30 mm front and 21 mm rear
Current: 17' GX460 Luxury with DSP, Nightfall Mica / Black
Sold: 05' 4R Sport v6, 07 4R Limited v6
Reason: correction
10-25-2013, 12:28 AM
#158
Yep my rear sway was def 19mm !
01-05-2014, 12:39 PM
#159
don't want to start a new thread...
reviving this one for a simple question (too cold to go outside right now and look on my runner). I read this entire thread and saw about larger washers being recommended, thank you.
I'd like to replace the factory bushing bracket bolts, Front and Rear.
Can anyone confirm the sway bar bushing bolt size is 8 x 1.25? same as the 3rd Gen writeup
@ J.A.
performed here: Toyota 4Runner Handling Modifications Addco Sway Roll Bars
What length are the stock bolts if they are 8 x 1.25 as well? I want to replace the oem bolts with some Gr8 or SS hardware while doing this mod once the weather warms up. Thank you.
01-06-2014, 02:54 PM
#160
really? 11 pages of people installing these poly sway bar bushings and no one knows the size of the bolts that hold on the bushing brackets?
01-06-2014, 03:06 PM
#161
When you replace something on your truck, do you usually take off all the bolts, measure the thread pitch and length for no apparent reason, and then re-install the bolts? Didn't think so, lol
Why don't you just go pull one out of your truck and measure it, it would be a lot more accurate and probably faster than sitting around waiting for someone to tell you.
BTW, no such thing as grade 8 metric bolts, you're looking for grade 10.9. And also don't bother with consumer grade SS bolts, they are almost never pressure rated and much weaker than 10.9 bolts. Definitely don't want that anywhere near load bearing components
01-06-2014, 05:28 PM
#162
Actually I do measure each bolt.
It's below zero outside, I have no garage, I work all day and I'll be damn if I'm going to lay on the frozen ground in the dark with 30mph winds trying to remove a stupid bolt. It's not that important, just figured I could make my lunch break useful by buying some parts I know I'll need once the weather warms up and I install the bushings. (eg. figured the forum could help save me a step by sharing information... that is the point of this forum, isnt' it?.... )
you're correct on the grade. meant to type GR8 equivalent... was working on my Harley so had imperial units in my head....
01-06-2014, 07:12 PM
#163
@ J.A.
The fronts are M8x1.25, not sure if the rears are the same. Took me a few trips to OSH because the bolts wouldn't thread into the M8x1.25 test thing they had, only the M8x1.50, kept confusing me, but eventually figured it out.
WishIWentLongTravel 2006 V6 - Icon extended travel coilovers w/ resi, Total Chaos UCA, Wheelers Super bump's, Metal Tech "LT" w/ Icon VS 2, Metal Tech lower links, JBA Long Tube Headers, Dirtydeeds exhaust, Gunmetal Konig Countersteer X, B.A.M.F LCA Skids
01-06-2014, 08:18 PM
#164
Thank you for sharing this information. So the front bolts are 8 x 1.25 and the rears are 8 x 1.25 also or 1.50 or you can not remember on the rears?
01-15-2014, 03:45 PM
#165
I am thinking about doing this mod, but had some questions on replacing the rear endlinks.
1. When replacing, do you leave the rear swaybar in place?
2. Do you have to unbolt the top nut, then pull the rod out in order to get to the bushings to replace them, and if so, do you have any tips or tricks on how to do this?
3. Do you keep your 4runner on the ground to change these, or do the wheels need to be off the ground?
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
