01-26-2008, 09:24 PM
Spidertrax On Stock 4R
Hey all.
Just received my 1 1/4" Spidertrax spacers and want to put them on now. I will be installing an OME lift in the next month or so, waiting for the weather to get a little better.
If I install them now will I get rubbing? It's really not a big deal, I'll just wait for the lift if it's going to rub.
On another note, what is the best way to torque them and keep the hub from moving?
2005 4X4 V8 LTD 4Runner Black
Driver's side upper assist handle, tail/stop bumper light mod, Flowmaster 50 suv with side exit exhaust and Valor tip, 20% tint on fronts and 27% add'l tint on rear window, DIY blacked-out headlights, Stainless door sills, VIP Plus w/GBS alarm, OBX pedals, Can. hood protector, ash tray kit, '06 LED tails, T&H Euro bar, OME lift, Spidertrax spacers, LT275/70R17 Cooper AT3s, HIR bulbs in LB and fogs, VSC mod, AFE Pro Dry S filter, White LED cluster and HVAC
01-27-2008, 01:29 AM
Slight rub at full-lock on my '06 LTD with original wheels and tires. YMMV
01-27-2008, 08:48 AM
You have to have someone apply the brakes while you torque them down. It even says that in the Spidertrax directions so I don't really think there is a better way.
1998 Toyota 4Runner Limited
1A5 V6 3.4l 4x4 w/ RR DIFF LOCK
Exterior: TRD Tacoma wheels painted black, Spidertrax spacers, 20% Tint, Coleman Safari Rack, clear corner lenses, custom dents
Interior: Alpine CDA-9883, Polk MOMO 6.5", Infinity Reference 5.25", Memphis 16-STT150 2 channel amp, custom mud
Offroad: OME 3" lift (881/890), 1" diff. drop from Toytec, Tacoma whip antenna, extended rear diff breather, gray wire mod, 285/75/16 BFG KM2s
01-27-2008, 03:00 PM
Super Moderator
Super Moderator
Lock the center diff in low range. With the vehicle in park, assuming you do 1 wheel at a time, you should be able to tighten it up...
Chris
07 Salsa SR5, 4wd Cyclone pre-cleaner , Aux Transmission Cooler, Hidden Hitch 70779 (600/6000lbs, WDH=730/7300lbs), AirLift 1000, FJCruiser front springs (& now rear too!), Axle Vent Mod, Swaybar Bushing Upgrade, V6 Tick Reduction, VSC off mod, Maplight Mod, 255/75/17 Goodyear Wrangler SAs, Tailpipe Mod
01-27-2008, 03:13 PM
Super Moderator
Super Moderator
I understand wheel spacers in the context of lifts, non-stock rim fitment etc. What advantage are they for an otherwise stock vehicle? I can guess it may handle/ride a touch better due to the 2.5 inch wider track. I can also see how tie-rods and ball-joints could be stressed more than usual. Do the benefits outweigh the downsides? Do spacers equate to front end components lasting 60k instead of 120k?
Thanks for any input
And RedRacer, do you have any lift of any kind? I got the stock rim/tire size part.
Chris
01-27-2008, 03:20 PM
OK, good info, thanks.
Haven't opened them up yet so couldn't look at directions. Just trying to do some pre-planning.
Both approaches seem to make sense though.
01-27-2008, 03:30 PM
Personally that is a definite worry of mine. But lots of others run wheel spacers or wheels that have about the same offset and I really haven't seen any threads/posts of premature wear of bearings, ball joints or tie rod ends.
Probably not what you're looking for, but only time will tell.
Perhaps someone that has been running spacers or offset wheels for some time could reply.
