that link you provided only applies to the 3.4L and will not work withe the 4.0L that you have in your 4runner.
as for other mfg filters, I would not recommend anything else but True Flow. They are by far the best solution available outside of the factory filter and is actually better both in filtering out gunk and giving you better performance.
Hell if you need to replace your stock filter, I would not recommend getting another stock filter but rather push the True Flow so that says a lot (well at least for me).
Northridge Toyota sells True Flow so if you're interested check them out (call em).
Link here
Good luck
