03-08-2008, 05:13 PM
Hidden Hitch vs Factory Installed Hitch, what's the diff?
Hey Folks,
Is there a difference between a hidden hitch and the factory installed hitch on our 4runners?
Someone told me the hidden Hitch was better? I Don't really see how.
2007 4runner Sport Edition V6, Black.
2011 BMW 335Xi Special Edition, Jerez Black.
03-08-2008, 05:47 PM
I cant really address the factory hitch as I have the Hidden Hitch 70411. It is my understanding that the factory V6 hitch only bolts to the left and right frame members. I further understand that the factory V8 hitch mounts to these members as well as the center member. The 70411 bolts to all three members and provides a higher rating, I believe. Hope this helps.
2006 SR5 White / Tan V6
Cooper Discoverer ATR, Wagner Thermo-Quiet Brake Pads, Hidden Hitch #70411
03-08-2008, 06:02 PM
Super Moderator
Super Moderator
Re: Hidden Hitch vs Factory Installed Hitch, what's the diff?
Originally posted by morphius909
Hey Folks,
http://www.toyota-4runner.org/showth...threadid=35954
Here's some hitch stuff that you may not look at if you searched based on the title.
One advantage of the HiddenHitch, IMHO, is that if rear ended by a low bumper car it may help a bit...
I think either one is good and it's a matter of preference.
Chris
07 Salsa SR5, 4wd Cyclone pre-cleaner , Aux Transmission Cooler, Hidden Hitch 70779 (600/6000lbs, WDH=730/7300lbs), AirLift 1000, FJCruiser front springs (& now rear too!), Axle Vent Mod, Swaybar Bushing Upgrade, V6 Tick Reduction, VSC off mod, Maplight Mod, 255/75/17 Goodyear Wrangler SAs, Tailpipe Mod
03-09-2008, 03:46 PM
Just wish that Hidden Hitch still made the 70411. Can't seem to locate one anywhere.
I can Explain it to you, I can't Understand it for you.
'08 Tundra SR5 5.7 V8 Double Cab, White, Equalizer WD system, '91 Coachmen Catalina 260FK, '89 Grumman GSS w/35HP Force O/B, 8' Snowbear utility trailer, 2012 Polaris 500HO LE in Camo, 7 x 14 TWF Landscape trailer w/2 ramps.
03-09-2008, 06:41 PM
Super Moderator
Super Moderator
My 70779 purchased in Oct '07 carries a sticker that says 600/6000lbs (dead weight) and 7300 w/wdh. http://www.toyota-4runner.org/showth...threadid=35954
Chris
03-11-2008, 12:16 AM
Super Moderator
Super Moderator
The factory V6 hitch is mounted to the rear most cross member only. HiddenHitch 70411 (now discontinued) and 70779 both mount to frame rails, similar to the factory V8 hitch. The 70411 also has a mounting point for in the center of the rear most cross member. I probably won't tow anything. I added the hitch so I can mount accessories to it (bike and/or ski/snowboard rack).
'06 Limited V6
Amy's Mom: "Who's that you're talking to?"
Amy: "It's Uneek, spelled in a 'unique' way."
