Old 03-28-2008, 02:13 PM #1
tonlun tonlun is offline
tonlun is an unknown quantity at this point
Question RE: Engine Noise, Ticking
I have a 2000 4Runner with 2.7L engine. It has 135K miles on it and lately it has a ticking noise on the engine. I took it for smog check, which it passed, and the mechanic said that the ticking sound is most likely the timing chain. Well, 1 month later, I changed the timing chain along with water pump and thermostat. The ticking sound is still there. It seems like it is coming from the exhaust side of the head of the engine. I adjusted the gaps on the valves about 3 months ago.
What do you think could be causing this loud ticking sound? I am thinking that the valve springs are getting weak? BTY, the pressure on the cylinders are 200 psi +/-10.
Thanks.
tonlun is offline   Reply With QuoteReply With Quote
Old 03-28-2008, 04:06 PM #2
onemoreokie onemoreokie is offline
onemoreokie is on a distinguished road
I'd bet the farm the exhaust header is leaking. This is a well known problem with the 2.7L. Check out the tacomaterritory forums for tons of info.
onemoreokie is offline   Reply With QuoteReply With Quote
Synthetic Engine Oil Thai Maintenance/Detailing 114 02-18-2023 01:39 PM
Ticking noise from the rear fitzt4r Problems & Warranty Issues 5 02-06-2008 07:01 AM
Whistling Noise In Engine vrbango Problems & Warranty Issues 1 04-29-2006 04:39 PM
wierd ticking noise after turning off engine 4RunnerLaker Problems & Warranty Issues 10 09-08-2005 12:47 PM
