01-12-2019, 06:58 PM
#1171
Originally Posted by T?@\7
Im curious as to how high some of your mileages are, 03 and up!
I just read about an 03 w/ 140k (2k34R), which is healthy!
07 with 159k on the clock. Still running strong!
01-12-2019, 10:27 PM
#1172
Originally Posted by blackjackck
Yeah my Runner has 130K and there's ticking noise when idle so it that the exhaust manifold issue?
Easiest way to tell imo is driving next to walls and slowly give it gas so it has a load on the engine, you'll hear it instantly.
05 v8 just rolled over 197k
01-14-2019, 10:55 PM
#1173
2005 4Runner sport
My daughter just purchased one. It has 156k miles on it and just found out it may have an exhaust leak manifold issue or heat shield may need fixing. Wont know until this Friday when they get under it. We also found out that it has a wiring bypass for some common ac issue. So it results in lower air pressure to the vehicle occupants even on full blast. It also may need a starter? No issue yet but my daughter heard some weird noise And delay when starting thebkther day. It almost feels like driving a used vehicle off the lot and it malfunctioning right away. Just don’t know if we should fix basic stuff now then sell or if this is normal for year make and mileage. Anyhow my question is this a bad year or model for the 4Runner? It seemed to b taken care of but my Toyota experience is limited. My husband had a Tacoma we bought with 130k miles. Ran hard every day til 190k miles. Zero issue. He got in an accident. Only reason we don’t still have it. Only major thing was cv joints. Just did basic maintenance. Anyhow this was a 1.5hr distance purchase and just not sure if this is normal ware and tare. Help. It’s my daughters first vehicle. She used all of her money.
01-15-2019, 03:00 PM
#1174
Real Name: John
Real Name: John
I know I've encountered the Heat Shield coming lose on 2 different occasions. The bolts and nuts holding them tight were rusted out so there was a constant knocking or metal hitting metal rattling, that was an easy fix. My faint ticking from the engine while being idle is something I'll need to keep an ear out for. I've had some leaking in the cv boot and my front brake calipers seized. I've owned it since 70K and that's what I've had to replace. From what I've researched my 08' should run pass 300K miles but obviously things will get worn and need replacing. But the expecting my engine, tranny, transfer case to be strong and long lasting.
2008 V6 4x4 Sports Edition / Build Thread/ FJ Off Road Package, 265/70/17, 2012 FJ Wheels, Husky Liner, LED bulbs, Spare Bumper -current////// SOLD Past vehicles:1996 V8 Landcruiser Rebuilt; 1988 Jeep Wrangler- 2 inch lift with 33' tires; 1976 Jeep CJ 7 (inline 6) - Frame off restoration
01-15-2019, 03:09 PM
#1175
HA!
I can't remember if I posted on this thread or not.
(and I aint going thru all 75 pages to find out)
2004 SR5 V6...
had 195k when I bought it in 2015....
just passed 266,000!
01-15-2019, 03:40 PM
#1176
Real Name: Kevin
Real Name: Kevin
Yeah, I had a dustshield rattle...I removed it and now it doesn't rattle anymore!
These engines also just like to tick. You can read up on it on here if you'd like, but it's not normally something that needs to be worried about. IIRC the V8 was the one that had exhaust manifold issues.
'04 4Runner - Build Thread | '05 CBR 600RR & 1000RR - The slow vehicles ;)
01-16-2019, 01:28 AM
#1177
Looking for a 4gen 2004. used im seeing alot for sale with a lot of miles on it, what have you done to your car maintenance wise with all these miles?
01-16-2019, 09:11 AM
#1178
Real Name: Kevin
Real Name: Kevin
The biggest issues with these seems to be seizing brake calipers. Some early 4th gen V6's (pre-'05) had headgasket issues.
Mine's at 185k and the list of replaced parts (apart from things like brake pads, spark plugs, and tires) is: - Balljoints (I just replaced all front control arms for the sake of having everything new and to get adjustable uppers for my lift)
- FR wheel bearing
- FL RL brake calipers
- Radiator
- CV axles
- Shocks (I debate whether or not they were actually bad, cuz they weren't leaking and felt fine. But a shop failed them during inspection so I had no choice but to replace)
Not bad for a truck with that many miles. I'm sure most of those items wouldn't have failed yet, either, if I didn't beat the hell out of it offroad.
01-23-2019, 11:50 PM
#1179
291,000 and change in my 06 V8 Limited, still going strong - bought from the original owner in AZ (rust free) with all records - only 2 timing services thus far.
New Daily Driver - 2006 4runner Limited Galactic Grey V8 4x4 -291K miles and counting - STOCK Driveline - New Audio Setup.
2007 Lexus GX470 - Stock, 56K miles - Sold
2004 Black Sport V8 4x4 - Made Limited- 141k miles Sold
2003 Grey Sport V8 4x4 - Sold - 1st 2UZ owned
Reason: Added ODO Pic
01-25-2019, 08:36 AM
#1180
Real Name: Kevin
Real Name: Kevin
Assuming the other services were done at 90 and 180k miles, I'd do another timing belt job if I were you. That's not something you wanna let go longer than you should.
01-25-2019, 10:22 AM
#1181
Yea, I hear ya,it's my 4th 2UZ. Did the air injection pump bybass from slyfox, but, I think it's like having kids.....after the 3rd timing service on "new-2-you" rigs seeing perfect belts with all teeth, no damage or cracks, you're like....meh.
01-25-2019, 06:50 PM
#1182
Hi all, 1st post!!!!
Just purchased an 03 V8 limited 4x4 with 180000miles lol....
WOO HOO>>>>
I'm not afraid off miles............
01-25-2019, 11:22 PM
#1183
'03 V8 2x4 194000; Still going strong!!
01-26-2019, 12:34 AM
#1184
Just bought mine, 2005 V6 4.0 Sport with 140k.
As my first real car, the mileage scared me a little, but everything checked out except for minor quirks that are bound to happen with a 14 year old vehicle.
01-26-2019, 06:48 PM
#1185
399,500 on 2007 SR5 2wd, rides and drives better than my 3rd gen that has 223,000.
