Old 05-07-2004, 11:55 PM #1
Mark86's Avatar
Mark86 Mark86 is offline
Super Moderator
Mark86 is on a distinguished road
Super Moderator
Mark86's Avatar
Roofrack Help
I was trying to move my crossbars on the roofrack today and I was not able to losen all of the screws by hand. I was able to losen 4 out of the 8 screws by hand. How do you unscew the crossbars on the 4th gen roofracks? What tool can I use that would not scratch anything? I tried very hard by hand but it just kept ripping my finger apart. Thanks!
Mark
2005 4Runner Limited 4X4 V8 since 6/15/05 Titanium Silver with Grey Leather
Nav, XREAS, Adjustable Ride Height, Sunroof, Side Curtain Airbags, Rear Spoiler, Double Deck Cargo, Chrome Exhuast Tip, Bug Shield, All Weather Mats, Driver Side Assist Handle, Audiovox Remote Starter, 2006 Skid Plate, LED lighting- interior and running boards, USA-Spec PA-15
Click For Pictures of My Current 2005 Limited, Detailed LED Conversion Instructions, Click For Pictures of My Retired 2003 Sport
Mark86 is offline   Reply With QuoteReply With Quote
Old 05-08-2004, 07:15 AM #2
lojeff's Avatar
lojeff lojeff is offline
lojeff is an unknown quantity at this point
lojeff's Avatar
Are you trying to remove them or just move them? If you are only moving them, no screws need to be removed, just loosen (by hand) the 4 black plastic wing-nuts on each cross bar.
2004 Black V8 4WD Sport Edition
Camry Navigation
Homelink
All Weather Mats
Bug Deflector
Yakima Ski Rack
Driver Side Handle
Footwell lighting
CO2 PowerTank
Red Bumper Lens Mod
Weathertech cargo mat
lojeff is offline   Reply With QuoteReply With Quote
Old 05-08-2004, 11:31 AM #3
Mark86's Avatar
Super Moderator
Super Moderator
Mark86's Avatar
I am trying to move them. A couple of the wingnuts seems to be stuck and will not move. I have gotten some to losen, but around two will not budge.
Mark
Old 05-08-2004, 01:08 PM #4
lojeff's Avatar
lojeff's Avatar
Mine certainly are not that tight. Maybe you could try placing the tip of a screwdriver on the edge of the wingnut and gently tap the screwdriver with a hammer to see if that will loosen it.
Sorry I can add anything else.
Camry Navigation
Homelink
All Weather Mats
Bug Deflector
Yakima Ski Rack
Driver Side Handle
Footwell lighting
CO2 PowerTank
Red Bumper Lens Mod
Old 05-08-2004, 05:46 PM #5
loyd's Avatar
loyd loyd is offline
loyd is on a distinguished road
loyd's Avatar
i had same problem....i used a set of vice grips, but wrapped the wing nuts with a cloth first to avoid scratching...i just clamped on to two of the wings with the grips, and gently nudged it until they came loose.
03 4Runner Limited V8 AWD
Sport Hood Scoop
Hood Protector
Yakima Rack System
Westin Safari Light Bar - Color Keyed
Husky Liners and Cargo Mat
DVD Player
Iforce Emblem
Valor Exhaust Tip
OBX Racing Pedals
Chrome Grill Inserts
Tint
Wishlist - BFG A/T KO's
2000 4Runner LIMITED - White
Husky Liners
Husky Cargo mat
Sunroof/Hood Deflector
1997 Harley Davidson FLSTS
loyd is offline   Reply With QuoteReply With Quote
Old 05-08-2004, 06:47 PM #6
TroutFlyFisher TroutFlyFisher is offline
TroutFlyFisher is an unknown quantity at this point
Taking this one step further....
I will be wanting to remove the crossbars on the roof rack to install a Thule rack system - how does one go about removing the cross bars alltogether???
TroutFlyFisher is offline   Reply With QuoteReply With Quote
Old 05-08-2004, 09:09 PM #7
leftyrb leftyrb is offline
leftyrb is an unknown quantity at this point
If the Thule rack is like the Yakima, where it clamps over the factory rack and the rack mounts pull inward, I would not remove the factory cross bars and they reduce or remove the side pressure exerted from the aftermarket rack. You might want to seek advise from Thule.
2005 Limited V8 Pacific Blue
leftyrb is offline   Reply With QuoteReply With Quote
Old 05-09-2004, 08:57 AM #8
ckon's Avatar
ckon ckon is offline
ckon is on a distinguished road
ckon's Avatar
As you can see above, I have a Thule rack. With the factory crossbars still in place things were a little crowded up there so I removed them to decrease windnoise and allow access to the roof for cleaning, etc. The rack remains solid and the roof is much more accessable.
To remove the crossbars, one pair of the end caps need to be removed. It's not hard, but it's a little scary because they fit so tight that it's possible to mar or break them. I had one of the mechanics at my dealer show me how to do it and he chipped the first one before he got it loose - (yes, they ordered me another one )
There are four lugs on the bottom flange of the endcap, two on the inside and two on the outside, that engage with the mounting plate that's bolted to the roof. Spreading the bottom of the cap, starting at the end that straddles the bar, will release them, but they do fit tight! When all four have been released the end of the cap can be raised and now you'll find that the end that is over the bar is clipped in a hole through the bar. By rotating the end of the cap upward the clip will release.
Once the caps are off, there are pieces of rubber that slide out of the grooves in the rails and the crossbars will slide out. Then just replace the rubber strips ans pop the caps in place and you're good to go!
Good luck and let me know if there's anything I didn't cover.
Chuck
Six 4Runners, Five Generations: http://ckon.zenfolio.com/p185579878
Silver 2018 TRDORP w/ KDSS, tint, hard-wired radar detecter, 285/70-17 Nitto Grapplers, Plasti-Dip, interior LEDs, XenonDepot, Salex, RCI, Sprint Booster, Bilstein, Morimoto fog lights, Subaru Kicker dash tweeters
ckon is offline   Reply With QuoteReply With Quote
Old 05-09-2004, 01:03 PM #9
yabedude's Avatar
yabedude yabedude is offline
yabedude is on a distinguished road
yabedude's Avatar
Just yesterday I had to loosten a few stuck ones ... I used a rag to cover the plastic handles and a large pair of adjustible pliers like this.
Good luck.
Roofrack Help-adjustablepliers-jpg
yabedude is offline   Reply With QuoteReply With Quote
Old 05-09-2004, 07:33 PM #10
Mark86's Avatar
Super Moderator
Super Moderator
Mark86's Avatar
Update
Today I had time to work on my roofrack. My first try in loosening the wingnuts was to use the rubber grip that is used to open jars and try turning the wingnut using that. To my surprise, it worked like a gem. I was planning on spending at least 20 minutes trying to figure out a way to loosen these things. I just put the rubber grip around the wingnut, and it went. I did not even have to muscle it. It took so quick that I had time to get all of the glue stains off of my roof. For some reason, when the dealer prepped my truck, they totally forgot about removing the lines of glue on the roof.
Mark
Old 05-09-2004, 07:40 PM #11
ckon's Avatar
ckon's Avatar
Re: Update
Originally posted by Mark86
My first try in loosening the wingnuts was to use the rubber grip that is used to open jars........
Good thinkin'
Chuck
Old 05-09-2004, 08:37 PM #12
emtp579 emtp579 is offline
emtp579 is an unknown quantity at this point
Roof Rach
I used the rubber grips that are used to open jars too when I needed to move my rack in March. Works like a charm!
Dan
Dan
2003 4Runner V6 Limited Galactic Grey
Everything but navigation!
emtp579 is offline   Reply With QuoteReply With Quote
Old 05-12-2004, 08:27 PM #13
riverwolf riverwolf is offline
riverwolf is on a distinguished road
perfect removal tool?
I would add to ckon's removal info what I think is an ideal removal tool. Metal vegetable skewers. They're long, thin, and strong enough to do the job. My thinnest screw driver still seemed too thick and in danger of cracking the rail cap.
I took off the rear caps to remove my cross bars. I worked one skewer down the outside (closest to you) base of the cap. Once you get it worked to the end, pry back and forth a bit to feel both tabs pop loose. Leaving that skewer in place, I worked a second one down the inside edge of the cap. I was only able to get the first tab to pop out here. Work the cap a bit so that the outside edge rises up a bit so it can't reengage it's slots. Remove the oustide skewer. Next takes a bit of force...working upwards and inwards to try to pop that last inside tab. Remember there's also a tab from the cap into the rail itself, so you want to pivot around the rail.
For my troubles, the first cap came off clean, but bloodied my nose...yes I was leaning over my work. The second, I broke the top rail tab off the cap. Both caps snapped back on fine, but they're a bit looser than they were before. Right now, I don't think it'll be a problem.
My dealer was useless. I asked if they could show me the roof rack installation manual so I could get a better idea of how to remove the end caps. Claimed there wasn't one. Funny, the roof rack is listed as accessory for those that didn't get one factory installed. Surely there must be an installation manual.
Brent
riverwolf is offline   Reply With QuoteReply With Quote
Old 01-20-2008, 11:13 AM #14
Shimajilosan Shimajilosan is offline
Shimajilosan is on a distinguished road
Question
Got it....I did break the inside rear anchor of each end cap, but the crossrails slipped right out. The end caps still fit fine, but I'll order new ones.
I am trying to remove my cross rails on my 2006, and am having trouble following the directions here (I'm installing a JAOS basket and leaving the factory cross rails in place leaves it really busy with lots of wind noise).
Does the below apply to the 4th gen, or are there directions for that?
TIA
Al
Shimajilosan is offline   Reply With QuoteReply With Quote
Old 11-04-2010, 01:23 PM #15
robertofran3 robertofran3 is offline
robertofran3 is on a distinguished road
Brent
Thanks Brent and CKON, i'm going to try this tonight and see how it works. I rob
robertofran3 is offline   Reply With QuoteReply With Quote
First Casulty of our trip!! Roofrack Weatherstripping! morphius909 Off Topic 9 02-03-2017 08:58 PM
2nd gen roofrack? Bens4runner Engines / Suspension / Wheels / Tires / Audio / Accessories 0 09-03-2010 01:38 AM
Snowboards - 1, Roofrack - 0 Magnum 3rd gen T4Rs 9 12-14-2009 01:24 PM
Wanted: Yakima Roofrack & Manik Brushguard bamatradition22 Classifieds - buy & sell (no commercial ads please) 1 12-11-2006 12:40 AM
Roofrack Needed aperionvi Engines / Suspension / Wheels / Tires / Audio / Accessories 0 03-16-2004 01:50 AM
