Old 05-11-2004, 11:41 PM #1
jclark jclark is offline
jclark is an unknown quantity at this point
Break Controller
has anyone installed a brake controller in their 4runner? Where abouts did you put it if so
jclark is offline   Reply With QuoteReply With Quote
Old 05-12-2004, 12:43 AM #2
Brewster Brewster is offline
Brewster is an unknown quantity at this point
I didn't "install" mine. I had a long cable put on. When I need it, which is not often, I open the bin door at the foot of the console, put the controller in the gap between door and console, and route the cable over the steeing wheel to the connector under the dash by the parking brake. If you do a search of this site, you should find at least one example of an actual permanent mounting. I need all the knee room I can get, so I didn't put in under the dash as I would normally do.
Brewster
2004 white 4WD limited V8
Brewster is offline   Reply With QuoteReply With Quote
Old 05-12-2004, 01:17 AM #3
leftyrb leftyrb is offline
leftyrb is an unknown quantity at this point
Mr. Clark:
I installed a Jordan Ultima in my 4Runner, it is compact in size, can be removed easily and is a proportional braking device, works also in reverse. I installed it on the right side of the lower dash. I will try to take a photo tomorrow.
I recommend the Jordan, very simple to install.
Let me know if you need further information.
2005 Limited V8 Pacific Blue
leftyrb is offline   Reply With QuoteReply With Quote
Old 05-12-2004, 08:53 AM #4
A picture would be great, I did a search and didnt find any threads about an install to be honest. I already bought a prodigy, which are supposed to be very good as well.
Old 05-12-2004, 09:16 AM #5
sharp4runr's Avatar
sharp4runr sharp4runr is offline
sharp4runr is on a distinguished road
sharp4runr's Avatar
OK, I'm a dork. What's the purpose of this? Is it mainly for off-roading purposes?
sharp4runr is offline   Reply With QuoteReply With Quote
Old 05-12-2004, 10:16 AM #6
SteveM's Avatar
SteveM SteveM is offline
SteveM is an unknown quantity at this point
SteveM's Avatar
It's a brake controller for a trailer with electric brakes. They provide an electrical signal that varies with what the controller decides is how hard you are trying to brake the vehicle. There's also a manual lever so you can apply trailer brakes without applying vehicle brakes.
The other type of trailer brakes are surge brakes and these are a purely mechanical system where a cylinder attached to the trailer tongue provides hydraulic pressure when the trailer pushes forward on the vehicle.
Electric brakes can be easily retro-fitted; surge brakes are much harder to add.
=Steve=
2003 V-8 SR5 4x2 4Runner
2003 BMW 330i 6sp
1965 Mustang (in Bondo and pieces)
1998 Jayco Eagle10UD tent trailer
Surefire Aviator
I'm SteveM and I approve this post.
SteveM is offline   Reply With QuoteReply With Quote
Old 05-12-2004, 10:37 AM #7
Check out Jordanbrake.com. It shows a photo and specs on the controller. Jordan is in Florida, but you can buy directly from him or from several dealers across Canada. CanAM RV in Ontario comes to mind. Jordan has a toll-free number that also works in Canada. Prodigy is also a great controller, but I am very pleased with the Jordan, having it installed in two vehicles.
I will post a photo later.
Old 05-12-2004, 12:23 PM #8
sharp4runr's Avatar
sharp4runr's Avatar
SteveM,
Thanks for explaining that for me.
July
Old 05-12-2004, 12:47 PM #9
bluewolf's Avatar
bluewolf bluewolf is offline
bluewolf is an unknown quantity at this point
bluewolf's Avatar
I need to install a brake-controller as well, very soon. I was told by a "sometimes-reliable" source that Toyota has an OEM brake controller, and that the vehicle is pre-wired for it (but I think this time he's full of crap). Anyway, I too am curious as to what the best, tightest-fitting controlling unit would be for the 4R. Photos would be extremely helpful!
04 SR5 V8 dorado gold pearl
bluewolf is offline   Reply With QuoteReply With Quote
Old 05-12-2004, 03:28 PM #10
QXEA QXEA is offline
QXEA is an unknown quantity at this point
I installed a Prodigy in mine shortly after I bought the Runner. I mounted it to the left of the steering column just under the access door to the fuse panel. I used the plastic holder so I can remove the controller if I want to. I spliced the OEM brake controller cable to the cable that came with the prodigy. I ran the wires straight forward around the parking brake pedal and back to the connector on the sidewall. If you choose to run the wires the same as I did make the wires at least 18-20 inches long. This will allow you to pull the controller from the mounting and unplug it with out cutting any tye wraps. Tekonsha makes or at least their web site lists a cable harness to plug the prodigy directly in to the connector in the Runner. I have yet to find a dealer anywhere that carries the harness for the Toyotas.
I don't have any pics of the installation, sorry.
2004 V-8 Limited Titanium
QXEA is offline   Reply With QuoteReply With Quote
Old 05-12-2004, 09:03 PM #11
I have posted two shots of the Jordan controller installed on my 04 unit. I have placed my foot on the brake pedal to indicate the LED display.
My 4Runer came with the factory wiring harness in the glove box and I simply spliced the required wires to it, plugged it in and that was it - about 30 minutes total, including the bracket on the brake pedal
Brake Controller-resize-p5120201-jpg
Old 05-12-2004, 09:04 PM #12
Second shot
Brake Controller-resize-p5120202-jpg
Old 05-12-2004, 09:05 PM #13
Just finished my prodigy, I put my on the fusebox door. If i sell or trade it in i can replace the fusebox door prior.
http://64.26.171.210/hitch/9.jpg
http://64.26.171.210/hitch/8.jpg
Took 30 minutes or so, buried all the wiring up under the pedals with tie wraps.
Old 05-13-2004, 12:32 PM #14
techjockey techjockey is offline
techjockey is an unknown quantity at this point
I put the brake controller in the middle, under the steering column, to stay out of the way of my knees. It is also attached via velcro so it can be removed when not in use. The velco also allows it to be very compact since there is no bracket involved. It is connected to the quick connect that is installed in all 03/04 4Runners.
techjockey is offline   Reply With QuoteReply With Quote
Brake Assist...what is it?? Thai 4th Gen T4Rs 3 02-01-2022 03:24 PM
Help installing electronic brake controller bcmichael 4th Gen T4Rs 4 06-23-2011 02:00 AM
Brake fluid maintenance Thai Maintenance/Detailing 4 06-02-2006 04:07 AM
Disc & Drum Brakes Thai Maintenance/Detailing 0 11-20-2002 04:32 PM
