Originally posted by bt216
yes. im rubbing on the frame only
any chance you can take a pic where the tire is rubbing?
Without knowing where its rubbing, it is a crapshoot. I'm thinking either your alignment needs some caster added back, or the combo of spidertrax and the offset of the sequoia wheel are causing the rub at full lock. It depends on where the rubbing is taking place as to what I'd recommend to fix it.
I ran 265/70 with no lift or rubbing.
