Thread Tools Rating: Thread Rating: 15 votes, 5.00 average. Display Modes
Old 01-17-2009, 11:43 AM #31
darkie3495's Avatar
darkie3495 darkie3495 is offline
Moderator
darkie3495 will become famous soon enough
Moderator
darkie3495's Avatar
Originally posted by aaf
oh sorry, i thought i could not post the photo but fortunately i miraculously made it. hehehe.
ok, well you have another alternative if you don't want to do the full LED swap. if you just want to replace the bulb and holder, here is the part number:
90010-09019 Long Green light bulb
It should be about $2.50 - $3.30 each.
You could also go to radio shack and just buy the bulb itself and place it in the holder.
Found a place that shows you how to take the HVAC apart and give you an idea of what the holder looks like (long green one).
Link
Kevin's 2008 4x4 Build Thread
Perkins Performance | Shrockworks | Demello | BudBuilt | ICON | Warn | Overland Warehouse | Goodyear | Lightforce | Spidertrax | Powertank | Complete LED Conversion
darkie3495 is offline   Reply With QuoteReply With Quote
Old 01-17-2009, 12:14 PM #32
aaf's Avatar
aaf aaf is offline
aaf is an unknown quantity at this point
aaf aaf is offline
aaf's Avatar
Link
I already ordered LED lights and the Surface Mount from the links you've posted. So, there's no more turning back for me..hehehe.
In fact, my '04 T4R is getting older and never tasted such an upgrade except for the sexy looking toyo tires i installed a year ago. I think she deserve a LED swap.
Thank you again.
aaf is offline   Reply With QuoteReply With Quote
Old 01-17-2009, 12:49 PM #33
aaf's Avatar
aaf aaf is offline
aaf aaf is offline
aaf's Avatar
Thank you again.
Here's my T4R. Her looks still amazes me even she's almost 5yrs old.
DIY: Interior LED swap (cluster, HVAC, switches, window, *steering wheel)-bulbs-001-jpg
Old 01-17-2009, 01:24 PM #34
darkie3495's Avatar
Moderator
Moderator
darkie3495's Avatar
Thank you again.
I hear you. Well good luck and let me know if i can help in any way.
Kevin
Old 04-10-2009, 03:13 AM #35
dothe4runner dothe4runner is offline
dothe4runner is an unknown quantity at this point
Thumbs up Awe---SOME
It's beautiful.
I'm getting tired of looking at yellow instruments, but this seems to be big project. Maybe after my computer upgrade, I have time.
Excellent post. Keep up the good work.
dothe4runner is offline   Reply With QuoteReply With Quote
Old 04-10-2009, 11:43 AM #36
darkie3495's Avatar
Moderator
Moderator
darkie3495's Avatar
Re: Awe---SOME
Originally posted by dothe4runner
It's beautiful.
Thanks man....if you have all the tools and supplies it shouldn't take you more than a day or so. The best way to do it is to tackle the hard stuff first (cluster, steering wheel, HVAC and door). the switches you can do at your leisure
I live in edmonds so if you need any help, let me know.
Old 04-19-2009, 03:10 AM #37
Re: Re: Awe---SOME
I appreciated it very much. I'll be sure to asking for advise from you.
Old 04-28-2009, 06:53 PM #38
chitown4x4 chitown4x4 is offline
chitown4x4 is an unknown quantity at this point
This process for getting the cluster out is the best way to get rid of the pesky TPMS sensor light!!!!
You only have to take off the front cover, pull the speed needle off and put a piece of black tape on the cluster liner back side. Works perfect for those that have upgraded to other wheels and did not bother with the TPMS sensors.
www.chitown4x4.com
chitown4x4 is offline   Reply With QuoteReply With Quote
Old 06-23-2009, 12:45 PM #39
ecrew16's Avatar
ecrew16 ecrew16 is offline
ecrew16 is an unknown quantity at this point
ecrew16's Avatar
Wow. Great write up!
ecrew16 is offline   Reply With QuoteReply With Quote
Old 06-24-2009, 06:50 PM #40
darkie3495's Avatar
Moderator
Moderator
darkie3495's Avatar
thanks. Let me know if i can help.
Old 07-14-2009, 12:50 AM #41
jerrysc99 jerrysc99 is offline
jerrysc99 is on a distinguished road
Originally Posted by darkie3495 View Post
Here is my write up on how to change the color of your interior lights for the 4th Gen 4Runner.
**Disclaimer: This "how to" is for informational purposes only. I take no responsibility for any damage to your vehicle. If you do not have basic soldering skills, please do not attempt. Serious damage could occur.**
Tools needed to remove cluster/steering wheel controls/HVAC unit:
10mm Socket (used to take apart dash/disconnect negative battery)
Small flat head screwdriver (remove steering wheel panels and unscrew bulb holders)
medium Phillips screwdriver (remove steering wheel control)
T-30 Hex Driver (disconnect Air Bag from steering wheel)
Tools needed or suggested to complete LED swap:
I know the fork is ghetto but it works...
15 PLCC-2 Surface Mount SMT LEDs (2-RPM, 3-Speedometer, 3-odometer, 2-gear selector backlight, 1-Fuel, 1-temp, 3-steering wheel controls)
20-backlight only/16-indicators(1-rear window, 1*-4x4 switch, 1-Reset/Mode, 2-HVAC screen, 1-defrost, 1-recirculate, 1-fan speed, 1-A/C, 1-Fan location, 1-cup holder, 1-gear selector, 1-DAC, 1-window, 1-Air bag, 1-Passenger indicator, 1 or 2-115V, 1-RSCA off, 1-VSC, 1-Diff lock)
Useful links:
Remove lower dash, center console and HVAC unit
Detailed how-to to swap Steering wheel control LED's. I won't go over this since slvrAZtaco's write-up is thorough.
Cluster LED Swap
1) disconnect battery using the 10mm socket
2) Remove lower driver side dash and let it hang (Step 3 - http://www.castulucci.com/projects/carpc/oemnaviaccess/)
- While you have it disconnected, you can pull all the switches located on this panel
3) Grab the trim surrounding the gauge cluster near the bottom and pull towards you. Clips are the only thing holding it in place.
4) There are 3 screws/10mm bolts holding the gauge cluster and 2 bolts connecting the harnesses.
This is what's behind the cluster
5) Remove the clear lens and interior black trim. both pieces are held on by plastic tabs.
6) Remove white plastic backing
7) Take pictures of the needle positions at rest. It
Hi Darkie3495, do you have more to the instructions. I notice it stopped at step 7 "Take pictures of the needle positions at rest." Do you have more steps to complete the cluster gauge with pictures? thanks appreciated.
jerrysc99 is offline   Reply With QuoteReply With Quote
Old 07-14-2009, 01:07 AM #42
darkie3495's Avatar
Moderator
Moderator
darkie3495's Avatar
Hey jerrysc99. looks like when they moved the site over to the new servers, it cut the DIY. i know they are working on it so it might populate eventually. if there is something specific i can answer i'll do my best. i still have most of the pics.
Let me know,
Kevin
Old 07-14-2009, 12:14 PM #43
Let me know,
Kevin
Thanks for the quick reply Darkie3495. Can you tell me where you got the LED's and model/part numbers? By the way your Cluster gauge looks fantastic! I hope the remaining of DIY gets populated soon. Thanks again.
Old 07-14-2009, 02:12 PM #44
darkie3495's Avatar
Moderator
Moderator
darkie3495's Avatar
Here is the post that shows the details:Link
Unfortunately, the link to the ebay LED's is out of date and the price has increase a little. here is the updated link: Ebay Link
Hope this helps.
Old 07-17-2009, 12:07 PM #45
Hope this helps.
Hey Darkie3495, the site still haven't update the missing DIY instructions. Do you happen to have a copy of it? Can you posted it again or email me at [email protected]
Thanks a lot!
steering wheel switches (colors) A/V1 Engines / Suspension / Wheels / Tires / Audio / Accessories 5 03-03-2012 08:59 AM
Rear Window doesn't go down and Wheel lock key situation. Gene4running Classic T4Rs 4 12-28-2009 06:54 PM
Scion HU swap = Tail gate window problem kalakar Engines / Suspension / Wheels / Tires / Audio / Accessories 3 12-05-2005 10:36 PM
Window switches Swaro 4th Gen T4Rs 7 11-25-2004 07:34 PM
