Originally posted by s-one
I was heading down hill to make a left turn at a stop light. I had my foot on the brakes as I slowed just before making the turn and I hit some rough pavement. At first the the brake peddle felt normal then it felt like it had had no resistance, then the truck surged forward for about 2 seconds then the brakes engaged very hard. Hard enough were everyone jolted forward a bit but not so hard to cause any skidding. Is this normal?
Thanks,
s-one
The rough pavement probably caused the wheels to loose traction. What you felt was the ABS releasing the wheels to allow them to spin and allow you to steer. Normally it's not as agressive as you described but once in a while you catch the conditions just right and it'll startle you. Kind of a perfect storm scenario... I've used the ABS on mine several times and only encountered what you described once. It involved washboard on one side of the vehicle on a dirt road...
Just keep steady pressure on the brake pedal and steer as necessary.
