02-09-2009, 02:56 PM
timing and serpentine belt - are they the same?
Dealership is telling me that the timing belt on my 04 v8 (56k miles) should be replaced every 90k or 5 years. I said the belt looks fine, the dealership said what I was looking at was the serpentine belt, and that the timing belt is "buried in the engine".
I thought the timing belt and serpentine belt were the same - am I wrong?
2004 4Runner V8 Limited
02-09-2009, 03:04 PM
They are not the same. The dealer is giving you sound information.
2006 V6 Sport Edition 4x4 Titanium Metallic, 265/65/17 Goodyear Wrangler Silent Armor
2003 V6 Highlander Limited Millennium Silver
02-09-2009, 03:06 PM
Re: timing and serpentine belt - are they the same?
No, the serpentine belt can also be called the accessory belt, it runs all the things attached to the engine: air conditioning, alternator, power steering, etc. The timing belt spins the camshafts. There is a cover on the front of the engine and it is inside that.
And yes, 90k or 5 years. If the timing belt brakes, the camshafts will stop spinning and some of the valves will be left in an open position and when the piston comes up it will kiss the valves and cause extensive damage. Expensive fix, might even need new cylinder heads.
Don't think that cars with chains instead of belts are immune, I got an 85 4Runner for free because the chain tensioner broke and the cam gear skipped a few teeth. That needed a new cylinder head, but the car was free so so what. It was 19 years old and 250,000 miles when it happened.
The 4L V6 uses a chain, btw. I wish our V8's did
2012 4Runner Limited
2004 V8 4Runner Limited
2003 V8 4Runner Limited
1998 3RZ-FE 4Runner
1985 22RE 4Runner SR5
02-09-2009, 03:10 PM
I just went out and looked at mine to reference; the chain is inside the black plastic covers on the fronts of the cylinder heads. If you're standing in front of the car looking at it, the radiator hose comes out of the radiator to your right, makes a turn and passes over the top of one of these covers before it makes another turn and goes into the engine. Once you see the shape of the cover it should make sense of what is inside
1998 3RZ-FE 4Runner
02-09-2009, 03:13 PM
Super Moderator
Super Moderator
Well, this might be the first time, but your dealer is absolutely correct. The serpentine belt powers the fan, alternator, power steering and air conditioner. Years ago, you might of called it the fan belt or alternaotr belt. Basically the serpentine belt is one long belt that does the work of 1 or 2 belts.
The timing chain is inside the front cover of the engine. The belt does run the water pump, but the main reason for the timing belt is turning the cams that control the valves.
Also, when you replace the timing belt, you have to remove the serpentine belt, since the cost of replacing the serpentine belt is labor, it usually makes sense to replace that when you take it off.
Also, you can look at the timing belt by taking off the cover, even if it looks fine, you don't want to risk the potential cost of it breaking as it may bend your valves. The V8 is an interference engine meaning, $$$ if it breaks.
I kind of sound like a dealer, sorry about that.
2001 & 2004 Toyota 4Runner SR5 4X2
Both V6 and both Natural White
"Yeah, I like white and I like 4Runners"
02-09-2009, 03:16 PM
Thank you for the fast response! Is the timing belt a DIY replacement?
02-09-2009, 03:19 PM
Super Moderator
Super Moderator
I would say it is fast, I wrote my response and 3 came in before me. Replacing a timing belt is somewhat hard to do. I can replace starters, alternators, but a timing belt is a little over my head. You have to have some special tools and special skills, skills I don't have, but you might have.
02-09-2009, 03:26 PM
Have you tried replacing the starter on the V8? Not fun, it is in between the cylinder banks and UNDER the intake manifold.... Everything on top of the engine has to come off. That's my only gripe about the 4.7L
1998 3RZ-FE 4Runner
02-09-2009, 03:28 PM
If you tried it yourself, just remember that if the timing is off you could cause extensive mechanical damage to the engine
1998 3RZ-FE 4Runner
02-09-2009, 04:02 PM
No offense, but if you don't know the difference between the timing belt and serpentine belt, it's definately not a DIY. I've done a good amount of work on all the Toyotas in my sig and have had quite a few timing belts replaced BY THE DEALER.
And it's probably a good idea to replace the waterpump at 90k instead of waiting until the next belt replacement at 180k. It's easier to get to the water pump when the timing belt is replaced (at least it was on my 2nd and 3rd gens).
Rick
'90 T4R - sold at 205,000 miles
'00 T4R - sold at 152,000 miles
'08 Sport - 178,000 miles & still going strong
'19 ORP - just over 6,000 mi. (garage queen, like my '07 Mustang)
02-09-2009, 04:31 PM
90k or 5 years? I think my service bulletin says 90k and 7 years. I had replaced TB on my 97 Audi A8 at 100k and it was a MAJOR piece of work. Belt looked like it could go for another 50k. 23 hours later it was done and everything worked perfect. I would not attempt this again unless you have access to shop full of tools and have dedicated weekend for it.
2004 4Runner Limited V8 4WD
Toytec Ultimate 3" (X-REAS & RAS - delete). LS460 + STi retrofit, Switchback Halos, LEDs in/out, Fog light mod.
CBI front bumper. 285/70/17 Duratracs.
JVC KW-V50BT with Hertz HCP4D & Hertz HCP1D, Hertz ESK-165 components and JL 10TW3 in custom stealth enclosure. Backup camera and steering wheel controls.
02-09-2009, 04:38 PM
Re: Re: timing and serpentine belt - are they the same?
just to give you idea what you will be up to if you attempt this yourself. By the way, 23 hours its a total manpower (2 people working relaxed, not to counting beers). This is TB replacement on 4.2 V8 Audi A8
02-09-2009, 05:31 PM
Yeah, doing the water pump during a TB service is pretty much a must. Crazy not to do it, plus it's cheap insurance at that point.
SOLD2007 4Runner Sport Edition V6 4X4 - Natural White - Perf: Doug Thorley Long Tube Headers | 4.56 Gears ARB Front / TrueTrac Rear Off Road: Fr: Bilstein 6112 w/1/2" Toytec Spacer / Rr: MT ICON Long Travel | JBA UCAs | VTX Rogue 17x8.5 -10 | GY Duratrac 285/70R17 | Rear Diff Breather Mod | 1" Toytec Body Lift | Custom Cut Axle Joints ICE: Auto Pumpkin 10.1" Android | 3.5" Tweeter Mod Exterior: Quad Bi-Xenon HID Retrofit
2019 4Runner Limited 4x4 - MGM - Hers | Ironman4x4 FCP's & UCA | Fuel Rebel 20x9+1 | GY Duratrac 275/60R20 | Victory 4x4 FLRR
02-09-2009, 05:44 PM
Super Moderator
Super Moderator
No, I haven't, also I haven't tried it on the 01 V6 either, I have put starters on smaller front wheel drive cars, but I did put one on a Fiat 124 once, (RWD) the starter was probably worth more than the car.
I tried to replace the timing belt on a 1980 Honda Civic and though it was a small 1.5 liter engine, I was a bit out of my leaque. I took it to a dealer. After that I haven't even tried or attempted to change one.
02-09-2009, 07:01 PM
Banned
Banned
Hey, if any of you 4th gen V6 owners want to get a glance at your timing chain, just pop open the oil filler cap and shine a flashlight into it. The chain is easily seen because it lines up perfectly with the filler opening.
