Old 03-02-2009, 11:41 PM #1
T4RBoarder's Avatar
T4RBoarder T4RBoarder is offline
Real Name: Aaron
T4RBoarder is an unknown quantity at this point
T4RBoarder's Avatar
Real Name: Aaron
Bumper removal
Has anyone taken the bumper off of a 4th gen? I need to get my bumper repainted and the body shop wants to charge 2.5 hours labor or 150 bucks to remove and reinstall it. I wouldn't think it would be that hard but it would be great if someone had a write up.
T4RBoarder is offline   Reply With QuoteReply With Quote
Old 03-02-2009, 11:48 PM #2
AbeFrohman AbeFrohman is offline
AbeFrohman is an unknown quantity at this point
I would think that a Haynes or a Chilton's book might be your best bet if no one has a walk through. These can all be found at Pep Boys or Autozone. Price is around $25. Good luck.
AbeFrohman is offline   Reply With QuoteReply With Quote
Old 03-02-2009, 11:58 PM #3
T4RBoarder's Avatar
Real Name: Aaron
T4RBoarder's Avatar
Real Name: Aaron
I checked on their websites and it seems that they don't publish one for our trucks? I could have just had a fail moment.
Old 03-03-2009, 12:24 AM #4
budenski budenski is offline
budenski is an unknown quantity at this point
There are 6 or 8 bolts at the bottom of your bumper that attach it the rest of the vehicle. There are also 2? brackets that attach your bumper to your fender?.
I know for sure there are those bolts at the bottom which are 10mm. I only know this because I hit a pine tree recently and immediately took off my bumper as it looks 30x better.
Oh, and I had no trouble with the airbag sensor. I was told they are the two yellow things(1 left, 1 on the right) and you shouldn't set them off by unbolting the bumper.
Photobucket
Go Dawgs!!!
06 SR5 V8-stock
budenski is offline   Reply With QuoteReply With Quote
Old 03-03-2009, 09:57 AM #5
paraordnance's Avatar
paraordnance paraordnance is offline
paraordnance is on a distinguished road
budenski, you right, it does looks 30 times better without a bumper
2004 4Runner Limited V8 4WD
Toytec Ultimate 3" (X-REAS & RAS - delete). LS460 + STi retrofit, Switchback Halos, LEDs in/out, Fog light mod.
CBI front bumper. 285/70/17 Duratracs.
JVC KW-V50BT with Hertz HCP4D & Hertz HCP1D, Hertz ESK-165 components and JL 10TW3 in custom stealth enclosure. Backup camera and steering wheel controls.
paraordnance is offline   Reply With QuoteReply With Quote
Old 03-03-2009, 12:09 PM #6
T4RBoarder's Avatar
Real Name: Aaron
T4RBoarder's Avatar
Real Name: Aaron
I totally agree! haha
Budenski: thanks for the info, once it warms up a bit here I'll tackle the job
Old 03-03-2009, 04:21 PM #7
haha, thanks guys. Well, it looks better than my FUBARed bumper, but it kind of sucks getting weird looks. But then again, I saw a 4runner without the driver's side rear window and the roof dented in due a tree falling on top of it. So I guess I made out better than that guy in this fluke weather.
GOH10, if you need detailed pics of what I'm talking about I don't mind running out and snapping a few more pictures. It's going to the body shop this friday so let me know by then.
Go Dawgs!!!
06 SR5 V8-stock
Old 03-03-2009, 11:01 PM #8
T4RBoarder's Avatar
Real Name: Aaron
T4RBoarder's Avatar
Real Name: Aaron
that would be AWESOME if you could take a few pics for me, I would really appreciate it.
Old 03-03-2009, 11:20 PM #9
matroe11's Avatar
matroe11 matroe11 is offline
matroe11 is an unknown quantity at this point
matroe11's Avatar
When I was installing some trim behind the upper and lower grilles, I tried to take the bumper off. Removed 8-10 bolts from the bottom and along the fender trim...but I couldn't get it off b/c there was something else holding it in. I didn't feel like spending any more time so I just crawled up between the retainer and the radiator to get it work.
Good luck in your attempt. There isn't much more to it than those bolts. Also, there def. is not a chiltion's or haynes manual.
http://www.calendollar.com
2005 T4R Limited
custom grille grating, Borla Dual Catback, rubberized undercoating skid plates, LED replacements, stainless steel shift knob, '06+ JBL HU, iPod adapter USA Spec
matroe11 is offline   Reply With QuoteReply With Quote
Old 03-04-2009, 10:26 PM #10
Here are some pictures of the bumper and of the front end. They are both banged up a good bit but you can get a good idea where possible connection points are by looking at the pictures of the bumper.
http://s702.photobucket.com/albums/w...ront%20bumper/
Go Dawgs!!!
06 SR5 V8-stock
Old 03-05-2009, 12:10 AM #11
mmjmeade mmjmeade is offline
mmjmeade is on a distinguished road
there are 2 10mm bolts up inside the fender liner. 2 plastic clips that hold the fender liner to the bumper on the side ( just turn them to remove them). there are 2 10mm bolt on the bottom of each side. these hold the fender liner to the bumper. you will have to remover the lower grille. this is the tricky part. there are 2 seperate clip that hold the grille o the bumper. just be carefull. them there are 3 push clips under the grille ( once it is removed). on the bottom center of the bumper there are a couple more bolts ( i believe 10mm). be sure to disconnect the fog lights as well. once all the bolts and clips are removed. pull out on the end of the bumper. they are still held in place by plastic brackets. these hold it tight to the fender. a good pull and its off. anything else just ask. i take them off all the time. for that price i would take it off myself too.
mmjmeade is offline   Reply With QuoteReply With Quote
Old 11-18-2019, 08:15 PM #12
04Limitedmj 04Limitedmj is offline
04Limitedmj is on a distinguished road
The clips? Do you pull straight down on the end of the bumper cover near the fender wells or out away from the vehicle?
04Limitedmj is offline   Reply With QuoteReply With Quote
Old 11-19-2019, 06:03 PM #13
BR06run BR06run is offline
Real Name: Bill R.
BR06run is on a distinguished road
Real Name: Bill R.
Pull straight forward. It helps to have 2 people,one on each side. Give it a good hard yank. Those claws can fit pretty tight.
BR06run is offline   Reply With QuoteReply With Quote
Old 11-19-2019, 06:37 PM #14
BendRunner BendRunner is offline
BendRunner will become famous soon enough BendRunner will become famous soon enough
yep give it a good tug. I was able to do it myself and I'm 5'5 and 130lbs.
BendRunner is offline   Reply With QuoteReply With Quote
