hey wes,
it is pretty easy. granted i have a 2008 so hopefully they are similiar. Just remove the lower dash below the cluster and just grab from the bottom and pull. start from the lower left and make your way across. it is just a bunch of clips.
Once you have the bezel removed there are actually 5 bolts holding it together (3 bolts holding the bezel itself, 2 used to connect the harness). once you remove the cluster, its just a few tabs holding the clear lens to the cluster.
just as a reference, look at the 2nd picture down on this thread.
link
Should only take you 20 mins. Good luck!!
Kevin
