Originally posted by ABooker
Ok, 1st give us a little more info. Did this just happen? Did you buy it that way? Does the key turn? Does it make a noise like it's trying to unlock? Can you lock the door?
Check the fuse?
Good luck....let us know what you come of with.
Thanks!
It just happened a day ago. And it did work before (I have a FOB, but wife doesnt). The key will insert, but wont turn at all. Not a tiny bit. No noise. Cant lock the door either (won't turn either way). The best way I can describe it, is like the lock is frozen. I've had it in the garage with the heat on for the past 6 hours, and shot some lock de-icer in for good measure. Just checked it now with no luck. I havent checked the fuze, but would a shot fuze keep the lock from even turning?
thanks for the reply BTW
EC
