Re: Running Board Lights - HELP!
Originally posted by BostonBeachbum
Not sure if this has ever been discussed, but nothing is coming up on the search. My front drivers side running board light is out. I've checked/changed the bulb and the bulb is fine, but something must be wrong with the wiring, connections etc. Has anyone run into this or have any suggestions. Any help with a wiring diagram would also be helpful. I don't think anything is shortingout, because no fuses are blown and all other lights, acc. are still working.
Its an 03 Limited w/v6
The socket for the bulb may be dirty or have a bent contact. I would start by checking for 12 volts at the socket with a voltmeter.
Larry
"Monsters From the Id"
2004 SR5 V6 Titanium Metallic/Stone, Auto Dimming Compass Mirror, Valor Tip, Overhead Console W/HomeLink, Cargo Net, Michelin Cross Terrains, Added JBL Synthesis 10 speaker system 6/08, USA Spec PA-15 TOY Ipod Interface, Drivers Side Overhead Handle, Valvoline Synpower 5W-30, Mobil 1 75W-90, LEDs
