02-07-2012, 07:30 PM
Battery Life??
Anyone know what the typical battery life is for the Panasonic batteries?
I have a 2008 with 54k....and I have a feeling it might be going.
Joe Santoro
4th Generation - 2008 4Runner SR5
02-07-2012, 07:56 PM
Real Name: Nick
Real Name: Nick
The factory Panasonic batteries have been known to last a long time, 5+ years. I have a 2005 with the original battery, 110k.
02-07-2012, 08:02 PM
^^ +1. They last a pretty long time.
'05 Black Limited V8 with XREAS / LED Interior & Exterior Swap / Custom LED Ground Lighting Strips Mounted Below Running Boards / HCF Delete / AFE Air Filter (Dry) / Optima YellowTop / DDM Tuning 35W 5000K HID Fogs / Weathertech Digital Floor Liners & Cargo Mat / 20" Enkei Wheels / Tacoma Skidplate / Built In Headrest DVD Monitors with Custom Covers / iPod Adapter / Pioneer AVIC-D3 HU with Navigation / PassPort 9500xi, Hardwired / 50% Tint / Custom White/Blue LED Gauges & HVAC /
Coming Soon: Lift, UCAs, 1.25" Spidertrax (have 'em, just waiting on install)
02-07-2012, 09:07 PM
Battery life is determined mostly from the temperature extremes you subject it to. Heat is probably worse for batteries than cold, but bitter cold can shorten battery life. Mileage has nothing to do with longevity. Batteries last the longest in areas without big temp swings.
02-07-2012, 09:29 PM
I just replaced my original with an optima but it wasn't ever dead yet and I have a 04 with 107k and in live in Wenatchee WA. Pretty good weather swings.
02-07-2012, 10:05 PM
Mine OE Panasonic Lasted over 6 years
Replaced the battery before it got bad. It was taking a little more time to turn over in the dead of Winter so I replaced it. It was almost 7 years old when I bought a new one. I went to the Toyota dealership for an identical Panasonic replacement battery, but they only carried some other aftermarket brand, I forget which. I ended up getting a NAPA Legend battery. It has the same AGM (Advanced Glass Mat) construction and had very similar electrical specs. It's been fine now for almost 2 years.
ALso, Sears DieHard batteries seem to be extremely well rated in Consumer Reports. I would have gotten one of those, but NAPA is about 10 minutes walk from my house, and i think it came with a 72 month warranty.
2003 4runner V6 Limited 4x4 - A good ten years.
4 out of 5 dentists recommend Trident to their patients who chew gum, the 5th dentist recommends chewing a cup of pure cane sugar before bedtime. Don't go to that dentist!!!
02-07-2012, 10:10 PM
2004 with 130k now and still the original battery.
Did some searching and as far as I can tell you can only get the Panasonic batteries in Japan.
Would be great if we could track down someone stateside that carries them...
2011 Limited - TerrainContact H/T & Blizzak DM-V2 - aFe Pro DRY S - AMSOIL Fluids - Woolwax Undercoat - Lasfit Lighting
2004 SR5 V8 - BFG KO2 - Bilstein Shocks - FJ Springs - Air Lift Bags - Redarc Controller - K&N filter - AMSOIL Fluids - Woolwax Undercoat - Lasfit Lighting
02-07-2012, 11:03 PM
My Panasonic battery lasted me 8 years and was still getting the job done. '04 4Runner with 110,000+ miles on it. Although still working, I had it tested and it was around 440 CCA left. Replaced with the Toyota true start battery.
Battery life can be affected by the climate you live in and your driving habits. In my case, I'm in Western Washington, park in it my garage, and don't make many short trips when I drive.
Wish we could all buy Panasonic replacements!
'04 Titanium/Taupe SR5 V6 4x4
VVT-i emblem
All weather floormats
Form Fit Hood Protector ("Canadian" one)
Toyota TRD duffle bag to hold the goodies.
K&N Drop-In Filter
Grill Mod
Cabin Air Filter Mod
Fully Synthetic Mobil 1 Oil and Lube
Michelin LTX AT/2 tires
02-07-2012, 11:05 PM
Super Moderator
Super Moderator
Mine failed a load test after 3 years. My truck is subjected to cold temperature throughout the winter.
Mark
2005 4Runner Limited 4X4 V8 since 6/15/05 Titanium Silver with Grey Leather
Nav, XREAS, Adjustable Ride Height, Sunroof, Side Curtain Airbags, Rear Spoiler, Double Deck Cargo, Chrome Exhuast Tip, Bug Shield, All Weather Mats, Driver Side Assist Handle, Audiovox Remote Starter, 2006 Skid Plate, LED lighting- interior and running boards, USA-Spec PA-15
Click For Pictures of My Current 2005 Limited, Detailed LED Conversion Instructions, Click For Pictures of My Retired 2003 Sport
02-07-2012, 11:28 PM
2004 80k miles still factory battery. knock on wood.
02-07-2012, 11:50 PM
My 2007 has 92K and on the original Panasonic battery. Wish I could replace it with another one when this one dies.
2013 Tundra Rock Warrior
2007 Lexus LS460
2011 Camry SE V6
02-08-2012, 09:03 AM
I actually just replaced my factory battery on Sunday. It was 7 years old and had ~108,000 miles on it. It was still cranking fine but it failed the load test with only 400CCA.
2006 SE 4.0 4WD (click for build) : Custom, de-badged floor mats...
02-08-2012, 09:24 AM
My 04's original is finally getting tired, on cold days (like today) it's noticeably slower cranking over. Time to try a DieHard.
04 4Runner SE V8-JVC KW AVX720-Clifford Remote Start-Huskyliner Mat
08 Tundra-DC-TRD OR-5.7L Stock
05 Tacoma AC TRD OR V6 4x4-265/75 Duratracs-Sold
96 4Runner SR5 3.4L e-Locker 265/75 AT's, PIAA Fogs, Command Start-Sold
98 Tacoma Xtracab 3.4L-Crushed by Toyota
02-08-2012, 10:29 AM
What actually kills a battery is HEAT. The more the battery is subject to high temperatures the less life expectancy it'll have. Cold will tell you when the battery is weak.
Here in the North East it's I usually get 7+ years out of the OEM battery. Then I usually replace it with any battery I find on sale (Usually a Sears Diehard - they're ALWAYS on sale). That will be the last battery I buy for the vehicle. Usually sell vehicles after 300k miles.
05-27-2015, 01:53 PM
Time for a thread resurrection...
'04 with OEM Panasonic; came home from an 8 day business trip a couple weeks ago and couldn't get the motor to turn over. A quick jump start from the roving long term parking attendant and I was back on the road. Has been fine for the last 18 days albeit noticeably longer crank time.
Went out to take my daughter to school this morning, low and behold it had finally died. RIP Panasonic; 11 years and never gave me as much as a scare. Sure do wish we could replace with the same!
2004 4Runner Sport V6 - Silver
BFG KM2 285/70/17 | Shrockworks Sliders | Spidertrax FF | TRD CAI | TRD Valve Stem Caps | Camburg UCAs
Toytec C/O Lift 3/2 | Custom Rack | iPod Controls | R Diff Breather | Cobra 29 LTD BT | Custom End Links | Weather Tech Liners | Custom Rear Drawers
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
