05-23-2009, 02:07 AM
How to have fog lights on, but not low beams
Has anyone figured out how to have the fog lights on without having to have the low beams on?
Or have the fog lights on while the high beams are on?
It's just something where I'd like to have that flexibility.
05-23-2009, 09:55 AM
Re: Fog Lights
I don't think it is possible unless someone were to rewire the system. The 4Runner is an incredible vehicle, but the fog light capabilities are kind of stupid.
2003 4Runner Limited V8 4WD;Pacific Blue Metallic; Cornfed 3/2 Lift; Spidertrax Wheel Spacers;Magnaflow Cat-Back Exhaust; Nitto Terra Grapplers 265/70/17; aFe Pro-Dry S Air Filter; Philips 4300 Xtreme HID Low-Beams; PIAA 540 Plasma Ion Fogs; HIR Hi-Beams; HIR main fogs; Man-A-Fre Front Skid; Alpine Head Unit w/I-pod Interface; Alpine Type-R 10" Sub; Kenwood 1000W Amp; JBL 10 speaker system; Steelcraft Bull Bar; Go Rhino Hitch Step; PIAA Super Silicone Wipers; TRD Radiator and Oil Caps; Brembo brake pads & rotors; TRD Carbon Fiber and iForceV8 Emblems on Hatch; all LED interior, Running Board, Reverse and License Plate bulb replacements; Weather Tech mats and Cargo Liner; Blitz Hybrid Cabin A/C Filter
05-23-2009, 04:25 PM
wow. I bookmarket it. Thanks. Have to do it one day. Was curious about that too. I have an awesome light set up and its extremely bright and wide at 55w lows and 35w fogs but I also would like to use all three with halogen Silvania Ultras as highs on empty highway cruising
2004 4Runner Limited V8 4WD
Toytec Ultimate 3" (X-REAS & RAS - delete). LS460 + STi retrofit, Switchback Halos, LEDs in/out, Fog light mod.
CBI front bumper. 285/70/17 Duratracs.
JVC KW-V50BT with Hertz HCP4D & Hertz HCP1D, Hertz ESK-165 components and JL 10TW3 in custom stealth enclosure. Backup camera and steering wheel controls.
05-23-2009, 06:42 PM
I did JA's mod, but with a twist.
Instead of getting my signal voltage from the
relay (on with the key) I spliced into the parking
lights for power. Now I "can have" fogs on with
LOW's, HIGH's, DRL's or PARKING's. I like this even
better than "always on" unless switched from the stalk.
2007 Driftwood Pearl Limited
06-01-2009, 11:13 PM
If the dealer saw this mod would they void the warranty??
06-02-2009, 12:07 AM
If that is your concern, you can perform the engine compartment fuse box mod from underneath and they will never notice it. Rather than bend out the fog relay prong, you cut the respective wire from underneath, tape off the side which is feeding from the low beams, and for the wire on the relay side you bring power to it via an idc tap on an ignition based 12V+ source.
06-02-2009, 07:35 AM
OK. I see. I will have to read this a few more times to make sure I get it. I am trying to visualize these steps
AND Im guessing it would void the warranty...
06-02-2009, 09:00 AM
It is totally reversable when done from above and can be quickly put back to factory specs. anyhow, it wouldnt instantly "void" the warranty unless it can be proven that the mod caused some particular damage. I have run this same mod on my 1999 for almost 10 years now (was basically the first to do this mod to the refreshed 3G 4R with factory fogs) with absolutly no issues.
06-06-2009, 03:40 PM
I'm having a hell of a time trying to track down the 3m Scotchlok locally. I might have to go online, but I don't need a bag of 50.
Anyone know where I might be able to source one?
06-06-2009, 05:02 PM
Super Moderator
Super Moderator
What's local for you? If you have marine stores nearby they often have that type of stuff as should a stereo install kit.
Chris
07 Salsa SR5, 4wd Cyclone pre-cleaner , Aux Transmission Cooler, Hidden Hitch 70779 (600/6000lbs, WDH=730/7300lbs), AirLift 1000, FJCruiser front springs (& now rear too!), Axle Vent Mod, Swaybar Bushing Upgrade, V6 Tick Reduction, VSC off mod, Maplight Mod, 255/75/17 Goodyear Wrangler SAs, Tailpipe Mod
06-06-2009, 05:06 PM
Keep in mind that the color of wires that you need to jumper (depending on how you want to do the mod) is different for different years. (The pin location is the same though)
http://www.toyota-4runner.org/showth...threadid=49670
* 2004 V8 White Sport Edition 4x4 * 265/70R17 Nokian Vatiiva's * Weathertech Floor Mats * USA-Spec TOY15 iPod Adapter (sweet) * Fog Light Mod * Lightforce Striker 170 Driving Lights *
06-07-2009, 03:33 AM
Woot! Found an equivalent at radio shack! Not a 3m, but it should get the job done.
06-07-2009, 07:50 AM
let us know how you made out , take some pics too
06-10-2009, 02:28 AM
So I got I got the foglights to work. I spent probably a half hour chasing my problem which was the connecting wire I made had a bad connection. Doh! Than ks god I had a ohm meter which help me chase down the problem much faster. It beeps when there's a complete circuit.
As a tip, the wire connector that is used on the steering column is probably best clipped in some pliers. It's not easy by fingers. OE, the wires come electrical taped and wrapped, but it didn't look like it was necessary, so I didn't bother to re-wrap it. I just put the covers back on.
I also installed some Mod-Express 4300k HID's which went well except for right after I installed it, The driver's side wouldn't turn on. So that was maybe another 20-30 min checking all the connections when I compared to the passenger side and though hmmm.. maybe I plugged the power source to the ballast in the wrong way which happened to the be culprit.
let me tell you that these 4300k HID's are way brighter than the crap ass blue light bulbs that the previous owner had in there. Those had hardly any light output.
i'm llikely going to be changing to 6000k light bulbs since the rest of the trucks lights are 5000k or 6000k.
I'll see if I can get some pics up tomorrow.
