07-11-2017, 11:13 PM
#16
Awesome.
Originally Posted by jetboy1975
Don't take it to the stealership to program. It is very easy to do it yourself. If you buy a fob on ebay it should come with instructions. If not I will post them below.
Programming for a 2003 to 2005 Toyota 4 Runner
When
Remote transmitter added or replaced.
System malfunction.
How
Driver's door open, key removed from ignition switch.
Within 5 seconds:
Insert and remove the key from the ignition switch twice.
Within 40 seconds:
Close and open driver's door twice.
Insert and remove the key from the ignition switch.
Within 40 seconds:
Insert the key into the ignition switch and close the driver's door.
Switch ignition ON and OFF once to program a remote transmitter code whilst
retaining the original codes or twice to program a remote transmitter code
whilst erasing the original codes. Three times to check how many remote
transmitters are currently registered or five times to erase all registered codes.
Remove key from ignition switch:
System should now lock and unlock vehicle once, twice or five times
depending which mode has been selected. One to four times, slowly, to
indicate number of remote transmitters registered.
Within 40 seconds:
Press and hold LOCK and UNLOCK buttons simultaneously for 1.5 seconds -
Within 3 seconds:
Press LOCK button.
System should now lock and unlock vehicle once to confirm registration,
twice to indicate registration has failed.
Within 40 seconds:
Repeat button procedure to program remaining remote transmitters.
NOTE: To exit programming mode: Open driver's door.
NOTE: A maximum of 4 remote transmitters can be programmed.
It may take a few tries and the timing must be very accurate to work but with a little patience it is easy.
Perfect. Worked like a charm!
09-21-2018, 12:09 PM
#17
Key Fob Programming
I have a 2000 4Runner, and I too have felt like a retard, not being able to program my remote- so much for that college degree. I have tried both ways of programming (door shut and open and lock unlock repeatedly) to the letter, repeatedly, and none have worked! I spent 3 days taking it places (battery shop, locksmiths, techie friends, etc. NONE have worked for my 2000. Then I just put my old fob guts into a new case and went on.... for awhile. Now I am told my remote is dead, new batteries do not help, so I purchased a new one on ebay. No luck, revisit of the frustration. Do I really have to pay the Stealership the $70? Someone said in earlier post the they did not think the 2000 was programmable. Can anyone else confirm this? Why?
(Sorry for the non-politically correct term in first sentence, just frustrated and no other term fits as well)
09-22-2018, 01:03 AM
#18
You might want to post in the 3rd gen forums. The key fob programming for the 3rd gen might be different from the 4th...
1999 2.7 5MT - SOLD // 2007 V8 4WD - Gone
2011 FJ 4WD - to new beginnings
// 4G V8 // 3G 2.7 5MT // Model 3 // IS300 5MT // FD RX7 //
09-22-2018, 11:40 AM
#19
Real Name: Justin
Real Name: Justin
You might also have maxed out the number of fobs keyed to the vehicle; I believe if it hits 5 it won’t allow any new fobs to link. I recently picked up 2 new fobs for my 2005 and my rig only permitted 1 to link up, leading me to think that some of the earlier fobs (which I don’t have) will need to be erased from the computer before programming new ones.
2005 V6 Sport T4R "Furiosita" and the mods are neverending
10-16-2018, 06:27 PM
#20
How can one erase from computer? At dealership?
10-16-2018, 06:36 PM
#21
At the very last step of programming:
Switch ignition ON and OFF twice to program a remote transmitter code
2004 Limited V8
05-28-2019, 07:49 PM
#22
Originally Posted by sr3tlaw
Here is the procedure that Worked for my 2007 Limited 4WD V8
Credit to "Count_Olaf" for the post over on yotatech forums
2006 Sport Edition V8
Well I tried this to program an eBay key fob. I only had one oem key and fob when I bought the vehicle.
The eBay fob would not program, and I unintentionally deprogrammed my oem fob.
I went through the procedure about 10 times with the oem fob to reprogram it. I get all the way through the end, & it confirms that it’s programmed (step 9). I then open the door to end programming & then the fob does nothing...🤬
So I can’t get the oem fob reprogrammed, and now the alarm randomly sets off...
12-10-2019, 08:40 PM
#23
Real Name: Evan Sundgren
JetBoy1975, I'm not sure how to "hold LOCK and UNLOCK buttons simultaneously" in step 8. Nothing seems to happen after that step and step 9. I get the confirmation "System should now lock and unlock vehicle.." after step 7, but nothing past that. Also working with new transponder key from dealership, and not a key fob remote. Thanks!
12-11-2019, 12:53 PM
#24
I went through hell with this also. What i found is that the timing is critical, the instructions say 1.5 sec, but i think that may be the MAX amount. When I finally got it to work I only held it for around 1 second. Each time previously I was holding it for about 2 seconds.
12-12-2019, 10:51 AM
#25
Ok, so... figured it out I think. My problem was trying to use key FOB remote programing with a key transponder! DoooH! I was thinking the "hold LOCK and UNLOCK buttons simultaneously" was referring to the 4Runner door LOCK and UNLOCK buttons, not the key FOB remote's. ...Oh well..
Found the transponder programming and it worked like a charm. Here's the thread that did it for me by digin66.
programming 2008 4runner keys
This other thread started by nicolachel was helpful as well.
How to make spare chipped keys
Looks like it helps to start in the right thread! Following up here in case anyone might make the same mistake I did.
Moonshadow: 2006 UnLimited VVT-i V8 RWD Titanium Metallic, Stock
Every time I step on the gas it makes me smile.
12-13-2019, 02:35 PM
#26
Originally Posted by bpearson
Hello all
I purchased a 2006 4Runner Ltd a few days ago from Carmax and my baby has only 1 key fob. I still have the key fob from my dearly departed 2000 4Runner (may she rest in peace).
Is it possible to re-program the key fob to work with my new 4runner?
If possible does this have to be done at a toyota dealership? I appreciate any insight that you all may provide!
BTW I am new to this forum, so forgive me if this has been posted.
Hey man welcome,
DO NOT go waste a bunch of money having the dealer program it. I got a spare flip key for $15 off ebay and had a local lock shop cut it to my master key. If you search the forum you can easily find the programming procedure. It took me ten minutes to do both procedures. Total cost 17 and some change. Save your money for beer hahah this is all assuming you have the master(should be the black key with toyota logo)
05-02-2020, 10:33 PM
#27
I tried to program a new (used) OEM fob today using these instructions and failed time and again. Each time I get through the steps and hit LOCK to confirm programming, the car locks/unlocks twice to indicate the fob did not program correctly.
I also tried clearing all the fobs registered with the car, then programming this one first. No dice. I was able to get my original fob reprogrammed correctly, so I'm sure I'm doing the process correctly.
Of note the seller I got this from on ebay suggested I buy a fob that has the same FCC ID on the back, which I made sure to do. After my first round of failures I tried changing the battery in the fob, which had no effect.
Anyone have an idea what might be going on here?
06-19-2022, 02:08 PM
#28
Any luck?
I also have the doomed 2 cycle door lock after program(did not register). I’ve tried several other strategies I’ve seen online, with no success.
06-19-2022, 02:32 PM
#29
So you may be running into an issue I see occasionally, specifically that the vehicle is already programmed for the maximum number of keys/remotes.
In those cases I will verify with the customer that they have provided ALL the keys/keyfobs they own & wish to have programmed to the vehicle. Then you'll start with the "Delete all registered fobs" step to wipe the memory and start from scratch (if you're doing keys you at least one Master key (Black Key, not a Grey Valet Key), then just follow the steps for registering new keys/fobs.
I will say though that I have had a lot of hit & miss with aftermarket keyfobs and keys, I don't know what it is... but they can be really finicky.
Also make sure all your door lock actuators function properly, if you have one or more that are intermittent then you're not going to be able to do this process. You can also probably have a locksmith do it for you on the cheap as they usually have a small scantool to use as a back-up if the "manual" method doesn't work.
06-20-2022, 10:23 AM
#30
Originally Posted by kmathe7
Any luck?
i also bought some off of ebay and i can get the truck into program mode, but never saves the FOB settings, i tried to erase previous fobs and no luck as well.
