Originally Posted by Jonny_04
looking for some guidance here; i will be installing the following suspension components and upgrading my tires. Will the tires interfere with my uca without having to run wheel spacers? trying to save some dollars and keep my stock wheels util i decide on what aftermarket wheels to purchase.
-King Shocks front/rear w/adjusters; lift front 2.5" rear 2.0"
-Total Chaos uca
-Icon 2" rear coil
-Nitto Ridge Grapplers 285/70/17
What kind of wheels? You might need to do body mount chop with those tires, the Ridge Grapplers are a wider tire in compared to others in the hybrid class. I run same size tires on Methods 17x8.5 0 offset would rub only extreme flex. Now body mount chopped and added body lift no rub at all.
285/70 is about 33 inches tall, 11.3+ inches wide
Btw just heads up but you should ask the guys in the 5th gen threads since they would know more about spacing on your 5th gen.
