A10MileHusker, Co.Ag.2005
Thread Tools Rating: Thread Rating: 41 votes, 4.68 average. Display Modes
Old 03-21-2020, 07:53 PM #7111
Drift Monkey's Avatar
Drift Monkey Drift Monkey is offline
Drift Monkey is just really nice Drift Monkey is just really nice Drift Monkey is just really nice Drift Monkey is just really nice Drift Monkey is just really nice
Originally Posted by cwilliams563 View Post
Bilstein 5100’s with the front set at 0. Front has Toytec Eibach springs with 1/2” aluminum spacer on driver side and 1/4” passenger. Rear Bilstein 5100’s with Toytec super flex.
I’d bought an OME .40” spacer for the rear too (couldn’t find 1/4”) but seemed too thick so I chose not to put it in. Not sure if it will matter with only adjusting for driver side lean on the front and not the rear? At some point I may sand down the spacer to 1/4” and throw it in the rear if possible.
Level 8 gunmetal grey wheels, 0 offset (thank you to Drift Monkey for the suggestion, I like them) with TRD center caps. I gained close to 1.75” negative offset with the new wheels if my math is correct, either way they definitely protrude more. Falken Wildpeak 275/70/17. Pushed the fender liners forward on the front and removed the front mud flaps to stop tire rubbing.
Lookin' real good man! Glad I could help you pick wheels!
2006 4Runner Sport Edition V8 4WD
Drift Monkey is offline   Reply With QuoteReply With Quote
Old 03-28-2020, 07:17 PM #7112
rhoyneriver rhoyneriver is offline
rhoyneriver is on a distinguished road
Originally Posted by PINORNR View Post
17x9 RRW wheels with -12 offset. I rub a bit so I got an Eibach lift kit that will be installed this week or next.
were you stock ride height when you installed the 17x9 with 265/70/17? just removed mud flaps?
I'm doing the same this next week (once they're delivered) and just wanna make sure they'll fit for the interim before I get a lift kit. thanks!
2008 4Runner Limited 4x4 -- MK7 GTI Autobahn -- C6 Corvette 6-speed
rhoyneriver is offline   Reply With QuoteReply With Quote
Old 03-29-2020, 12:24 AM #7113
06_dark_knight 06_dark_knight is offline
Real Name: Mario
06_dark_knight is on a distinguished road
Real Name: Mario
I have 265 70 17’s on when I was stock for over 3 years with no rubbing but I feel like everyone has a different story to tell. Good luck!
06_dark_knight is offline   Reply With QuoteReply With Quote
Old 03-29-2020, 09:02 AM #7114
good to know, thanks! if nothing else, it'll give me an excuse to finally fix the factory rake
Old 03-30-2020, 11:47 AM #7115
Arcturus08's Avatar
Arcturus08 Arcturus08 is offline
Real Name: Derek
Arcturus08 is on a distinguished road
Arcturus08's Avatar
Real Name: Derek
Originally Posted by SoCal35 View Post
Stock suspension was shot so I went with a budget lift. Bilstein 5100's and OME 885/895. BFG KO2 285/70R17 on 17x9.
Did you have to do a body mount chop?
I have a similar setup and looking at upgrading wheels/tires. Once my new LCAs get in and can get it aligned. D@mn frozen cam bolts!
Thanks,
Tojo - 2006 V8 Sport 4x4 - Pioneer 2500NEX iDatalink Maestro
Bilstein 5100 - OME 885 - SuperFlex RCC2.0-P
Arcturus08 is offline   Reply With QuoteReply With Quote
Old 03-31-2020, 05:08 PM #7116
PINORNR's Avatar
PINORNR PINORNR is offline
PINORNR is on a distinguished road
PINORNR's Avatar
To add to what DarkKnight put, I do rub even after the mud flap removal. Nothing a bit a trimming couldn't fix but went with a lift kit instead. With everything going on, I've yet to install it. I will soon and report back.
PINORNR is offline   Reply With QuoteReply With Quote
Old 04-01-2020, 05:34 PM #7117
SoCal35 SoCal35 is offline
SoCal35 is on a distinguished road
Thanks,
Ooh that sucks! PB Blaster didn't help loosen them? I haven't done the BMC yet. I do plan to do it eventually. So far, I've only been using the 4R for going to and from work and running errands.
SoCal35 is offline   Reply With QuoteReply With Quote
Old 04-02-2020, 12:36 AM #7118
Silver Stallion's Avatar
Silver Stallion Silver Stallion is offline
Silver Stallion is on a distinguished road
Finally got my lift so I thought I'd share. Not many 4th gens seem to have this kit on the forum from the research I've done. Most of the info is on the 5th Gen forum.
2004 SR5 V8, Eibach Pro Truck Lift, Stage 1 Kit. Front and rear springs + shocks. 2.5" front, 1" Rear. 10mm trim packer for drivers side lean. 12% stiffer than stock, great on and offroad performance. Made to work with all stock components.
Tires are 275/70/16 BFG KO2, 31" D Rated, 8 Ply. I have not seen anyone on here with this tire size either, not as common but I went for the wider tire.
2004 SR5 V8, 275/70/16 KO2's, Eibach Pro Lift, JBA UCA, SuperPro LCA, DT Headers.
Silver Stallion is offline   Reply With QuoteReply With Quote
Old 04-02-2020, 08:30 PM #7119
Heffernan's Avatar
Heffernan Heffernan is offline
Heffernan will become famous soon enough
Heffernan's Avatar
Did you add the 10mm trim packer just to the front?
2008 Toyota 4Runner Sport V6
5100s / front 4x4 FJ springs / OEM stock rear springs
ToyTec 1/4" topout spacer & OME 10mm trim packer (both driver side)
General Grabber AT2 tires
Heffernan is offline   Reply With QuoteReply With Quote
Old 04-02-2020, 09:40 PM #7120
The OME trim packer is for the rear, it fits on top of the bump stop. It gives about 1/2 inch of lift to compensate for the lean from the gas tank.
Old 04-03-2020, 05:49 PM #7121
T4RDirt's Avatar
T4RDirt T4RDirt is offline
Real Name: Devo
T4RDirt is on a distinguished road
T4RDirt's Avatar
Real Name: Devo
Had the lift for 2 years (maybe i dont remember)
Dobinsons 3"
17" FJ/T4R 8 Holes +15mm Offset
285/70/17 Kenda Klever RT
Love the way it rides now with the bigger/heavier tires.
First Picture is after the lift with original tires and wheels (265/70/17 G2s)
Sent from my ONEPLUS A6013 using Tapatalk
T4RDirt is offline   Reply With QuoteReply With Quote
Old 04-06-2020, 04:04 PM #7122
TDrew TDrew is offline
TDrew is on a distinguished road
Dobinsons 3"
How do you like the Klevers? I've been eyeing those for a while. Very affordable. Any issues on highway? And I assume you are running wheel spacers to get that stance?
TDrew is offline   Reply With QuoteReply With Quote
Old 04-06-2020, 04:05 PM #7123
hinmo24t hinmo24t is offline
hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough
somewhat recently i saw someone raving about those Kenda MTs...liked more than big name brands
hinmo24t is offline   Reply With QuoteReply With Quote
Old 04-07-2020, 07:37 PM #7124
thedus thedus is offline
thedus is on a distinguished road
Ironman 4x4 Foam Cell Pro with SPC Uppers and 285/70/17 Falkens on SCS F5's 17x8.5 w/-10 offset.
Lift and Tire Central (pics)... Post 'em Up!-img_20200226_144253-jpg
Lift and Tire Central (pics)... Post 'em Up!-img_20200225_091950-jpg
Lift and Tire Central (pics)... Post 'em Up!-img_20200226_144240-jpg
Lift and Tire Central (pics)... Post 'em Up!-img_20200225_092001-jpg
thedus is offline   Reply With QuoteReply With Quote
Old 04-08-2020, 04:48 PM #7125
tamagucci tamagucci is offline
tamagucci is on a distinguished road
Wheel/Tire Fitment advice
Hi all, I just recently lifted my '07 v6 using Bilstein 5100s in conjunction with OME 884s in the front and Toytec superflex coils in the rear. It gave me almost 3 inches of lift!
I want to purchase 17' wheels but am unsure with all the different size options. I was hoping the wheels would have a little wider stance than stock to make up for the rise in center of gravity. (without using wheel spacers)
of these two options (or if you have other suggestions I am open) which would be "further out" and also not rub? I don't want to cut anything.
17x8.5 6x5.5, 0 offset, 4.75 backspace
17 X 8.56 X 139.7, -10mm offset, 4.30 backspace
Also tire suggestions would help immensely.
I have been doing research but it's kind of an emergency because one of my tires is leaky and I really don't want to buy another 18" tire if I can help it.
I would have started a separate thread, but I only have one active post, my apologies.
tamagucci is offline   Reply With QuoteReply With Quote
Lift/Tire/Wheel central Asaspades93 3rd gen T4Rs 75 07-13-2018 04:23 PM
need pics of a specific lift/tire combo Token13 4th Gen T4Rs 3 05-09-2014 09:37 PM
Bigger Tire Pics / No Lift agjake01 5th gen T4Rs 6 03-20-2013 07:28 AM
Post PICS of your 3rd Gen with a Daystar lift and/or 265/75 RdRunNNeR Maryland / Virginia / WV / D.C. 0 03-01-2013 09:17 AM
please post pics of your 2nd gen with OME lift w/32's 4x4dad Classic T4Rs 15 05-02-2012 01:22 AM
