04-08-2020, 09:13 PM
#7126
Originally Posted by tamagucci
Hi all, I just recently lifted my '07 v6 using Bilstein 5100s in conjunction with OME 884s in the front and Toytec superflex coils in the rear. It gave me almost 3 inches of lift!
I want to purchase 17' wheels but am unsure with all the different size options. I was hoping the wheels would have a little wider stance than stock to make up for the rise in center of gravity. (without using wheel spacers)
of these two options (or if you have other suggestions I am open) which would be "further out" and also not rub? I don't want to cut anything.
17x8.5 6x5.5, 0 offset, 4.75 backspace
17 X 8.56 X 139.7, -10mm offset, 4.30 backspace
Also tire suggestions would help immensely.
I have been doing research but it's kind of an emergency because one of my tires is leaky and I really don't want to buy another 18" tire if I can help it.
I would have started a separate thread, but I only have one active post, my apologies.
I don't have an opinion on the backspacing questions but got pics of the new setup? I'm looking at the same configuration. Also tire-wise, been running Falken Wildpeaks with zero regrets.
04-08-2020, 10:03 PM
#7127
I would go with 0 offset and at most 275's
Sent from my SM-G986U using Tapatalk
04-09-2020, 03:06 AM
#7128
I went with level 8 MK6 17x8 with 0 offset wheels and 275/70/17” Falken Wilpeak A/T W3 tires. The 0 offset stick out a fair amount over stock since the stock are + offsets. I went with Bilstein 5100’s, Eibach front springs, and 1/2” spacer on top. Gave me about 3” and I Still rubbed pretty good on front turning past halfway. I had to remove my mud flaps and trim/push my fender well liners forward. The wider the tires stick out the more you’ll rub as it was the outside of tire that was mainly rubbing.
I still get a little bit of rubbing while turning when I gun it a little or on big bumps. I haven’t looked anymore into it but now it’s probably my front lower fender and may have be to trimmed a bit more. I did NOT want to trim anything either but it’s the nature of it and comes with the territory apparently. Trimming the fender well liner and pushing forward was easy and no big deal, unless you really look inside it would be hard to notice. If you don’t want to rub then be conservative on your tire size. Mine wasn’t significant by any means, only 1 size up in width and height.
My build thread https://www.toyota-4runner.org/4th-g...ml#post3520544
2008 Titanium Metallic 4WD 4Runner V6 SR5| Satoshi Grille mod|17x8 Level 8 MK6 wheels, 275/70/17" Falken Wildpeak tires| Front-Bilstein 5100's set at 0 with ToyTec branded Eibach silver springs and 1/2" ToyTec spacer driver side, 1/4" ToyTec spacer passenger|Front Diff. drop spacer kit|sway bar relocate kit| Rear-Fox 2.0Resi and ToyTec superflex black springs|Tyger Bull bar with LED's/Lund HX tube side steps
2021 Subaru Crosstrek Limited in Crystal White Pearl
04-10-2020, 11:50 PM
#7129
Not sure if I'm cool enough to have my own thread but...
Before:
After:
2006 4Runner Sport Edition V8 4WD
04-11-2020, 12:00 AM
#7130
Registered User
Real Name: Morris
Registered User
Real Name: Morris
Looks really good!
04-11-2020, 12:07 AM
#7131
Originally Posted by momo.75
Looks really good!
Thanks bud! I now feel like I'm in the cool kids club!
04-11-2020, 01:01 AM
#7132
Real Name: Seth
Real Name: Seth
2006 Shadow Mica SR5 v6 1" BL, Fox Racing UCA's, RC 3" N3 Lift, Rock Trix RT110 -12 Wheels, 315/70R17 Goodyear Territory MT, Tacoma Front Bumper, 5th Gen 4R Tire Carrier, Big Lion LED's
04-11-2020, 05:15 AM
#7133
Before:
After:
I always like the look of these wheels on 4th gens. Like they were meant to be.
Also what size tires? They look BEEF!
04-11-2020, 05:50 AM
#7134
Me too, really happy with how they turned out - cheap too!
295/70R17
04-11-2020, 08:01 AM
#7135
Originally Posted by MrSeth
What read bumper do you have?
04-11-2020, 04:25 PM
#7136
After:
Nice
Are those like 2017-19 TRD Off Road wheels?
2006 SportEdition V8 | 2009 Honda Accord EX-L
04-11-2020, 05:11 PM
#7137
Originally Posted by DirtySouth89
Nice
Sure are! I'm pretty sure they were off a '19 or '20, the owner changed em out for the black TRD Pro wheels so these were never used. Got 'em for a good price!
04-11-2020, 05:22 PM
#7138
Oh and by the way... nice Mr. Saturn. Love that game.
04-11-2020, 05:37 PM
#7139
Thanks for all the replies guys, sorry I'm so late to respond...
Here is a crappy pic with stock wheels, I will post some better ones but perhaps I'll wait until I get the wheels and tires.
04-11-2020, 05:48 PM
#7140
A man after my own heart. Shouldn't be surprised we DIRTY SOUF bros!
