A10MileHusker, Co.Ag.2005
Thread Tools Rating: Thread Rating: 41 votes, 4.68 average. Display Modes
Old 01-12-2021, 03:57 PM #7486
Bikeric's Avatar
Bikeric Bikeric is offline
Real Name: Eric
Bikeric will become famous soon enough Bikeric will become famous soon enough
Bikeric's Avatar
Real Name: Eric
Originally Posted by thight View Post
Love that blue!
Thanks!! Here it is next to the same color Tundra RCSB. Nautical Blue FTW!!
1984 SR5, 1989 DLX, 2011 SR5 4wd
Bikeric is offline   Reply With QuoteReply With Quote
Old 01-12-2021, 07:32 PM #7487
FXFRunner FXFRunner is offline
FXFRunner is on a distinguished road
Originally Posted by Bassturd View Post
I did the Toytec Ultimate 3” on my 04 V8
the stuff on top between the nut and the suspension well.. i didnt use those... how important are they? mine just went coilover in nut on top done..
2007 V8 Limited / Toytec & Bilstein 3 inch lift
FXFRunner is offline   Reply With QuoteReply With Quote
Old 01-12-2021, 07:46 PM #7488
montijo505's Avatar
montijo505's Avatar
Post a photo so we know what you're talking about
Sent from my SM-G986U using Tapatalk
Old 01-12-2021, 08:44 PM #7489
timothylynn7 timothylynn7 is offline
timothylynn7 is on a distinguished road
Originally Posted by DASYOTA View Post
Just got some vision manx 2 and 285/70/17 Toyo open country At III's put on. Had to do some trimming. Alignment almost back in spec with stock UCA's at Firestone Tech said.
5100's all around set to bottom. 885 in front, superflex in rear. Almost want to put a top plate spacer to bring the front up a bit more, idk yet. What do you guys think is that a good idea.
IMG-20201202-211236-706
Looks good. Little rake in the front
timothylynn7 is offline   Reply With QuoteReply With Quote
Old 01-12-2021, 08:48 PM #7490
Originally Posted by aemravan View Post
Did some trail testing this weekend with the 35s. They sruff nicely in the rear with no rubbing after my home made 2"bump stop extensions and cleared decently with minor frame and uca rubbing at full lock up front.
Sent from my SM-G970U using Tapatalk
Looks like Ma Bell. You in Mass?
Old 01-12-2021, 09:41 PM #7491
aemravan aemravan is offline
aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute
Naw, this is in North Carolina at the Uwharrie national forest.
aemravan is offline   Reply With QuoteReply With Quote
Old 01-13-2021, 12:25 AM #7492
momo.75's Avatar
momo.75 momo.75 is offline
Registered User
Real Name: Morris
momo.75 has much to be proud of momo.75 has much to be proud of momo.75 has much to be proud of momo.75 has much to be proud of momo.75 has much to be proud of momo.75 has much to be proud of momo.75 has much to be proud of momo.75 has much to be proud of
Registered User
momo.75's Avatar
Real Name: Morris
Any BL?
momo.75 Build ThreadClick to order T4R.ORG Decals • @urban_overland
momo.75 is offline   Reply With QuoteReply With Quote
Old 01-18-2021, 12:21 PM #7493
702tripgen 702tripgen is offline
702tripgen is on a distinguished road
Ome 895e springs rear with 5100 shocks and 5100s on 3rd setting with factory coils on front. 265/70/17 ko2s.
Alignment after lift:
2005 Limited 4X4 V8 36,000 original miles. 265/70/17 BFG KO2s, Front: Bilstein 5100s set to 3rd perch with stock springs. Rear: OME 895E springs and driver OME trim packer driver side with 5100 shocks. 2" overall lift.
702tripgen is offline   Reply With QuoteReply With Quote
Old 01-20-2021, 02:55 AM #7494
yourfriendcasey's Avatar
yourfriendcasey yourfriendcasey is offline
yourfriendcasey is on a distinguished road
Eibach Pro 3” lift kit w/ Raceline clutch 17x9 wheels, RBP M/S 285/70r/17 tires.
Had to do some trimming/ bang down pinch weld because of rubbing in front and back, rarely get rubbing anymore.
05 v8 Limited - Eibach Pro Lift Kit 3" Front, Ironman foam cell pro w/ 3" mid weight coils Rear - JBA High Caster UCAs - Coastal Offroad High Clearance Rear Bumper w/ Dual Swingarms - Toyo Open Country ATIII 285/70/17 - Bronze Raceline Clutch 17x9 Wheels - Raptor Liner Paint - Front Sway Bar Delete - Extended Rear Sway Bar Links - Rear Diff Breather - RCI 1/4" Aluminum Front Skid - Cali Raised DOM Rock Sliders
yourfriendcasey is offline   Reply With QuoteReply With Quote
Old 01-20-2021, 01:45 PM #7495
newton22 newton22 is offline
newton22 will become famous soon enough
Originally Posted by newton22 View Post
My rear springs are stock right now. I probably gained about 2.5-3" mainly because my stock fronts were lower than stock. They were even a little lower than the V8 in the pic.
Update. My 883s have settled and are now lower than when I first installed them. So a ~1.75" gain from stock is accurate. Now I wish I had gone 884.
Lift and Tire Central (pics)... Post 'em Up!-img_20210110_125642-jpg
2004 SR5 4WD | 5100s | Level 8 MK6s
newton22 is offline   Reply With QuoteReply With Quote
Old 01-20-2021, 01:58 PM #7496
mkscrewy mkscrewy is offline
mkscrewy is on a distinguished road
how long have you had yours on the car? I'll measure mine and see if there's much difference as well. Been about 4 months here.
2004 v8 | bilstein 5100s | ome883 + wheelers t12 | 2013 FJ cruiser wheels
mkscrewy is offline   Reply With QuoteReply With Quote
Old 01-20-2021, 06:28 PM #7497
About 7 months/9000 mi
Old 01-23-2021, 07:57 PM #7498
NHToyo73 NHToyo73 is offline
Real Name: Jake
NHToyo73 is on a distinguished road
Real Name: Jake
Originally Posted by yourfriendcasey View Post
Digging the color
NHToyo73 is offline   Reply With QuoteReply With Quote
Old 01-28-2021, 02:02 PM #7499
Sausage_gut Sausage_gut is offline
Sausage_gut is on a distinguished road
I have a dobinsons IMS 2.5/1.5 lift and some Volk TE37s 16x8 -20 on the way but won’t be here until April and I’m gonna put 285/75 16 geolander g003 on it. I plan on bringing the family up to big bear this weekend and the stock tires weren’t
going to cut it so I swapped wheels and tires from my 06 Tacoma. All stock on 265/75 16 BFG KO2s and zero rubbing
Sausage_gut is offline   Reply With QuoteReply With Quote
Old 01-29-2021, 11:13 AM #7500
TLar25's Avatar
TLar25 TLar25 is offline
Real Name: Taylor
TLar25 will become famous soon enough TLar25 will become famous soon enough
TLar25's Avatar
Real Name: Taylor
Looks good. Lucky your limited didn't come with the optional bigger sport brake package.
Sent from my KB2007 using Tapatalk
1985, 22re, 5spd, 4x4, Marlin crawler dual transfer case, locked fr&rr, 35's
1996, 5vz-fe, Auto, 4x4, Bilstein/ome lift, tundra 17's, 33's
Sold(regret it)- 1999 Highlander edition, Auto 4x4, 3"lift, factory rear locker
TLar25 is offline   Reply With QuoteReply With Quote
Lift/Tire/Wheel central Asaspades93 3rd gen T4Rs 75 07-13-2018 04:23 PM
need pics of a specific lift/tire combo Token13 4th Gen T4Rs 3 05-09-2014 09:37 PM
Bigger Tire Pics / No Lift agjake01 5th gen T4Rs 6 03-20-2013 07:28 AM
Post PICS of your 3rd Gen with a Daystar lift and/or 265/75 RdRunNNeR Maryland / Virginia / WV / D.C. 0 03-01-2013 09:17 AM
please post pics of your 2nd gen with OME lift w/32's 4x4dad Classic T4Rs 15 05-02-2012 01:22 AM
