A10MileHusker, Co.Ag.2005
Thread Tools Rating: Thread Rating: 41 votes, 4.68 average. Display Modes
Old 02-25-2024, 05:06 PM #7906
YotaRunner008 YotaRunner008 is offline
YotaRunner008 is on a distinguished road
Originally Posted by alhang View Post
OME 886/898 springs 1/4 front poly spacers, bilstein 5100's, rear sway connectors from 2nd gen, only rubs the front mud flaps which I'll take off soon. camber and toe aligned fine with stock uca, loss of caster, but at least tires won't wear unevenly.
If it's over 2.5" you need adjustable uca, to properly align the vehicle or uca that have the camber/caster build into them. I have seen way too many people come into my shop and say they don't need them until we show them why and the damage it is doing
YotaRunner008 is offline   Reply With QuoteReply With Quote
Old 02-25-2024, 05:21 PM #7907
Originally Posted by nr0974 View Post
Did mine over the weekend got everything done excepted the from brakes due to receiving the wrong Rotors. I HATE the whole 319mm and 338mm rotor thing. I was wondering are the OEM Springs worth anything?
338mm came on the sports only, don't know about the urbanrunner
Old 02-25-2024, 05:23 PM #7908
Possibly the limited but I haven't installed any drilled n slotted on limiteds, I have owned 2 sports at once n most that come in the shop are SR5s
Old 02-25-2024, 05:41 PM #7909
Originally Posted by MrSeth View Post
Found some old photos from 2015 when I upgraded my 4Runner from a Daystar spacer lift to a Rancho RS9000XL QuickLift. It was a fun project for me one day after work at the Mercedes/Porsche shop I worked for at the time. Look how much thicker the Rancho's are than the OEM!!!!
From what I have seen you will be warranting them out in a year or two
Old 02-25-2024, 06:03 PM #7910
Originally Posted by kcdehart View Post
I honestly like the E's more on pavement. They keep the handling sharp despite being large tires. I had a friend that daily's an S2000 comment on how much he liked the turn-in when he drove it On the other hand, a friend of mine has C load Grabbers on his Forester and absolutely hates how sloppy they feel.
Thanks! Did the work myself on a friend's lift with air tools. Took us about 7 hours (30 mins of which was a wheel bearing - surprisingly the easiest part). I'd hit everything with PB blaster the day before and expect the endlinks to be a *****-and-a-half to remove. The top rear bolts on the front struts are also a pain. The strut tophat will also sometimes seize to the piece it goes into. That took us a solid hour of banging at to remove.
I think it could be done without a lift - would just be a bit more uncomfortable. I wouldn't try it without an impact though.
As for UCA's, I'm gonna replace them whenever my upper ball joints go bad. For the time being, they're alright. I do still need to get it aligned, though (shame on me).
I went with 2nd gen endlinks on the rear to get a bit more droop. I left the front stock though, as I'm worried about my CV's binding. A diff drop/new skid that accommodates it will be coming in the future.
Hit me up sometime if you wanna head offroad!
Yes u have an old post but guaranteed your upper ball joints are bad, the only way to test them is with a big ass pair of vise grips or pliers to compress to look to slack.
Old 02-28-2024, 11:15 PM #7911
MrSeth's Avatar
MrSeth MrSeth is offline
Real Name: Seth
MrSeth is a jewel in the rough MrSeth is a jewel in the rough MrSeth is a jewel in the rough MrSeth is a jewel in the rough
MrSeth's Avatar
Real Name: Seth
I ended up running them for about 2.5-3 years before switching to Bilstein 5100s. They rode okay, but the adjusters broke off pretty early on. I won't go back to Rancho's on my current build lol. When I did that lift, I was super super new to the offroad world and went to 4Wheel Parts and they said it was the only lift made for the 4th gen
2006 Shadow Mica SR5 v6
1" BL, Fox Racing UCA's, RC 3" N3 Lift, Rock Trix RT110 -12 Wheels, 315/70R17 Goodyear Territory MT, Tacoma Front Bumper, 5th Gen 4R Tire Carrier, Big Lion LED's
MrSeth is offline   Reply With QuoteReply With Quote
Old 03-08-2024, 10:08 PM #7912
Originally Posted by jlaw904 View Post
I have not lifted yet, but I thought this would be useful info. I got these Falken Wildpeak ATW/3's on my 2008 and contrary to a lot of what I read, I still had to make some modifications to fit. They are 265/70R17. They required trimming the front bumper and moving the liner forward. And behind the front tire required hammering and bending the pinch weld behind the mudflap. May not be required with the lift.
Your front suspension is completely collapsed! Upgrade already, I have worn out suspension but mine is not that bad, 174k on mine factory suspension no leaks 08 sport run same tore size no rubbing except fully locked n going over a bump
Old 03-20-2024, 01:05 AM #7913
TLar25's Avatar
TLar25 TLar25 is offline
Real Name: Taylor
TLar25 will become famous soon enough TLar25 will become famous soon enough
TLar25's Avatar
Real Name: Taylor
Originally Posted by T4rcruznn View Post
05 4Runner icon 2.5 with resis all around spc upper arms dobinson 677v rear springs with 17x8.5 advan rg-d2 wrapped with 315/70/17 Falken wildpeaks trai gear adapters and super bump stops front and rear with extensions and BMC
That rear bumper job looks cleeaan Lift and Tire Central (pics)... Post 'em Up!
Sent from my SM-G975U using Tapatalk
1985, 22re, 5spd, 4x4, Marlin crawler dual transfer case, locked fr&rr, 35's
1996, 5vz-fe, Auto, 4x4, Bilstein/ome lift, tundra 17's, 33's
Sold(regret it)- 1999 Highlander edition, Auto 4x4, 3"lift, factory rear locker
TLar25 is offline   Reply With QuoteReply With Quote
Old 03-22-2024, 09:54 AM #7914
locked up's Avatar
locked up locked up is offline
locked up is on a distinguished road
locked up's Avatar
Originally Posted by Jpicar681 View Post
Just got the grill and very happy with the end result
What lift, tires, wheels, spacers are you running?
Any rubbing?
Any cutting?
I really like this.
locked up is offline   Reply With QuoteReply With Quote
Old 04-20-2024, 12:23 PM #7916
Richmasse Richmasse is online now
Richmasse is on a distinguished road
Sweetnesa
Richmasse is online now   Reply With QuoteReply With Quote
Lift/Tire/Wheel central Asaspades93 3rd gen T4Rs 75 07-13-2018 04:23 PM
need pics of a specific lift/tire combo Token13 4th Gen T4Rs 3 05-09-2014 09:37 PM
Bigger Tire Pics / No Lift agjake01 5th gen T4Rs 6 03-20-2013 07:28 AM
Post PICS of your 3rd Gen with a Daystar lift and/or 265/75 RdRunNNeR Maryland / Virginia / WV / D.C. 0 03-01-2013 09:17 AM
please post pics of your 2nd gen with OME lift w/32's 4x4dad Classic T4Rs 15 05-02-2012 01:22 AM
