A10MileHusker, Co.Ag.2005
Thread Tools Rating: Thread Rating: 41 votes, 4.68 average. Display Modes
Old 04-08-2020, 09:13 PM #7126
eleven14 eleven14 is offline
eleven14 has a spectacular aura about eleven14 has a spectacular aura about
Originally Posted by tamagucci View Post
Hi all, I just recently lifted my '07 v6 using Bilstein 5100s in conjunction with OME 884s in the front and Toytec superflex coils in the rear. It gave me almost 3 inches of lift!
I want to purchase 17' wheels but am unsure with all the different size options. I was hoping the wheels would have a little wider stance than stock to make up for the rise in center of gravity. (without using wheel spacers)
of these two options (or if you have other suggestions I am open) which would be "further out" and also not rub? I don't want to cut anything.
17x8.5 6x5.5, 0 offset, 4.75 backspace
17 X 8.56 X 139.7, -10mm offset, 4.30 backspace
Also tire suggestions would help immensely.
I have been doing research but it's kind of an emergency because one of my tires is leaky and I really don't want to buy another 18" tire if I can help it.
I would have started a separate thread, but I only have one active post, my apologies.
I don't have an opinion on the backspacing questions but got pics of the new setup? I'm looking at the same configuration. Also tire-wise, been running Falken Wildpeaks with zero regrets.
eleven14 is offline   Reply With QuoteReply With Quote
Old 04-08-2020, 10:03 PM #7127
montijo505's Avatar
montijo505's Avatar
I would go with 0 offset and at most 275's
Sent from my SM-G986U using Tapatalk
Old 04-09-2020, 03:06 AM #7128
cwilliams563's Avatar
cwilliams563 cwilliams563 is offline
cwilliams563 has a spectacular aura about cwilliams563 has a spectacular aura about cwilliams563 has a spectacular aura about
I went with level 8 MK6 17x8 with 0 offset wheels and 275/70/17” Falken Wilpeak A/T W3 tires. The 0 offset stick out a fair amount over stock since the stock are + offsets. I went with Bilstein 5100’s, Eibach front springs, and 1/2” spacer on top. Gave me about 3” and I Still rubbed pretty good on front turning past halfway. I had to remove my mud flaps and trim/push my fender well liners forward. The wider the tires stick out the more you’ll rub as it was the outside of tire that was mainly rubbing.
I still get a little bit of rubbing while turning when I gun it a little or on big bumps. I haven’t looked anymore into it but now it’s probably my front lower fender and may have be to trimmed a bit more. I did NOT want to trim anything either but it’s the nature of it and comes with the territory apparently. Trimming the fender well liner and pushing forward was easy and no big deal, unless you really look inside it would be hard to notice. If you don’t want to rub then be conservative on your tire size. Mine wasn’t significant by any means, only 1 size up in width and height.
My build thread https://www.toyota-4runner.org/4th-g...ml#post3520544
2008 Titanium Metallic 4WD 4Runner V6 SR5| Satoshi Grille mod|17x8 Level 8 MK6 wheels, 275/70/17" Falken Wildpeak tires| Front-Bilstein 5100's set at 0 with ToyTec branded Eibach silver springs and 1/2" ToyTec spacer driver side, 1/4" ToyTec spacer passenger|Front Diff. drop spacer kit|sway bar relocate kit| Rear-Fox 2.0Resi and ToyTec superflex black springs|Tyger Bull bar with LED's/Lund HX tube side steps
2021 Subaru Crosstrek Limited in Crystal White Pearl
cwilliams563 is offline   Reply With QuoteReply With Quote
Old 04-10-2020, 11:50 PM #7129
Drift Monkey's Avatar
Drift Monkey Drift Monkey is offline
Drift Monkey is just really nice Drift Monkey is just really nice Drift Monkey is just really nice Drift Monkey is just really nice Drift Monkey is just really nice
Not sure if I'm cool enough to have my own thread but...
Before:
After:
2006 4Runner Sport Edition V8 4WD
Drift Monkey is offline   Reply With QuoteReply With Quote
Old 04-11-2020, 12:00 AM #7130
momo.75's Avatar
momo.75 momo.75 is offline
Registered User
Real Name: Morris
momo.75 has much to be proud of momo.75 has much to be proud of momo.75 has much to be proud of momo.75 has much to be proud of momo.75 has much to be proud of momo.75 has much to be proud of momo.75 has much to be proud of momo.75 has much to be proud of
Registered User
momo.75's Avatar
Real Name: Morris
Looks really good!
momo.75 Build ThreadClick to order T4R.ORG Decals • @urban_overland
momo.75 is offline   Reply With QuoteReply With Quote
Old 04-11-2020, 12:07 AM #7131
Originally Posted by momo.75 View Post
Looks really good!
Thanks bud! I now feel like I'm in the cool kids club!
Old 04-11-2020, 01:01 AM #7132
MrSeth's Avatar
MrSeth MrSeth is offline
Real Name: Seth
MrSeth is a jewel in the rough MrSeth is a jewel in the rough MrSeth is a jewel in the rough MrSeth is a jewel in the rough
MrSeth's Avatar
Real Name: Seth
just "poking" around.
20200406_154144
20200409_140231
2006 Shadow Mica SR5 v6
1" BL, Fox Racing UCA's, RC 3" N3 Lift, Rock Trix RT110 -12 Wheels, 315/70R17 Goodyear Territory MT, Tacoma Front Bumper, 5th Gen 4R Tire Carrier, Big Lion LED's
MrSeth is offline   Reply With QuoteReply With Quote
Old 04-11-2020, 05:15 AM #7133
montijo505's Avatar
montijo505's Avatar
Before:
After:
I always like the look of these wheels on 4th gens. Like they were meant to be.
Also what size tires? They look BEEF!
Old 04-11-2020, 05:50 AM #7134
Me too, really happy with how they turned out - cheap too!
295/70R17
Old 04-11-2020, 08:01 AM #7135
Timtim Timtim is offline
Timtim is on a distinguished road
20200406_154144
20200409_140231
What read bumper do you have?
Timtim is offline   Reply With QuoteReply With Quote
Old 04-11-2020, 04:25 PM #7136
DirtySouth89's Avatar
DirtySouth89 DirtySouth89 is offline
DirtySouth89 will become famous soon enough
After:
Nice
Are those like 2017-19 TRD Off Road wheels?
2006 SportEdition V8 | 2009 Honda Accord EX-L
DirtySouth89 is offline   Reply With QuoteReply With Quote
Old 04-11-2020, 05:11 PM #7137
Originally Posted by DirtySouth89 View Post
Nice
Sure are! I'm pretty sure they were off a '19 or '20, the owner changed em out for the black TRD Pro wheels so these were never used. Got 'em for a good price!
Old 04-11-2020, 05:22 PM #7138
Oh and by the way... nice Mr. Saturn. Love that game.
Old 04-11-2020, 05:37 PM #7139
tamagucci tamagucci is offline
tamagucci is on a distinguished road
Thanks for all the replies guys, sorry I'm so late to respond...
Here is a crappy pic with stock wheels, I will post some better ones but perhaps I'll wait until I get the wheels and tires.
Lift and Tire Central (pics)... Post 'em Up!-20200411_143134-jpg
tamagucci is offline   Reply With QuoteReply With Quote
Old 04-11-2020, 05:48 PM #7140
A man after my own heart. Shouldn't be surprised we DIRTY SOUF bros!
Lift/Tire/Wheel central Asaspades93 3rd gen T4Rs 75 07-13-2018 04:23 PM
need pics of a specific lift/tire combo Token13 4th Gen T4Rs 3 05-09-2014 09:37 PM
Bigger Tire Pics / No Lift agjake01 5th gen T4Rs 6 03-20-2013 07:28 AM
Post PICS of your 3rd Gen with a Daystar lift and/or 265/75 RdRunNNeR Maryland / Virginia / WV / D.C. 0 03-01-2013 09:17 AM
please post pics of your 2nd gen with OME lift w/32's 4x4dad Classic T4Rs 15 05-02-2012 01:22 AM
