A10MileHusker, Co.Ag.2005
Thread Tools Rating: Thread Rating: 41 votes, 4.68 average. Display Modes
Old 05-22-2020, 10:32 PM #7216
The-Wood The-Wood is offline
The-Wood is on a distinguished road
After all is said and done...
Front: OME 883 (+1/4 top spacer on driver)
Rear: Stock + 1" spacer (1/2" pass and 1" driver)
Bilstein 5100 all around
Hub to fender numbers:
Front: 21.25"
Rear: 22.5"
Running 275/70R17 BFG AT
As far as rubbing, only thing I did was push the front fender liner forward a bit. Alignment in spec with stock UCAs.
The-Wood is offline   Reply With QuoteReply With Quote
Old 05-23-2020, 08:08 AM #7217
Heffernan's Avatar
Heffernan Heffernan is offline
Heffernan will become famous soon enough
Heffernan's Avatar
Front: 21.25"
Rear: 22.5"
Looks great - what rear spacers did you end up using? Hard to find anything other then the 1.5" kit.
2008 Toyota 4Runner Sport V6
5100s / front 4x4 FJ springs / OEM stock rear springs
ToyTec 1/4" topout spacer & OME 10mm trim packer (both driver side)
General Grabber AT2 tires
Heffernan is offline   Reply With QuoteReply With Quote
Old 05-23-2020, 12:46 PM #7218
Cornfed.
Burtman Industries
You can custom order any size spacer from him too if you want. More expensive that a poly spacer but will last longer.
I would like to find some new coils for the rear, but cant find any that give a true 1" lift in the rear. Something with a little higher spring rate, but only 1".
Old 05-23-2020, 02:25 PM #7219
Grayed 0ut Grayed 0ut is offline
Real Name: Gray
Grayed 0ut is on a distinguished road
Real Name: Gray
Installed a set of bilstein 5100s all round (fronts set to max) with FJ coils in front and rear factory airbags in back (lifted with the sensor trick)
Tires are 275 65 18 Duratracs. I love how it sits now!
I tried adding 1" thick topout spacers on the front but it was too much and the coils caught on the UCA
Lift and Tire Central (pics)... Post 'em Up!-20200523_123656-jpg  Lift and Tire Central (pics)... Post 'em Up!-20200521_205901-jpg
Grayed 0ut is offline   Reply With QuoteReply With Quote
Old 05-23-2020, 03:36 PM #7220
Silver Stallion's Avatar
Silver Stallion Silver Stallion is offline
Silver Stallion is on a distinguished road
Cornfed.
Burtman Industries
The Eibach rear coils are a 1" rear lift, 12% stiffer than stock. I have them and they are great.
Part Number: E30-82-073-01-02
PRO-LIFT-KIT Springs (Rear Springs Only) - TOYOTA 4Runner 2WD/4WD w/X-REAS
2004 SR5 V8, 275/70/16 KO2's, Eibach Pro Lift, JBA UCA, SuperPro LCA, DT Headers.
Silver Stallion is offline   Reply With QuoteReply With Quote
Old 05-24-2020, 09:42 AM #7221
Syr4RinNC's Avatar
Syr4RinNC's Avatar
Cornfed.
Burtman Industries
Id also recommend looking at a 5th gen oem coil. That’s what I just went with. About an inch taller (one extra coil) and slightly stiffer than the 4th gen as the 5th is heavier. Plus being relatively newer will have less sag and more of its original height/ compression- rebound and physical characteristics
Plus they are easy to find for cheap
Old 05-24-2020, 12:53 PM #7222
But are they a true 1" coil? Wheeler said the T13 coil would only give me a 1/2" lift and the reality was 2".
Old 05-24-2020, 01:07 PM #7223
jrm's Avatar
jrm jrm is offline
jrm will become famous soon enough
jrm jrm is offline
jrm's Avatar
Dobinson..
Cornfed.
Burtman Industries
C59-323 rear coils. I know in the dobinson threat there listed a stock ride height but i gained a little over an inch. Im using the OE isolators as well.
I paired um with the dobinson shocks as well in the back and bilstein 6112s up front for a 2/1" lift. But im only on falken 265/70/17s so YMMV
jrm is offline   Reply With QuoteReply With Quote
Old 05-24-2020, 03:51 PM #7224
I think I got a true 1" but I don't remember my stock height numbers any more. I would have been happy with 1-2" but I wasn't too picky about checking the numbers. I'll let you know my hub to fender measurements tomorrow when I get a chance.
Old 05-25-2020, 12:25 PM #7225
SHagood's Avatar
SHagood SHagood is offline
SHagood is just really nice SHagood is just really nice SHagood is just really nice SHagood is just really nice
SHagood's Avatar
2008 Urban Runner
MY BUILD THREAD
SHagood is offline   Reply With QuoteReply With Quote
Old 05-25-2020, 03:06 PM #7226
Ebolavirus6 Ebolavirus6 is offline
Real Name: Tyler
Ebolavirus6 is on a distinguished road
Real Name: Tyler
I just picked up some 5100's I plan to install next weekend. Currently, I have a daystar 1'' leveling puck on the front and Im level at all 4 corners. I plan to set the 5100's to 2.5, which should increase the front height by about 0.5". To eliminate rear rake, I wanna raise the rears by about an inch.
I know my options are FJ, 5th gen and various aftermarket suppliers. I cant find fj or 5th gen springs near me, and everyone has different information about spring height change. Can anyone point me towards something yields roughly 1" rear lift?
Ebolavirus6 is offline   Reply With QuoteReply With Quote
Old 05-25-2020, 10:15 PM #7227
FJH195 FJH195 is offline
FJH195 is on a distinguished road
Originally Posted by SHagood View Post
Sweet looking rig!
2006 4Runner SE 4WD V6
FJH195 is offline   Reply With QuoteReply With Quote
Old 05-26-2020, 07:50 PM #7228
my69opelgt my69opelgt is offline
my69opelgt is on a distinguished road
3"/2" spacers
2007 sport edition SR5
197k miles
Stock tires (for now)
rough country spacer lift 3" front / 2" rear
XREAS DELETED
Bilstien 5100's
New front uca, lca, sbl, bushings
PLAN ON : 285/70/17 Mud Terrain tires
new hd coil springs in rear
Front and rear armor plus sliders
rear drawer system
roof rack/ solar setup
my69opelgt is offline   Reply With QuoteReply With Quote
Old 05-30-2020, 06:35 PM #7229
Sharkseed Sharkseed is offline
Sharkseed will become famous soon enough
Method NV 305 wheels
Just installed method NV 305 wheels them along with new headlights
Lift and Tire Central (pics)... Post 'em Up!-2ad359ad-6bd2-4748-8788-b38d297bbd77-jpeg
Sharkseed is offline   Reply With QuoteReply With Quote
Old 05-30-2020, 09:19 PM #7230
ajw1275 ajw1275 is offline
Real Name: Adam
ajw1275 is on a distinguished road
Real Name: Adam
Anyone run a lift with factory 2018 limited 20 inch rims on there 4th gen?
ajw1275 is offline   Reply With QuoteReply With Quote
Lift/Tire/Wheel central Asaspades93 3rd gen T4Rs 75 07-13-2018 04:23 PM
need pics of a specific lift/tire combo Token13 4th Gen T4Rs 3 05-09-2014 09:37 PM
Bigger Tire Pics / No Lift agjake01 5th gen T4Rs 6 03-20-2013 07:28 AM
Post PICS of your 3rd Gen with a Daystar lift and/or 265/75 RdRunNNeR Maryland / Virginia / WV / D.C. 0 03-01-2013 09:17 AM
please post pics of your 2nd gen with OME lift w/32's 4x4dad Classic T4Rs 15 05-02-2012 01:22 AM
