06-05-2020, 12:52 AM
#7231
2004 4Runner SR5
I put on an Icon Stage 7 lift (Thank you Black Friday sales). I had to do some adjustments to the front coil overs to get the ride height just right.
I put on Vision Nemesis wheels with Milestar Patagonia M/Ts in a 285/70R17.
I had some good rubbing with everything stock, but after some trimming, it stopped unless I was under decent compression while in a turn. I also did a body mount chop (just used some steel bar to fill the area I cut).
Overall, I am very happy with this, although it was a bit on the pricey side. I saved for almost a year to buy the lift, wheels, and tires.
I think that I could fit 35s in there if I wanted to do more trimming on the fender area, but it would be tight and I feel like a regear would really be needed at that point.
Who knows, when these tires are toast maybe I will try...
2004 SR5 with 195K miles.
Icon Lift, 33" Patagonia MT tires, ARB Bullbar, Coastal Offroad rear bumper.
Ctullu's Build Threadl
06-05-2020, 01:07 PM
#7232
Registered User
Real Name: Morris
Registered User
Real Name: Morris
Looks really good!
06-06-2020, 09:51 PM
#7233
2008 4 runner
The car is a 2008 4 runner v6 2wd. With Trd pro wheels and nitto ridge grapplers 285 70 17. I also have spider trax 1.25 inch wheel spacers.
My suspension set up is all mismatched . I originally wanted to level out my car. So I purchased a bilstein 5100 kit with rear 1.8 springs. I was gonna use the front stock coils and put it at 4th notch. Then I decided to purchase some dobinson c59300 front coils. Ran that set up for a few months. So later on I wanted to go higher. Somewhere along the way I purchsed the dobinson upper control arm. That opened up possibilities of going higher. I recently purchased the Dobinson c59-677v coil so I can run 3 inches. I moved my bilstein 5100 to second clip using the c59300 coils. Im currently at 23 inches up front and 24.5 rear. Im planning on raising the front up some more I dont like the rake it has at the moment. Ill up load pics soon
06-06-2020, 11:14 PM
#7234
Looks nice! I really like the way the white on 4th gens.
06-07-2020, 06:20 PM
#7235
04 4Runner Limited V8 4WD - Toyotec Springs w/Bilstein 5100s and Icon Rear Springs w/Bilstein 5100s - MK6 17x8 -10 275/70 ST Maxx's - Victory4x4 Wench Bumper - LED Interior Swap - Pioneer Bass Upgrade -
06-07-2020, 07:47 PM
#7236
Originally Posted by Skiian
Well finally upgraded my suspension, originally had TRD Tacoma front 4600 bilstein struts/springs with 1.5" Daystar spacer on stock rear springs with 5100s. Was equipped with XREAS but removed that when I installed the above stuff. So on to the new stuff, Rocking Toyotec 2.5" springs with 5100s on the front and 5100s with 2" Icon Springs rear. Went ahead and swapped my 265/70 Cooper AT for 275/70 Cooper STT MAX's.
Damn, that looks super clean, would you mind if I asked what the height front/back is by this point?
06-07-2020, 08:39 PM
#7237
Thanks man! not at all, current measurements from ground to flare lip is:
DF:36" PF: 37"
DR: 37" PR: 38"
So driverside sits about 1" lower to the passenger side which can be corrected with spacers. Which il do eventually.
06-08-2020, 03:30 PM
#7238
Real Name: Tyler
Real Name: Tyler
Man this looks great. How much rake do you have with this? Also, what headlights are you running? Thanks!
06-08-2020, 03:58 PM
#7239
Thanks, got 1" of rake. AS for the headlights they're just black housing ones off eBay.
06-14-2020, 06:32 PM
#7240
4 new BFGoodrich All Terrain KO2
2006 SportEdition V8 | 2009 Honda Accord EX-L
06-15-2020, 05:44 PM
#7241
I like the look of the lifts with a little rake still. My spacer lift is even, and too often after I park with the car not settled, one corner looks higher or lower.
06-16-2020, 03:12 PM
#7242
Originally Posted by ajw1275
Anyone run a lift with factory 2018 limited 20 inch rims on there 4th gen?
My wheels are from a 2012 without the black accents
2004 V8 LIMITED 4WD
[INT/EXT] 06+ Projectors & HIDs/LEDs/CDN Hood deflector/SS Bull Bar & Hitch Step
[ENGINE] aFe Pro DRY S Air Filter/DT Headers/TRD Dual Exhaust
[WHEELS/SUSPENSION] OEM 20" Rims(265/50R20)/Dobinsons Suspension 2" lift
06-17-2020, 05:43 PM
#7243
WHOA! Not many malls open right now to be crawling. What journeys have you taken up in the interim? LOL Only kidding, if it works for you, thats cool. Definitely not something you see everyday though.
2006 V8 Limited 4WD
| Doug Thorley Headers | Gibson | Old Man Emu | ToyTec | SPC Performance | RCI Metalworks |
| Skid Mark 4x4 | SpiderTrax | BFGoodrich KO2 | aFe | Rutech | HCF Mod |
06-18-2020, 01:06 AM
#7244
Real Name: Daniel
Real Name: Daniel
Lift brand/size: Bilstein 5100 Shocks with Moog FJ coils up front (lift set at 1.75") and Bilstein Heavy Rear Springs 400lb Constant Load
Tire brand/size/style: BF Goodrich KO2 AT's, 275/70/17
Do I like it? Of course I do! I think I may want to give her an extra inch or two but I'm not sure yet. When spare money rolls around, I'll consider it.
'06 Sport V8 RWD | OME 885's on Bilstein 5100's | JBA UCA's | Doug Thorley Long Tubes w/ Magnaflow Catback | Satoshi Grille Mod | Oracle Halo Kit | TRD Pro FJ Wheels | Sony XAV-AX100 w/ Rockford Fosgate 10" Punch Subwoofer | BF Goodrich KO2's (275/70/17) | 15% Tint | 282xxx miles
06-21-2020, 12:28 AM
#7245
Day Star 2.5” lift in the front with the matching 1.5” in the back to level it out, along with some 275/70/18 Pathfinder AT’s
