Did some trail testing this weekend with the 35s. They sruff nicely in the rear with no rubbing after my home made 2"bump stop extensions and cleared decently with minor frame and uca rubbing at full lock up front.
Sent from my SM-G970U using Tapatalk
2003 Limited V8 4runner - 37's, Tacoma Front End swap, ARB locked front and rear , LC200 rack swap
Here's my junk again. It's pretty much stock. I got lost on some county road in california. Met some pretty awesome people, they kept telling me the road was named after some lame ass jeep. His first Gen is on 37's with a d300 turbo diesel in it. Solid dude. Ex marine, tough as nails. Had some cool stories to tell too.
Sent from my SAMSUNG-SM-T337A using Tapatalk
Stock suspension? Tire size? Personally love a low and lean 4runner.
Had to do a move the fender skirt up a little forward previously to help with rubbing before the lift, but it still rubbed sometimes. With the lift, there's no rubbing. Definitely loving the new suspension. This truck has 222K miles on it, and I have a feeling it was still on the original suspension.
Big thanks to Wheeler's Offroad for hooking me up with this setup.
What was you end lift height? Hub to fender?
Looks good with the 275s. Fills out nicely.
I always say, a lift height is relative to the tire size.
Recently installed the Eibach Pro Lift kit on my rig. Fronts are set one clip above the bottom. Tires are 265/70/17 Wildpeaks and have no rubbing issues.
Does it rake forward a touch still? Just put that kit on mine today with the fronts at the third clip (second from top), and it's got the tiniest amount of rear rake. Took the running boards off to make it less obvious, I think I'm happy with it now.
Might just put a spacer above the rear springs sometime to get it perfect
It might have a touch of forward rake, but it's not much if any. I'm happy with being on the second clip so far. Maybe when I get UCA's I might go up another clip but that won't be for a little while.
2019 Off Road Premium, Fox 2.5 and a bunch of other stuff.
Before and after. DO front bumper, factor55 fairlead and flat link E, smittybilt 10,000 lbs, Baja design fogs, fifteen52 turbomac HD [classics], BFG ko2s 285/75/17
2005 Sport / v6 / Icon stage 2 / toytech 1'' body / DO Front / 285/75/17 BF Goodrich KO2s / Fifteen52 Turbomac HD / Prinsu Full Length / Baja Designs & Factor 55 Goodies / Overland Custom Designs Links
