A10MileHusker, Co.Ag.2005
Thread Tools Rating: Thread Rating: 41 votes, 4.68 average. Display Modes
Old 08-31-2021, 02:47 PM #7651
stopthefury stopthefury is offline
stopthefury is on a distinguished road
Originally Posted by mjg514 View Post
getting to be my favorite time of year! snapped while heading up mammoth gulch to the james peak lookout near rollins pass, CO.
my lift and tire set up on 2007 SR5 4x4:
  • Front Suspension: OME 884/90021 + SPC UCA's
  • Rear Suspension: OME 895/60004
  • Tires: 285/70r17 BFG K02's (C Load)
  • Wheels: TRD Pro
where do you have you spare?
stopthefury is offline   Reply With QuoteReply With Quote
Old 08-31-2021, 04:42 PM #7652
Tironeous's Avatar
Tironeous Tironeous is offline
Real Name: Joe
Tironeous has a spectacular aura about Tironeous has a spectacular aura about Tironeous has a spectacular aura about
Tironeous's Avatar
Real Name: Joe
Lift and Tire Central (pics)... Post 'em Up!
Originally Posted by mkrunnersd View Post
Awesome Trioneous. I love the SCS but could not available at the time I got my Fuels. Motivates me to purchase the 650lbs springs for my 6100.
Any rubbing issues? If not i'll be purchasing the springs sooner.
Mike
The normal pushing the fender liner forward, removing mud flaps, and trimming some plastic near where the mud flaps were. For daily driving it’s doing really well not rubbing now.
Tires do not clear body mount at full lock. Caster is 3.6. I guess the wheels could go a little more forward. I’m getting a body mount chop in a few weeks. It’s fine for on-road driving right now.
The 650lb spring definitely makes it taller. I had to lower it down to the 3rd clip from the 5th (second highest) because I had 1/2” reverse rake even with the 2” Icon springs in the rear. Now it’s sits perfect with about 1/4” of forward rake.
2005 4Runner Limited V8 4x4 Galactic Gray Mica
Instagram | My "Build" Thread | Bilsten 6112 with 650lb spring | Total Chaos UCAs | Bilsten 5160 with OME 895 | Stealth Custom Series GEN5 Wheels | Dirtcom Trail Swing | Sony XAV-AX5500 | Focal Integration ISS 165 (Front) | Focal RCX-165 (Rear) | Pioneer TS-SW2002D2 (Subwoofer) | Accele RVCLPMBS (Backup Camera)
Tironeous is offline   Reply With QuoteReply With Quote
Old 08-31-2021, 04:46 PM #7653
Tironeous's Avatar
Real Name: Joe
Tironeous's Avatar
Real Name: Joe
One more because I’m a obsessed and this is the thread for it after all
Old 08-31-2021, 06:56 PM #7654
mjg514 mjg514 is offline
Real Name: Matt
mjg514 will become famous soon enough
Real Name: Matt
that's coming! just got another trd pro wheel and i'm going to get another ko2 new since this set isn't very old at all. for now i'll have to carry it in the back, but i'm looking to get a rear hitch swingout very soon. just wish detours of maine wasn't on a 12 month backorder right now. might have to go with RIGd but dayumn....over $1k seems crazy to me!
anyway, i haven't had a full size spare for about a year now and have luckily not had to use one. maybe not lucky so much as the bfg ko2's are burly AF. i still have the factory spare underneath....it would still work for me for where i go most of the time if i was in a real pinch... i'd just put the smaller spare on the front and drive out in 2wd.
2007 SR5 V6 4x4 / Front Suspension: OME 884/90021 + SPC UCA's / Rear Suspension: OME 895/60004 / Tires: 285/70r17 BFG K02's (C Load) / TRD Pro Wheels / Apex Overland Front Recovery Points / Desert Armor Ninja RTT / Outgear Solutions Low-Pro Crossbars
2017 TRD ORP / Watch this space....
mjg514 is offline   Reply With QuoteReply With Quote
Old 09-05-2021, 11:42 AM #7655
mattkwade mattkwade is offline
mattkwade is on a distinguished road
Lift + Front End Refresh
My 2005 SR5 4wd is coming up on 200k and starting to show its age with a little wobble at 60 MPH. I know I need to replace the hubs/wheel bearings and figured I'd do a refresh on the front end. I just moved to Denver so picked up a couple of CVJ Reman front axles and also ordered JBA UCAs.
Right now I'm riding on Bilstein 5100s (fronts at .85) and FJ Trail Teams springs all around. I have about 50k on a set of 255/75/17 Cooper AT3 4S (32.2") on 5th Gen TRD OR wheels and they've served me well but I'm looking to move up to some 33" Falkens so I may try to lift it another inch or so. I've considered adjusting the Bilsteins up a notch or two but I think I'd rather not compress the springs that much. Can anyone recommend a set of springs that pair well with 5100s (and can fit a 33" tire without setting the Bilsteins above the first notch or two)?
Also - are there any other items I should look at or replace while I have everything apart? I think it would made sense to do the lower control arms as well - is the consensus still that Toyota OEM is the right move there?
mattkwade is offline   Reply With QuoteReply With Quote
Old 09-06-2021, 03:35 PM #7656
Billynath1988's Avatar
Billynath1988 Billynath1988 is offline
Billynath1988 has a spectacular aura about Billynath1988 has a spectacular aura about Billynath1988 has a spectacular aura about
255/85/17 Mickey Thompson Baja Boss AT
2021 Genuine TRD SEMA edition Gloss gunmetal wheels
Radflo 2.5 ext travel Coilover with remote Resi's and 700# springs (overland warehouse valving)
Radflo 2.5 ext travel rear shock -
Metaltech HD Long travel Rear springs
Metal Tech 3 inch rear Bump stop extensions
DuroBump extended front Bump stops
DuroBump Extended Rear bump stops
Lift and Tire Central (pics)... Post 'em Up!-signal-2021-08-28-155350_001-jpg
2005 4Runner SE V8
http://www.toyota-4runner.org/4th-ge...-v8-build.html
Billynath1988 is offline   Reply With QuoteReply With Quote
Old 09-07-2021, 09:37 PM #7657
Offroad03 Offroad03 is offline
Offroad03 is on a distinguished road
2007 ome suspension pro comp wheels
Lift and Tire Central (pics)... Post 'em Up!-8a965586-4c87-444e-bac4-b9eb6661943c-jpg
Offroad03 is offline   Reply With QuoteReply With Quote
Old 09-16-2021, 03:04 PM #7658
Annolino122 Annolino122 is offline
Annolino122 will become famous soon enough Annolino122 will become famous soon enough
2008 V8 4Runner - 285/75r17 + Icon Stage 2 + 1/2" Shim
Annolino122 is offline   Reply With QuoteReply With Quote
Old 09-18-2021, 05:06 PM #7659
Fish-hed's Avatar
Fish-hed Fish-hed is offline
Real Name: Drew
Fish-hed is on a distinguished road
Fish-hed's Avatar
Real Name: Drew
Originally Posted by TC4Rnr View Post
done by 3 hours by myself in the drive way with simple tools.
Brother, you're a better mechanic than I am. I did virtually the same on mine with OME coils with Billsteins. For me it was more like 3 hours to do the rear springs, but I got them did and have been super happy with them.
Fish-hed is offline   Reply With QuoteReply With Quote
Old 09-20-2021, 06:44 PM #7660
slprice1631 slprice1631 is offline
slprice1631 is on a distinguished road
2008 sr5
hi, Im new here and trying to figure out my lift/ tire/ rim options.
I am working on getting set up for off roading / overlanding. I am going to do a 3" suspension lift and I would like to get bigger tires, Id really like to go up to 33" if possible but I am not sure if they would fit. If you were starting from scratch what would you do. Im thinking of doing a small body lift to help with better clearance for bigger tires but I dont want to go too big and throw of the center of gravity. Im having a hard time finding good options for low profile bumpers too, any hints?
slprice1631 is offline   Reply With QuoteReply With Quote
Old 09-22-2021, 09:31 PM #7661
Syr4RinNC's Avatar
Syr4RinNC's Avatar
All depends on your goals and budget - rock climbing, desert riding, just general aggressive looks. How expensive or economic do you want in a suspension, whats your budget for wheels/ tires, do you need added protection - sliders, skid plates, off road bumpers/ recovery points
Lots of reading. - scan through this thread to get ideas.
Old 09-23-2021, 02:57 PM #7662
Skiian's Avatar
Skiian Skiian is offline
Skiian will become famous soon enough Skiian will become famous soon enough
Skiian's Avatar
04 4Runner Limited V8 4WD - Toyotec Springs w/Bilstein 5100s and Icon Rear Springs w/Bilstein 5100s - MK6 17x8 -10 275/70 ST Maxx's - Victory4x4 Wench Bumper - LED Interior Swap - Pioneer Bass Upgrade -
Skiian is offline   Reply With QuoteReply With Quote
Old 09-23-2021, 04:34 PM #7663
MLSD MLSD is offline
MLSD is on a distinguished road
Still need rock sliders
Lift and Tire Central (pics)... Post 'em Up!-4runner2021smaller-jpg  Lift and Tire Central (pics)... Post 'em Up!-skidplatesmall-jpg  Lift and Tire Central (pics)... Post 'em Up!-ledssmall-jpg
07 Titanium Metallic Limited 4x4 V6, OME/Bilstein 3"Lift, Total Chaos Upper Control Arms, BMC, Apex Overland Front Recovery Points, Victory 4x4 Strike Rock Sliders, Vision 18x9 Manx 2 Satin Black Wheels, 33.2" (P275x70x18) Cooper Discoverer ATP II
MLSD is offline   Reply With QuoteReply With Quote
Old 09-24-2021, 10:25 PM #7664
WyEast-08's Avatar
WyEast-08 WyEast-08 is offline
WyEast-08 is on a distinguished road
WyEast-08's Avatar
Good looking 4runner, not too many folks running with 18 tires. Ive got 275/65/18's and using limited wheels at the moment, what offset are your visions?
WyEast-08 is offline   Reply With QuoteReply With Quote
Old 09-24-2021, 11:01 PM #7665
Thanks! The offset is -12. I went with 18-in wheels because that's what was on it new. In hindsight it would be better off-road to have more tire and less rim. I'll just have to be careful.
Sent from my Pixel 2 XL using Tapatalk
Lift/Tire/Wheel central Asaspades93 3rd gen T4Rs 75 07-13-2018 04:23 PM
need pics of a specific lift/tire combo Token13 4th Gen T4Rs 3 05-09-2014 09:37 PM
Bigger Tire Pics / No Lift agjake01 5th gen T4Rs 6 03-20-2013 07:28 AM
Post PICS of your 3rd Gen with a Daystar lift and/or 265/75 RdRunNNeR Maryland / Virginia / WV / D.C. 0 03-01-2013 09:17 AM
please post pics of your 2nd gen with OME lift w/32's 4x4dad Classic T4Rs 15 05-02-2012 01:22 AM
