02-25-2024, 05:06 PM
#7906
Originally Posted by alhang
OME 886/898 springs 1/4 front poly spacers, bilstein 5100's, rear sway connectors from 2nd gen, only rubs the front mud flaps which I'll take off soon. camber and toe aligned fine with stock uca, loss of caster, but at least tires won't wear unevenly.
If it's over 2.5" you need adjustable uca, to properly align the vehicle or uca that have the camber/caster build into them. I have seen way too many people come into my shop and say they don't need them until we show them why and the damage it is doing
02-25-2024, 05:21 PM
#7907
Originally Posted by nr0974
338mm came on the sports only, don't know about the urbanrunner
02-25-2024, 05:23 PM
#7908
Possibly the limited but I haven't installed any drilled n slotted on limiteds, I have owned 2 sports at once n most that come in the shop are SR5s
02-25-2024, 05:41 PM
#7909
Originally Posted by MrSeth
From what I have seen you will be warranting them out in a year or two
02-25-2024, 06:03 PM
#7910
Originally Posted by kcdehart
I honestly like the E's more on pavement. They keep the handling sharp despite being large tires. I had a friend that daily's an S2000 comment on how much he liked the turn-in when he drove it On the other hand, a friend of mine has C load Grabbers on his Forester and absolutely hates how sloppy they feel.
Thanks! Did the work myself on a friend's lift with air tools. Took us about 7 hours (30 mins of which was a wheel bearing - surprisingly the easiest part). I'd hit everything with PB blaster the day before and expect the endlinks to be a *****-and-a-half to remove. The top rear bolts on the front struts are also a pain. The strut tophat will also sometimes seize to the piece it goes into. That took us a solid hour of banging at to remove.
I think it could be done without a lift - would just be a bit more uncomfortable. I wouldn't try it without an impact though.
As for UCA's, I'm gonna replace them whenever my upper ball joints go bad. For the time being, they're alright. I do still need to get it aligned, though (shame on me).
I went with 2nd gen endlinks on the rear to get a bit more droop. I left the front stock though, as I'm worried about my CV's binding. A diff drop/new skid that accommodates it will be coming in the future.
Hit me up sometime if you wanna head offroad!
Yes u have an old post but guaranteed your upper ball joints are bad, the only way to test them is with a big ass pair of vise grips or pliers to compress to look to slack.
02-28-2024, 11:15 PM
#7911
Real Name: Seth
Real Name: Seth
I ended up running them for about 2.5-3 years before switching to Bilstein 5100s. They rode okay, but the adjusters broke off pretty early on. I won't go back to Rancho's on my current build lol. When I did that lift, I was super super new to the offroad world and went to 4Wheel Parts and they said it was the only lift made for the 4th gen
2006 Shadow Mica SR5 v6 1" BL, Fox Racing UCA's, RC 3" N3 Lift, Rock Trix RT110 -12 Wheels, 315/70R17 Goodyear Territory MT, Tacoma Front Bumper, 5th Gen 4R Tire Carrier, Big Lion LED's
03-08-2024, 10:08 PM
#7912
Originally Posted by jlaw904
I have not lifted yet, but I thought this would be useful info. I got these Falken Wildpeak ATW/3's on my 2008 and contrary to a lot of what I read, I still had to make some modifications to fit. They are 265/70R17. They required trimming the front bumper and moving the liner forward. And behind the front tire required hammering and bending the pinch weld behind the mudflap. May not be required with the lift.
Your front suspension is completely collapsed! Upgrade already, I have worn out suspension but mine is not that bad, 174k on mine factory suspension no leaks 08 sport run same tore size no rubbing except fully locked n going over a bump
03-20-2024, 01:05 AM
#7913
Real Name: Taylor
Real Name: Taylor
Originally Posted by T4rcruznn
05 4Runner icon 2.5 with resis all around spc upper arms dobinson 677v rear springs with 17x8.5 advan rg-d2 wrapped with 315/70/17 Falken wildpeaks trai gear adapters and super bump stops front and rear with extensions and BMC
That rear bumper job looks cleeaan
Sent from my SM-G975U using Tapatalk
1985, 22re, 5spd, 4x4, Marlin crawler dual transfer case, locked fr&rr, 35's
1996, 5vz-fe, Auto, 4x4, Bilstein/ome lift, tundra 17's, 33's
Sold(regret it)- 1999 Highlander edition, Auto 4x4, 3"lift, factory rear locker
03-22-2024, 09:54 AM
#7914
Originally Posted by Jpicar681
Just got the grill and very happy with the end result
What lift, tires, wheels, spacers are you running?
Any rubbing?
Any cutting?
I really like this.
03-23-2024, 10:47 AM
#7915
Originally Posted by J.A.
Came across this thread and my page 1 post and though I would give a 15 year update...
04-20-2024, 12:23 PM
#7916
Sweetnesa
04-30-2024, 12:02 PM
#7917
My 4Runner already came with a decent lift when I bought it and it’s working for know. I am currently running Bilstein 5100 shocks with OME coils front (OME-886X) and rear (OME-895). My 4Runner also came equipped with a 1 inch body lift.
So far, I have no complaints with this setup. The ride is decent and the front springs handle the bumper, winch, bigger battery and the skid plates just fine.
Only thing I added was a set of Total Chaos upper control arms that I transferred from my out going Tacoma and a set of rear sway bar end links off of a 2nd gen 4Runner, which are about an inch longer than the stock 4th gens.
RCI Armor, CBI Bumper, WARN EVO winch, Triple Lockers, Sherpa Rack, MR312 Wheels on MT Baja Boss Tires
Build Thread: https://www.toyota-4runner.org/4th-g...der-build.html
Reason: added a comment about the rear sway bar links
04-30-2024, 06:27 PM
#7918
Here's my setup. Dobinson mid-travel kit with Perry Parts bump stops.
Reason: adding photos
05-21-2024, 01:45 AM
#7919
Lift and Tire Central (pics)... Post 'em Up!
I’m looking at doing the same wheel/tire package, just have a front level though. How’s the clearance in general? Concern is the 8.5” W +0 offset wheels will lead to rubbing issues.
2008 Limited V8 - Natural White - Nav
Bilstein 5100/4600+RAS - Cooper AT3 4S 265/65-18
My build thread
05-27-2024, 10:05 PM
#7920
You will definitely rub on the front part of the bumper. I trimmed a bit when i had my Spidertrax then even more when I swapped out to these wheels. But it is not much that you need to trim off and it isn't noticeable at all. Pushing the fender liner forward as much as possible helps the most. Very easy to do.
