Originally Posted by PhantomF4E
Attached are some photos I took of the left-hand fog light housing. I can only make out one vertically oriented bolt, but not sure how to take it out. Anyone have any thoughts?
I was unable to open your PDF. Not sure what year your truck is, but mine is an '09, and I just replaced mine yesterday. If yours is '06-'09, you'd need to remove the outside black plastic molding/trim by pressing the 4 tabs which attach it to humper; these are accessed from inside bumper next to fog housing; in attached picture, it's that black thingy halfway down green arrow, as indicated in pic. You then disconnect light blub socket, and try to wiggle housing pushing forward. Housing is not held by any screws, but there're a couple of tabs you may need to pry out, one at time, while pushing housing forward. In attached pic, green arrow is pointing to that tab you could pry out with a screwdriver. To install, start from front and just push housing in until it's seated, very simply.
