Originally Posted by MikeinNH67
Do you have any active codes? Is the check engine light on? I can't tell by the app you are using if it's code related or just not enough drive cycles.
Good question, no codes.
I may have driven the truck 12-16 times since the replacement engine install was completed. Maybe 120 miles. Its a good thing we waited because I found out the AFE cold air intake is not CARB compliant so I put in an offer for a used system on ebay for local pick up.
