Old 08-27-2004, 03:23 PM #1
skategoat skategoat is offline
skategoat is an unknown quantity at this point
What wheels fit my '04 Runner?
My dealer promised me a deal on used wheels but he's not coming through. I'm also talking to a few guys about buying their wheels but most are long distance deals which I want to avoid.
I'm going to keep my eye out locally but would like to know what to look for. That is, what wheels, other than '04 4Runner wheels fit my truck? I'm looking for a winter set so they don't have to be anything fancy.
Since most people list used wheels according to the vehicle they come from, what trucks have the same fitment as the '03-'05 4Runner? Do previous gen wheels fit? How about Tacoma or Tundra?
TIA,
Henry
skategoat is offline   Reply With QuoteReply With Quote
Old 08-27-2004, 06:13 PM #2
sharp4runr's Avatar
sharp4runr sharp4runr is offline
sharp4runr is on a distinguished road
sharp4runr's Avatar
I think you're looking for the bolt pattern. the bolt pattern dictates how the wheel studs are spaced from each other. You'll also need to have the right offset i think. neither of which I know so I can't help :arrow:
Just did a quick search and the bolt pattern is 6 X 5.5
Different wheels will have different offsets so you'll have to figure that one out yourself.
sharp4runr is offline   Reply With QuoteReply With Quote
Old 08-27-2004, 06:17 PM #3
ToolmanJohn ToolmanJohn is offline
ToolmanJohn is on a distinguished road
Re: What wheels fit my '04 Runner?
TIA,
Henry
I've been in the same situation. I want a 16" set of winter wheels and tires (because there are a lot of 16" truck tire choices), but there aren't any that fit the 4th gen 4runner. Mine is a 2003 Linited with the factory 17" wheels.
I don't know anything about getting spacers to accomodate the lug pattern and offset? Would this post be better in maintenance?
2003 4runner V6 Limited 4x4 - A good ten years.
4 out of 5 dentists recommend Trident to their patients who chew gum, the 5th dentist recommends chewing a cup of pure cane sugar before bedtime. Don't go to that dentist!!!
ToolmanJohn is offline   Reply With QuoteReply With Quote
Old 08-30-2004, 09:50 AM #4
Thanks. I didn't know about the bigger Sport brakes. I have an SR5. Since they are the smaller brakes, I'm going to assume Sport wheels fit.
Bolt pattern and offset, I'm familiar with. However, when someone is selling wheels, they usually say - "99 Tundra" or "99-02 4Runner'. Most people won't even know the offset. That's why I've been searching for some sort of definitive cross-reference. I think I will try a tire shop.
Also, I'll take my spare off tonight and check for offset numbers.
Thanks,
Henry
Old 08-30-2004, 11:06 AM #5
mbradshaw3 mbradshaw3 is offline
mbradshaw3 is an unknown quantity at this point
I'm looking to sell my factory 16" wheels with Bridgestone tires (about 20k miles) if any of you all are interested. I would imagine that they would fit fine coming off an 04 SR5.
mbradshaw3 is offline   Reply With QuoteReply With Quote
Old 08-30-2004, 12:03 PM #6
Good Times's Avatar
Good Times Good Times is offline
Good Times is on a distinguished road
Good Times's Avatar
The easiest way to figure out whether or not you can fit 16" wheels is by measuring the front discs of your 4runner.
If the disc is over 13" then you will need a 17" wheel. This is regardless of what model you have. Obviously all the SPORTS model comes w/ the 13.3" disc so you're all kinda screwed. Those that have Limiteds may have the smaller discs so please do measure them.
Like I said, this is the easiest way to figure out what size wheels to get.
IF you're looking for aftermarket and can fit 16" wheels, you want to get atleast a 16x8 (so you can fit larger tires) with backspacing of 4.5".
Good luck
Good Times is offline   Reply With QuoteReply With Quote
Old 08-30-2004, 02:50 PM #7
bradshaw:
I sent you PM
Old 07-10-2009, 03:01 PM #8
alejo2112's Avatar
alejo2112 alejo2112 is offline
alejo2112 is an unknown quantity at this point
alejo2112's Avatar
My friendo, a question: did you know in a Cragar steel Wheels 16x8 with 5" backspacing fit on my 06 4Runner (16" rim stock) ?????
http://www.summitracing.com/parts/CR...P/?image=large
thanks!!!!
ALEXANDER
Good luck
alejo2112 is offline   Reply With QuoteReply With Quote
Old 11-06-2021, 07:17 PM #9
Hkgbeef Hkgbeef is offline
Hkgbeef is on a distinguished road
What is the biggest size of mags (i really like the ray10 of SCS 17/8.5 -10 offset) and tires can i put with a stock suspension without rubbing.
Im sorry to ask here but i didnt found another way.
Really hope you can understand my question, english is not my first language
Thanks
Hkgbeef is offline   Reply With QuoteReply With Quote
Old 11-06-2021, 07:34 PM #10
Keros Keros is offline
Keros has a spectacular aura about Keros has a spectacular aura about
Thanks
Stock size is 265/65R17. You can step up to 265/70R17 with somewhere between no rubbing to minor rubbing. Depending on tire brand and your ride height. My truck rubbed on the fender liners on stock wheels with the 265/70R17
I have a set of 17x8-0 offset for winter tires, 265/70R17, and they're pretty much flush at the fender line. The sidewalls "poke out" but not the tread.
2005 V8 Limited
Bilstein 6112/5160, ADDCO bars. 18x9 Beast with 285/60R18 BFGs
IPT valve body, DT shorty headers, Dirty Deeds BAMF exhaust
Keros is offline   Reply With QuoteReply With Quote
Old 11-06-2021, 11:37 PM #11
haro's Avatar
haro haro is offline
haro is on a distinguished road
haro's Avatar
Just got this falken wildpeak 265/70/17 installed today. I have fj moog and bilstein 5100 . Front set one setting higher to lever the truck . No rubbingWhat wheels fit my '04 Runner?-20211106_111026-jpgWhat wheels fit my '04 Runner?-20211106_104059-jpg
Sent from my SM-G986U using Tapatalk
2003 4RUNNER LTD V6 4X4
SILVER
haro is offline   Reply With QuoteReply With Quote
Old 12-05-2021, 09:10 PM #12
blacktopninja blacktopninja is offline
blacktopninja is on a distinguished road
i cant find my answers either so i ask .. i have 2008 limited 4runner with 18 inch 25mm offset tires are 265/ 60 18 im looking to pickup 2021 premium wheels new with tire size 265 70 17 ,wheels they have 15mm offset. has anyone ever done this swap without any rubbing or surprise problems ? thanks
blacktopninja is offline   Reply With QuoteReply With Quote
Will these wheels fit my '87? illzoni Classic T4Rs 4 09-25-2010 11:49 AM
POLL, # of FAMILY MEMBERS WHO FIT IN YOUR RUNNER 2000runr 3rd gen T4Rs 19 06-21-2010 05:26 PM
can 15" rim fit on my 01 4 runner???? mudrunner01 3rd gen T4Rs 3 06-20-2006 08:31 PM
17 and 18" wheels with tires, Chicago AREA terrytcl Classifieds - buy & sell (no commercial ads please) 19 01-10-2006 11:07 AM
Wheels! What things to consider when shopping... Thai Engines / Suspension / Wheels / Tires / Audio / Accessories 3 01-03-2004 04:05 PM
