Okay I am new here and This is my second post. First was in the new member forum.
I wanted to add some fog Lights/running lights to the front if the 4 runner however after i wired it up I did not like the way the switch looked. I added it to the center blank in the center console and it really detracted from the aesthetics so off I went in search of one that would fit in my 2005 4Runner SR5. There was not a lot of info out there on how or where to obtain switches. I was thinking of auto recyclers, but nothing there local. Then I looked at new, but that was expensive locally (dealer) and there really wasn't a "fog light switch" because it is now part of the light switch on the column itself. I was going to purchase anothe 115 VAC switch and simple repaint it label it and clear coat it. But I wasn satisfied with that. so I looked and found the the Tacoma switches work and WELL. I wired it up and got it into the center console where the old one was. It snapped right in.
In case you are wondering the part # is 8416004010 and I found it for practically 1/2 the price of any online dealer at this place:
https://www.toyotapartsbarn.com/replacement-parts.html It looks very good.
Toyota Tacoma Fog Lamp Switch - 2005 to 2008
1- switch #84160-04010
1-connector#90980-11090
4-pigtails #82998-12340
In wiring it up I found that you can wire it one of two ways:
To Illuminate when lights are powered on:
Pin #
1-ground
2-wired to [3], then wired to relay that is powering your lights
3-wired to [4]
4-power (usually from high beam circuit for driving lights)
To Illuminate with dash lights (parking lamps)
pin#
1-ground
2-dash illumination wire (from another switch, rear of radio, etc)
3-power (usually from high beam circuit for driving lights) (power in)
4-wired to relay that is powering your lights (Power out)
You can also use the FJ Cruiser Switch Part # PT29735070AS
Toyota FJ Fog Lamp Switch
1-connector #PT297-35070-SH
1-switch #PT297-35070-AS
Which has an indicator light as well as you can see
I found this post on another forum that gave me tons of insight
http://www.thenewx.org/forum/showthread.php?t=17563
Pictures coming........
