Old 10-26-2009, 07:29 PM #1
wallstreet wallstreet is offline
wallstreet is an unknown quantity at this point
Good Noise?
When I turn the ignition key to ACC, I hear a humming sound for about 10-15 seconds. Its perfectly normal. I think all 4runners have this. Seems like the the oil pump is working to circulate oil before I crank the truck. Not sure but was wondering if this is true. Does anyone know what processes take place in the engine when the ignition is set to ACC.
Maybe it might be a good idea to turn the key to ACC for 10-15 seconds before cranking to help the engine at cold starts, esp in winters.
wallstreet is offline   Reply With QuoteReply With Quote
Old 10-26-2009, 07:55 PM #2
drmorbius's Avatar
drmorbius drmorbius is offline
drmorbius is on a distinguished road
drmorbius's Avatar
You are probably hearing the power brake booster which uses an electric motor to drive a pump and fill a reservoir. Most cars use a vacuum operated booster that uses engine vacuum and requires that the engine be running.
Larry
"Monsters From the Id"
2004 SR5 V6 Titanium Metallic/Stone, Auto Dimming Compass Mirror, Valor Tip, Overhead Console W/HomeLink, Cargo Net, Michelin Cross Terrains, Added JBL Synthesis 10 speaker system 6/08, USA Spec PA-15 TOY Ipod Interface, Drivers Side Overhead Handle, Valvoline Synpower 5W-30, Mobil 1 75W-90, LEDs
drmorbius is offline   Reply With QuoteReply With Quote
Old 10-26-2009, 08:03 PM #3
03 Limited 03 Limited is offline
03 Limited is an unknown quantity at this point
Or maybe he is hearing the fuel pump priming?
2003 4Runner Limited V8 2WD -Stock
1990 300ZX Twin-Turbo -Modded
1990 300ZX Non-Turbo -Stock
03 Limited is offline   Reply With QuoteReply With Quote
Old 10-26-2009, 08:12 PM #4
drmorbius's Avatar
drmorbius's Avatar
Well that's all the way back in the fuel tank and I can't hear mine but I can hear the booster.
Larry
Old 10-27-2009, 12:10 AM #5
wombie wombie is offline
wombie is on a distinguished road
Brake booster gets my vote, if only because it's right up by the drivers side of the hood.
They can shake about quite a bit too (mine had to be replaced because it was sending vibration up the brake pedal every time I braked...talk about annoying).
2006 4x4 SR5
2000 Limited (RIP old buddy)
wombie is offline   Reply With QuoteReply With Quote
cold start , ignition , noise , winter
