Originally Posted by wallstreet
When I turn the ignition key to ACC, I hear a humming sound for about 10-15 seconds. Its perfectly normal. I think all 4runners have this. Seems like the the oil pump is working to circulate oil before I crank the truck. Not sure but was wondering if this is true. Does anyone know what processes take place in the engine when the ignition is set to ACC.
Maybe it might be a good idea to turn the key to ACC for 10-15 seconds before cranking to help the engine at cold starts, esp in winters.
You are probably hearing the power brake booster which uses an electric motor to drive a pump and fill a reservoir. Most cars use a vacuum operated booster that uses engine vacuum and requires that the engine be running.
