11-24-2009, 11:40 AM
Look for Replacement Headlight Bulbs - Recommendations
I was wondering what everyone recommends or considers the best replacement headlight bulbs to improve lighting distance for the high beams/low beams/fog lights on a 2006 4Runner Sport Edition without actually installing HID.
I was looking for one that lasts the longest, the most dependable, and best viewing.
I was told that PIAA seems to be one of the best replacement bulbs out there.
Also, is it worth going to yellow bulb fog lights, does that make a big difference in fog/snow
Thanks
11-24-2009, 11:44 AM
There are a couple headlight and foglight threads going already, look down a few lines. This one has a link to a bigger thread in it: HIR Bulbs for my 2004 4Runner
'03 4R SR5 4x4 V6 bone stock; '03 Land Cruiser; B-767 (company vehicle)
11-24-2009, 12:11 PM
If you take the 9005 and 9006 bulbs, going with the HIR's sounds like a great plan. You have to buy the 9011 and 9012 bulbs and then file a tab on each to get them to fit but I've been hearing a lot of great things about them. Another option, mainly for the low beam, is to use the Osram nightbreakers. These are supposedly brighter than the Silverstars.
Rick
'90 T4R - sold at 205,000 miles
'00 T4R - sold at 152,000 miles
'08 Sport - 178,000 miles & still going strong
'19 ORP - just over 6,000 mi. (garage queen, like my '07 Mustang)
11-24-2009, 01:35 PM
some guys upgrade the H11 to H9, the h9 are slightly higher wattage but seem to work without problems. the stock h11 i think have 1350 lumens, the h9 have 2100?. i currently have the osram nightbreaker & while they are much better than stock, im going to try the h9, im not modifing the bulbs but im using this adapter. i also switched to yellow fog bulbs & find them much better. Bulbzilla Headlight and Foglight Brightness Conversion Kits - TruckCustomizers.com
11-24-2009, 01:43 PM
I have the piaa extreme white plus bulbs and I lovem! I've seem them next to the silverstars, and the piaa's are alot brighter and more white! I also have the jet yellow bulbs in my fogs! I think they are worth it!
2004 titanium met 4x4 v6 sr5, 265/70/17 nitto terra grapplers, pro comp 7005 rims, Light Racing UCA`s, OME 884/895 w/ toytec top plate spacers, pro comp es6000 struts, pro comp es9000 shocks, toytec diff drop, and sway bar reclocation kit, OW rear brake line reloc bracket, weathertech digi-fit, front, rear, and cargo liners, piaa extreme white plus low beams, putco pure jet yellow fog light bulbs, Silverstar reverse lights, scion t1808 radio with ipod cable, afe pro dry s air filter, front windows tinted 25%
11-24-2009, 02:07 PM
Super Moderator
Super Moderator
You got your yellow fogs ? How do you like them ?
< 2016 Classic Silver TE w/KDSS >< Bone stock at the moment >
11-24-2009, 02:22 PM
sorry i meant osram nightbreakers not sylvania silverstars, theres a big difference. falls, yellow bulbs in the fogs do make it easier to see, in fog of course, not for using them as extra driving lights like some do.
11-24-2009, 03:26 PM
Sorry, I am a little confused here. I see a lot of people posting with 06' and above 4runners with the projectors and I seen this thread and want to understand what bulb is the best that I can replace the stock ones with without using the Projector Retrokit. I see everyone saying the Osram Nightbreakers but I want to know what bulb would give me the best light with minimum to no modification and longer life for my 05'? Sorry to hijack this thread, but I want to make a clear choice.
2011 LE Toyota 4Runner Classic Silver Metallic| JBL/NAV System | Chrome Tip | Running Boards | Factory Crossbars |
11-24-2009, 03:45 PM
This topic is currently being discussed on at least four threads simultaneously. This thread H11 Silverstars seems to have the most useable info. I'm going with the 9011 and 9012 bulbs as they give the most light for a standard plug-in bulb compatible with my '03. I can't say they're the "best", but they are the brightest and longest lasting commercially available bulbs at a reasonable cost ($20-$30).
11-24-2009, 03:47 PM
11-24-2009, 03:48 PM
I have an 04 with the piaa bulbs! They install just like the factory ones with no modding, and with alot more light and further range! To answer Falls, the yellow fogs are nice in fog and makes the road more visible in rain I think!
11-24-2009, 03:54 PM
Interesting that they don't mention trimming the alignment tabs to fit the 9005/9006 holes. Are they trimming them, or has something changed?
11-24-2009, 04:02 PM
11-24-2009, 04:06 PM
I trimmed them for my '97 Land Cruiser, figured I'll do the same when these arrive. There were some suppliers that trimmed them for you, but I wonder about the legality of that. I've heard these aren't street legal in our 9005/9006 application, which is why they have different tabs.
11-24-2009, 04:11 PM
yea, id say when ya get em, compare the 2 & you should be able to see where & if/how much to trim . scottm, please update after the install, im curious myself about these hir bulbs.
