11-29-2009, 09:24 PM
Shocks and struts
I have a 2005 v8 4x2 4 runner with 53000 miles my local firestone dealer said I need new shocks and struts. I just purchased this car recently. Any advice on what kind to buy. I live in las Vegas and don't plan on going offroad anytime soon.
11-29-2009, 09:47 PM
Super Moderator
Super Moderator
Bilstiens are a popular choice. A few have used the KYB GR2's as an OE replacement and been happy. There are many sources but you can start at Shockwarehouse.com EDIT: I agree with the other guys... I didn't focus on 53k miles. That does seem too early.
Chris
07 Salsa SR5, 4wd Cyclone pre-cleaner , Aux Transmission Cooler, Hidden Hitch 70779 (600/6000lbs, WDH=730/7300lbs), AirLift 1000, FJCruiser front springs (& now rear too!), Axle Vent Mod, Swaybar Bushing Upgrade, V6 Tick Reduction, VSC off mod, Maplight Mod, 255/75/17 Goodyear Wrangler SAs, Tailpipe Mod
11-30-2009, 01:55 AM
Is there any diff in the ride quality
11-30-2009, 07:57 AM
How do they determine that?? 53000 miles dosent seem like that many miles for shock to be bad...
11-30-2009, 10:52 AM
Exactly. Did they find a broken shock? Do you have a lot of bouncing after hitting bumps?
I did mine at 130k and they still had a bit of life in them. The shocks and struts are a big service and a big money maker for the dealerships. You can buy aftermarket and and take them to most any local mechanic and get it done for way less than the dealership.
11-30-2009, 12:13 PM
Super Moderator
Super Moderator
Bilstiens are reported to be slightly stiffer in a good way, not harsh just sporty. The KYB's are generally very close to OE shocks.
Chris
11-30-2009, 05:25 PM
I'm not surprised that a Firestone shop told you that you need shocks and struts. What DOES surprise me is that he didn't tell you that you also need 4 new tires, brakes, brake cylinder, exhaust and anything else he thinks he can get out of you.
Find another shop IF you think that your suspension needs work.
Rick
'90 T4R - sold at 205,000 miles
'00 T4R - sold at 152,000 miles
'08 Sport - 178,000 miles & still going strong
'19 ORP - just over 6,000 mi. (garage queen, like my '07 Mustang)
11-30-2009, 05:46 PM
I put the standard yellow and blue bilstein HD shocks on my 03 and oh my god, what a difference. Much stiffer ride, for the better, with less body roll, lean and shorter stopping distance.
I say they are must have upgrade!
11-30-2009, 09:13 PM
I have a question for you. I have 4 new tires and the steering wheel starts to shake at around 65-70 mph and then wants to turn to the right. could this be a shock or strut issue.
01-31-2013, 11:30 PM
Real Name: Cody
Real Name: Cody
I just bought a 2003 and I don't have new tires but I am having some shakeing, Im very sure that its just a tire out of balance and the pulling is it being out of alignment. I have 197k miles and oem shocks, I have way too much bounce and roll in my car which prolly indicates a shock and strut issue, Right?
Thanks
02-01-2013, 01:29 AM
shocks & struts
Hey propjock if you have the $ have them road-force balanced then check alignment , then if you need the above do it . And like they say bilstiens are better or kyb or rancho , they will improve your ride .
2011 SR5 Mgm 4x4 alpharex pro headlights & depo black tail lights level 8 trackers wheels & p285/70/17 cooper at3s, 6112s all around set 2.5 rear rancho spacer 11/4, FJ coils TRD intake.w/afe-dry filter Urd y-pipe flowmaster super70ii TE roofrails! 2014 Sr5 Superwhite Bils 6112s/eibach 2.5 /1 "rear springs 285s Cooper at3 ms on fj pc-d satin black, Urd y-pipe/Flow delta 50 muffler/all interior led lights & low beams sealights h7 led with laminx yellow fogs & oldreds puddle harness w/2010-13 mirrors
