Originally Posted by Okie
I am in the process of changing my plugs and I noticed a screen with what looks like filter material on it located next to the throttle body. (It is in the housing next to the throttle body after you remove the outer air filter housing and is the same shape as the air filter.) I tried to remove it to clean but it seems to be moulded into the housing.
Does anyone here remove it when changing the air filter to clean or is it none removeable?
Well. You can remove it but you brake it to remove it. I took mine out before I switched to a CAI. But you dont need it. Many people on here remove it. I searched for a second (not too extensively) for a write-up on it but couldn't locate it. Removed, you'll notice a small difference in your throttle response.
