06-07-2017, 06:30 PM
#61
4th gen 2003 4runner shifter
Picture of the offending pin and the plastic cylinder it fits into too loosely.
06-07-2017, 10:20 PM
#62
Yep, that's a pretty good description, Montego. Maybe even more than 14 years. The longer pin extending further into the plastic cylinder results in a lot less lateral pressure on the top portion of that cylinder during the shifting process. Good luck!
06-07-2017, 11:39 PM
#63
A few years back I came up with what I think is the solution but I have been too lazy to do it.
The last time I was dealing with this a few years ago I noticed the groove in the plastic plate that sits on top of this pin. My solution (Which I haven't done yet) is to epoxy fill that groove and polish it flush.
All it seems to take is a mm and this pin won't stay in.
This summer I am hoping to muster the energy to take the console apart and epoxy fill and sand the plate.
2003 V8 Sport Toytec/Bilstein lift, 3" front, 2" rear / 1/2" leveling kit / Front diff drop kit / Camburg upper A arms / Mayem Rampage 17x9.-12 Matte black wheels / Duratrac 265/70R17 Tires
06-08-2017, 12:41 AM
#64
The underside of the plastic plate on my 4 runner didn't have a groove worn in it, Vertigo, but it does have a series of peaks and valleys that, along with that spring loaded pin are part of the design to keep these things in gear. It was actually fairly easy to remove to console trim and get at the shifter on my 03. Well worth the time. Good luck with yours.
06-08-2017, 12:47 AM
#65
I had it apart several times when originally trying to get the pin in place.
Mine has a shallow groove worn into the plate, at first I thought it was kind of designed that way to track the pin. At the time when I realized it was actually part of the problem I put it back together and just haven't got around to taking it apart again.
How many KM on yours then the problem came about? I had about 165k on mine when it happened.
06-08-2017, 01:08 AM
#66
My machine has about 195 k on it, mostly on the prairies. We've spent the last few years in the mountains, doing a lot more downshifting and the like, so I guess I wore it out. Hopefully you can restore that top plate. Sounds like you're on the right track.
06-08-2017, 01:40 AM
#67
Hey all just came across this thread and hopefully this post can be of some help.
I had this issue on our 05 Sienna as well and was able to find a good permanent solution...(post #8)
broken shifter 05 XLE - Toyota Sienna Forum - siennachat.com
Essentially what this person did was find a 3/8 metal tube that fit the bullet shaped pin and widened the original plastic hole to fit the tube thus reinforcing it. I did this on our Sienna and seems like a pretty solid solution. I haven't seen the 4runner's shifter assembly taken apart in my own eyes yet but I figured I'd post this to see if it would be some help. I guess this might've been a common design issue
06-08-2017, 09:54 AM
#68
I had the pin socket break on my '03 Limited a few months back. Finally found a good used replacement shifter assy., on ebay and installed it a few weeks ago. Now shifter works as it was intended to. A few thoughts on why the old one failed, other that the poor design. I think, at least in my case, that I became too lazy when shifting out of park and didn't give the shifter enough time to find its way through the zig-zag motion on its own. Making the shifts too fast, may have contributed to putting too much stress on the pin socket, and caused it to fail. With the 'new' shifter in place, I am making an effort to slow down when changing gears, and let the shifter find it own way through the pattern with out forcing it. So, far it seems to be working fine.
I can Explain it to you, I can't Understand it for you.
'08 Tundra SR5 5.7 V8 Double Cab, White, Equalizer WD system, '91 Coachmen Catalina 260FK, '89 Grumman GSS w/35HP Force O/B, 8' Snowbear utility trailer, 2012 Polaris 500HO LE in Camo, 7 x 14 TWF Landscape trailer w/2 ramps.
06-08-2017, 11:44 AM
#69
I don't think those peaks and valleys are the problem -- those detents are there to hold the shifter in position using the spring and rod.
If I'm understanding this correctly, the problem is the rod itself getting hung up on grooves in the plastic cylinder as it travels up and down riding those detents. My theory is this: 99% of the time, it's just shifted into "D" and never beyond. After many shifts, the flat edge of the rod wears into the cylinder but stops carving at the "D" position because it rarely was moved past that. Later on when one tries to shift it there, the pin can't slide past the ridge it created over time, and the force added to move the shift then breaks the pin out of the cylinder.
06-08-2017, 03:10 PM
#70
OK. I messed around with springs and a new fabricated pin today and didn't have the results I wanted.
So I started looking at another direction and realized that yes, the OEM spring is really tense and a softer one would do a far better job... however.
Methinks part of the problem lies with where the pin has to go. Check out these photos.... I do apologize for the obnoxiously large photo attachments, however I wanted people to have the ability to zoom in at detail if desired.
So everyone can see what goes on in there, I've identified the path where the slider pin rubs on the bottom of the plate. To identify the path, I smeared fresh grease on there, ran the shift through the pattern, and removed the plate to see the new lines. If you look closely, you can see where the pin has carved into the plastic between P, R, and N. Remember this is backwards because the part is flipped over.
The horizontal shift from D to 4 (3 for our V6 friends) is where the problems seem to manifest. That said, look at that huge jump the pin has to slide over to get into that shift position. That is where it hangs up.
I think that by removing material from that area (shown by the pointer) we could relieve the force needed to move the shift into 4/3. Of course, this doesn't explain why it didn't always hang up since new.
Now... I'll be honest. I'm not willing to tear mine up for a maybe - especially if my gamble makes it worse.
If anyone knows of a broken/ruined/junker shifter somewhere they can send me, I'd be more than willing to do the experimentation, documentation, and grindywork and figure out the best way to do this... I've been looking but haven't found one yet.
Stay tuned...
Reason: Grammar, added photo, and resized images because huge.
06-09-2017, 02:05 AM
#71
Wait, Vertigo.... I just realized that we may be talking about the same thing.
Are you talking about filling in that "divot" pointed out as "D" in the closeup photo above?
That could work very well....
06-09-2017, 11:29 AM
#72
Real Name: Ed
Real Name: Ed
@ Montego Murph
: Great thread!!! Wow, you deserve a free lunch.
You mentioned where it basically starts: The horizontal shift from D to 4. Mine is tough to shift, but to return it to D, it is fine. Anyway, I have a friend who regularly goes to yards, so he'll keep an eye out for one. If he scores one, I'll be sure to let you know so I can send it to ya!
06-23-2017, 07:49 PM
#73
Hey TechWrench
I did the same as you, found one in a junk yard for 50 bucks. I've got it bolted down, but I can't get it into gear - which I need to do to unbolt the old cable. I've plugged in two electrical connectors, one of which I think allows you to get it into gear, but still no luck.
Any idea what I'm doing wrong? Thanks
06-23-2017, 07:54 PM
#74
I never got notification of your post..
It's a groove that travels the route the pin does, it looks like it's worn in from the pin, it doesn't look like a factory groove.
It may allow the pin to sit up a mm or two higher than it should.
06-23-2017, 07:55 PM
#75
Originally Posted by 03_4R_LTD
Hey TechWrench
There is a small square cover on the shifter plate, it's release for the shifter, Carfuly open the cover with a screw driver and press the button inside.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
